Results 1 to 40 of 57
    Jul 26 2014
    OBD-II PIDs for Audi B8 / B8.5 S4 / S5 3.0T
    Picked up an el-cheapo OBD-II WiFi dongle and loaded EngineLink app from AppStore this weekend to have a chance to monitor some basic ECU parameters on the go (I also have VCDS and realise that OBD-II based universal tools will never compete in accuracy and scope of diagnostic info provided). Wanted to be always able to check the simple things like boost / IAT etc. on my iPhone without the need to go get a notebook from home etc. I quickly realised that even the best examples of mobile dignostic apps (like Torque Pro, which is not available for iPhone btw) seriously lack in engine parameters display department with such simple things like e.g. IATs being not available on my B8 S5 3.0T.
    I spent some time to pick up the most notoriously lacking info and wanted to share (in a secret hope someone would share back more info )
    These may be added as custom gauges in any OBD-II app that supports adding custom PIDs (note you may also change the formulas as you wish e.g. to get it in F and psi instead of my units or calculate boost rather than absolute pressure):
    Charge air cooler temperature (IAT post-charger, post-cooler, in C) PID 77, formula: B-40
    Intake manifold pressure (actual, absolute, in kpa) PID 70, formula (D*256+E)/32
    These worked out of the box and I think are availble as such on most apps but I thought I still list them as confirmed to be working:
    Ignition timing advance (in deg) PID 0E, formula A/2-64
    Engine coolant temp (in C) PID 05, formula A-40
    Would be happy if anyone shares more or confirms my findings above as working on his car as well. If any more custom PIDs info would follow up I'll update the lists.
    2011 S5 Sportback
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Just for reference,IAT's are available in Torque pro on Android.
    They are under the heading CACT (Charge Air Cooler Temperature iirc)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jul 11 2016
    Mississauga
    There are a lot options in DashCMD... have not played around too much with it.
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    I use DashCommand and it doesn't support IAT or Boost PIDs. I don't think I can add custom PIDs to it which stinks.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    I just downloaded the Torque app. Seems to have a little more options on logging perimeters than dash command. Is there a way to log boost bypass?
    Jul 26 2014
    Quote Originally Posted by xpoweruk View Post
    Yes, this is exactly what made me dig into it. I think they pull the data exactly from the PID I mentioned above.
    Quote Originally Posted by umairg35 View Post
    Quote Originally Posted by awwturbo View Post
    Yes, looks like DashCommand for iOS does not allow custom PIDs unfortunately. They say due to Apple limitations on app developers: http://www.palmerperformance.com/for...p?topic=1926.0
    I used EngineLink, not as nice looking but does the job and has custom PIDs functionality.
    Quote Originally Posted by derek.kritz View Post
    PID 72 would be my guess, but no idea if the data is there and how to interpret.
    Wikipedia has a nice page on OBD-II PIDs but not all ifo is universal across the different vehicles and formulas are often missing https://en.wikipedia.org/wiki/OBD-II_PIDs
    2011 S5 Sportback
    Aug 23 2015
    Texas
    OBD Fusion for iOS allows custom PIDs, has Apple Watch support, and supports the Carista adapter. I'm going to test the IAT PID later today.
    OBD Fusion - OBD2 vehicle scan tool and diagnostics by OCTech, LLC
    https://appsto.re/us/eOkYM.i
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by omegis83 View Post
    Ya I've been pretty impressed with OBD fusion for simple logs. Seems to work well for IATs.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Aug 23 2015
    Texas
    Quote Originally Posted by Hofahome View Post
    What PID are you using to track IATs? I've tried Charge Air Cooler Temperature Bank 1, Sensor 1 with OBD Fusion but it seems slow to update.
    Jul 26 2014
    I don't have OBD Fusion but from the name of it I guess you use one of the parameters available by default. Did you try to add the one in the first message? Does it work?
    2011 S5 Sportback
    Aug 23 2015
    Texas
    Quote Originally Posted by -leman- View Post
    Nope because it needed OBD mode number
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    gr8 info on the Torque App pro and IAT, would definitely come in handy vs. dragging a laptop with me for each track day when I just want to run for fun, but monitor starting IAT's at the same time.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jul 26 2014
    Try mode 01
    I understood it's always 01 for real-time PIDs
    Also header should be "auto" or equivalent, if such option is available in OBD Fusion. If not, I guess ECM could work...
    2011 S5 Sportback
    Aug 23 2015
    Texas
    Try mode 01
    Kind of on the high side for being 75F outside
    Jul 26 2014
    Yeah)))
    What formula you use?
    If you just use "B-40" you should get the value in C (not in F), did you use an extra formula to convert C -> F? If yes, could this formula be off?
    2011 S5 Sportback
    Jan 26 2015
    CO
    Ya that's the one I use but it can be slow to update for me as well. It's good for ballparking IAT deltas and that is about it.
