Results 1 to 12 of 12
    Feb 03 2016
    Cleveland
    A6 Headlight Fuse Location
    I looked through the owners manual but didn't see anything for the headlight fuse.
    I started up my car the other day and the DRLs on both sides and the rt front headlight are all out, so assuming it's a fuse since they all went out at once.
    Established Member Two Rings Los Cuentos's Avatar
    Mar 02 2015
    Volswagen Bug '69
    Belgium
    Should first look into your MMI under the car menu if everything is activated. Do you get an error on your cluster?
    Audi A4 B7 Avant 1.9 TDI - 150HP - Bagged by Airlift - Fitted by Rotiform
    Feb 03 2016
    Cleveland
    Yes, I get an error that all of the front lights are out except the left projector.
    Feb 03 2016
    Cleveland
    Any Audi techs on here?
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    What year is your A6?
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Feb 03 2016
    Cleveland
    2013 2.0t Premium Plus
    Oct 11 2011
    2018 A5 SB
    The headlights are controlled by the Vehicle Electrical System Control Module J519. There are 5 fuses that are tied to that module. The fuse panel D is located under left instrument panel.
    Check these fuses. If they are good than maybe bad control module J519.
    Hope this helps if you have not already fixed the issue.
    6 - Fuse 6 (on fuse panel D) -SD6- 35 A - Vehicle Electrical System Control Module -J519- 30
    7 - Fuse 7 (on fuse panel D) -SD7- 20 A - Vehicle Electrical System Control Module -J519- 30
    8 - Fuse 8 (on fuse panel D) -SD8- 30 A - Vehicle Electrical System Control Module -J519- 30
    9 - Fuse 9 (on fuse panel D) -SD9- 30 A - Vehicle Electrical System Control Module -J519- 30
    10 - Fuse 10 (on fuse panel D) -SD10- 30 A - Vehicle Electrical System Control Module -J519- 30
    Feb 03 2016
    Cleveland
    Thanks jrsAudiA6! I will check these out today and let everyone know for future reference.
    Feb 03 2016
    Cleveland
    Update:
    I checked the owners manual and the only fuse panel D is in the trunk. I'm guessing it may be in the cabin for a A4 or something?
    Looking at the fuses on panel D in the trunk, no burnt fuses. So on to J519...does that have to be checked at the dealer?
    Oct 11 2011
    2018 A5 SB
    The fuse panel D that is referenced in my previous post is not mentioned in the manual. According to the wiring diagram document I have this panel is located under the left Instrument panel. It is not the one in the Trunk.
    The following is what I cut and paste from the wiring diagram.
    Component Location Fuse Panel D -SD-
    Component Location, left-hand drive
    On relay arrangements, under left instrument panel.
    Fuse Colours
    ♦ 40 A - orange
    ♦ 30 A - light-green
    ♦ 25 A - clear
    ♦ 20 A - yellow
    ♦ 15 A - light-blue
    ♦ 10 A - red
    ♦ 7.5 A - brown
    ♦ 5 A - light-brown
    Assignment through model year 2014
    A - Fuse panel D -SD-
    ❑ Only left-hand drive
    ❑ Position of Fuses, through model year 2014
    1.9.1 Position of Fuses Fuse Panel D -SD- , through model year 2014
    No. Designation in Wiring Diagram Nominal Value
    Function/Component Terminal
    1 - Fuse 1 (on fuse panel D) -SD1- 5 - Terminal 15 power supply relay -J329- 30
    2 - Not used -
    3 - Fuse 3 (on fuse panel D) -SD3- 5 A - Sensor Electronics Control Module -J849- 30
    4 - Fuse 4 (on fuse panel D) -SD4- 20 A - ABS Control Module -J104- 30
    5 - Fuse 5 (on fuse panel D) -SD5- 5 A - Anti-Theft Alarm System Sensor -G578-
    Alarm Horn -H12-
    30
    11 - Fuse 11 (on fuse panel D) -SD11- 5 A - Front Interior Light -W1-Roof Electronics Control Module -J528-30
    12 - Fuse 12 (on fuse panel D) -SD12- 5 A - Auxiliary Heater RF Receiver -R64- 30
    Sep 21 2019
    Pennsylvania USA
    Headlight issue 2013 A6 3.0 Quattro
    Quote Originally Posted by jrsAudiA6 View Post
    Fuse Colours
    ♦ 40 A - orange
    ♦ 25 A - clear
    ♦ 20 A - yellow
    ♦ 15 A - light-blue
    ♦ 10 A - red
    ♦ 7.5 A - brown
    ♦ 5 A - light-brown
    2 - Not used -
    Alarm Horn -H12-
    30
    Hi.*
    First post, thanks everyone for your help!
    Situation: I had a working headlamp (R side) that I replaced to match the one that had blown on the L side. Within two days the R side went out. Also lost my DRLs and right turn signal. Traced the problem back to a fuse in the J519 module that had blown. I replaced the fuse and the headlight with the original OEM that was working fine on the R side.*
    The fuse blew again. So now I've isolated the issue to somewhere between the fuse and the headlamp. I just don't know where.
    Question: I am at a loss about any other headlamp relays between the fuse and the headlamp that might be*the issue. I can't find any other diagrams that might help me source the problem. The wiring shouldn't be shot. I imagine a bad headlamp overloaded a circuit and fried something. Anyone have any thoughts on what that might be?
    Thanks in advance for any help!
    Feb 25 2010
    magimmeMVE
    Usa
    A diagnostic scan wold help a lot in order to narrow down a faulty headlight module or a more serious J519 issue