    Nov 10 2014
    Apex, NC
    is this boost on an iPhone? i couldn't get this sh!t working for the life of me
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Aug 23 2015
    Texas
    Quote Originally Posted by doug97gxe View Post
    Yes
    Boost pressure sensor A
    Established Member Two Rings pcardenas's Avatar
    Sep 04 2014
    S4 B8, Audi Q7
    México
    Any one has more info for Torque o for Iphone apps??
    _________
    Paulo
    S4 B8 2011 , Dual pulley , Revo 1+ , custom Brakes , bilstein b8 , H&R Rear Sway Bar, CR15 mod, Pipercross Air Filter , Magnaflow xPipe 11386
    Jul 26 2014
    What exactly parameters do you need?
    I may actually post all parameters (PIDs / formulas) EngineLink has available. A lot (but not all) work for my B8 S5. Except for the ones above (first post) I did not check if the data is plausible, however.
    2011 S5 Sportback
    Nov 10 2014
    Apex, NC
    Yes
    Custom PID? And if so can u share ur screens ?
    Present:
    Aug 23 2015
    Texas
    Not a custom PID, even though I'm planning to test the one -leman- provided in the first post. Boost is under SAE PIDs on OBD Fusion.
    Also, here's what I've got for IAT but it seems to round to the nearest whole number and I need to figure how to convert to F. I'll try the factor and offset formula. Since the app evaluates in metric, their formula is (metric value * factor) + offset, so I'm thinking factor of 1.8 and offset of 32.
    This would be a great idea!
    Update: Formula seemed to work for IAT in Fahrenheit.
    Boost formula is off. It was reading 30+ PSI at idle.
    And here's what I've got for Boost (user defined):
    And here's a list of relevant PIDs:
    http://imgur.com/a/1GLje
    Jul 26 2014
    Update: Formula seemed to work for IAT but Boost formula is off. It was reading 30+ PSI at idle. Seems the built in SAE PID for boost is more accurate (see pic) but is off by a few PSI.
    My formula for boost is in kpa, and absolute pressure. So 30+ kpa absolute is roughly -0,7 bar or -10 psi boost (that's a rough calculation, I used 14,5 psi as ambient pressure). Seems not far off if it's your value at idle.
    The link doesn't work for me...
    2011 S5 Sportback
    Aug 23 2015
    Texas
    My formula for boost is in kpa, and absolute pressure. So 30+ kpa absolute is roughly -0,7 bar or -10 psi boost. Seems not far off if it's your value at idle.
    I was trying to prevent eating up more screen real estate with my pictures but here you go:
    Jul 26 2014
    Looks like OBD Fusion has a lot available by default.
    Here's what I have in EngineLink (I copied this from CSV file, but the format is hopefully clear - fist 4 digits in each row is mode (01) and PID (04, 05, etc) - I took the US units formulas):
    ModePID,Description,Min,Max,Units,Formula,Header
    0104,Calculated engine load value,0,100,%,A*100/255,0
    0105,Engine coolant temperature,-40,419,ЎF,(A-40)*9/5 + 32,0
    0106,Short term fuel % trim Bk 1,-100,99.22,%,(A-128) * 100/128,0
    0107,Long term fuel % trim Bk 1,-100,99.22,%,(A-128) * 100/128,0
    0108,Short term fuel % trim Bk 2,-100,99.22,%,(A-128) * 100/128,0
    0109,Long term fuel % trim Bk 2,-100,99.22,%,(A-128) * 100/128,0
    010A,Fuel pressure,0,111,psi,A*3*0.145,0
    010B,Intake manifold abs pressure,0,37,psi,A*0.145,0
    010C,Engine RPM,0,16383.75,rpm,((A*256)+B)/4,0
    010D,Vehicle speed,0,158,mph,A*0.6215,0
    010E,Timing advance,-64,63.5,Ў,A/2 - 64,0
    010F,Intake air temperature,-40,419,ЎF,(A-40)*9/5 + 32,0
    0110,MAF air flow rate,0,655.35,g/s,((A*256)+B) / 100,0
    0111,Throttle position,0,100,%,A*100/255,0
    0114,Bk 1 Sensor 1 O2 Voltage,0,1.275,V,A/200,0
    0115,Bk 1 Sensor 2 O2 Voltage,0,1.275,V,A/200,0
    0116,Bk 1 Sensor 3 O2 Voltage,0,1.275,V,A/200,0
    0117,Bk 1 Sensor 4 O2 Voltage,0,1.275,V,A/200,0
    0118,Bk 2 Sensor 1 O2 Voltage,0,1.275,V,A/200,0
    0119,Bk 2 Sensor 2 O2 Voltage,0,1.275,V,A/200,0
    011A,Bk 2 Sensor 3 O2 Voltage,0,1.275,V,A/200,0
    011B,Bk 2 Sensor 4 O2 Voltage,0,1.275,V,A/200,0
    011F,Run time since engine start,0,65535,s,(A*256)+B,0
    0121,Distance traveled with MIL on,0,40721,mile,((A*256)+B)*0.62137,0
    0122,Fuel Pressure (relative to vacuum),0,750,psi,(((A*256)+B) * 0.079)*0.145,0
    0123,Fuel Pressure (direct inject),0,95025.75,psi,(((A*256)+B) * 10)*0.145,0
    0124,O2S1_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    0125,O2S2_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    0126,O2S3_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    0127,O2S4_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    0128,O2S5_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    0129,O2S6_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    012A,O2S7_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    012B,O2S8_WR_lambda(Voltage),0,2,NA,((A*256)+B)*2/65535,0
    012C,Commanded EGR,0,100,%,A*100/255,0
    012D,EGR Error,-100,99.22,%,(A-128) * 100/128,0
    012E,Commanded evaporative purge,0,100,%,A*100/255,0
    012F,Fuel Level Input,0,100,%,A*100/255,0
    0130,# of warm-ups since codes cleared,0,255,N/A,A,0
    0131,Distance since codes cleared,0,40721,mile,((A*256)+B)*0.62137,0
    0133,Barometric pressure,0,37,psi,A*0.145,0
    0134,O2S1_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    0135,O2S2_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    0136,O2S3_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    0137,O2S4_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    0138,O2S5_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    0139,O2S6_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    013A,O2S7_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    013B,O2S8_WR_lambda(Current),0,2,NA,((A*256)+B)/32768,0
    013C,Catalyst Temp Bk 1 Sensor 1,-40,6513.5,C,((A*256)+B)/10 - 40,0
    013D,Catalyst Temp Bk 2 Sensor 1,-40,6513.5,C,((A*256)+B)/10 - 40,0
    013E,Catalyst Temp Bk 1 Sensor 2,-40,6513.5,C,((A*256)+B)/10 - 40,0
    013F,Catalyst Temp Bk 2 Sensor 2,-40,6513.5,C,((A*256)+B)/10 - 40,0
    0142,Control module voltage,0,65.535,V,((A*256)+B)/1000,0
    0143,Absolute load value,0,25700,%,((A*256)+B)*100/255,0
    0144,Command equivalence ratio,0,2,N/A,((A*256)+B)/32768,0
    0145,Relative throttle position,0,100,%,A*100/255,0
    0146,Ambient air temperature,-40,419,ЎF,(A-40)*9/5 + 32,0
    0147,Absolute throttle position B,0,100,%,A*100/255,0
    0148,Absolute throttle position C,0,100,%,A*100/255,0
    0149,Accelerator pedal position D,0,100,%,A*100/255,0
    014A,Accelerator pedal position E,0,100,%,A*100/255,0
    014B,Accelerator pedal position F,0,100,%,A*100/255,0
    014C,Commanded throttle actuator,0,100,%,A*100/255,0
    014D,Time run with MIL on,0,65535,min,(A*256)+B,0
    014E,Time since trouble codes cleared,0,65535,min,(A*256)+B,0
    0150,Max value for air flow rate,0,2550,g/s,A*10,0
    0152,Ethanol fuel %,0,100,%,A*100/255,0
    0153,Abs Evap system Vapor Pressure,0,47.5,psi,(((A*256)+B)/200)*0.145,0
    0154,Evap system vapor pressure,-32767,32768,Pa,((A*256)+B)-32768,0
    0155,Short term secondary O2 trim bk 1,-100,99.22,%,(A-128)*100/128,0
    0155,Short term secondary O2 trim bk 3,-100,99.22,%,(B-128)*100/128,0
    0156,Long term secondary O2 trim bk 1,-100,99.22,%,(A-128)*100/128,0
    0156,Long term secondary O2 trim bk 3,-100,99.22,%,(B-128)*100/128,0
    0157,Short term secondary O2 trim bk 2,-100,99.22,%,(A-128)*100/128,0
    0157,Short term secondary O2 trim bk 4,-100,99.22,%,(B-128)*100/128,0
    0158,Long term secondary O2 trim bk 2,-100,99.22,%,(A-128)*100/128,0
    0158,Long term secondary O2 trim bk 4,-100,99.22,%,(B-128)*100/128,0
    0159,Fuel rail pressure (absolute),0,95025.75,psi,((A*256)+B) * 10*0.145,0
    015A,Relative accelerator pedal position,0,100,%,A*100/255,0
    015B,Hybrid battery pack remaining life,0,100,%,A*100/255,0
    015C,Engine oil temperature,-40,419,ЎF,(A - 40)*9/5 + 32,0
    015D,Fuel injection timing,-210.00,301.992,Ў,(((A*256)+B)-26880)/128,0
    015E,Engine fuel rate,0,848.7,Gal/h,((A*256)+B)*0.05*0.264172,0
    0161,Driver's demand engine torque,-125,125,%,A-125,0
    0162,Actual engine torque,-125,125,%,A-125,0
    0163,Engine reference torque,0,48338,lb-ft,(A*256+B)*0.7376,0
    0178,EGT11 support,0,1,bit,{A:0},0
    0178,EGT12 support,0,1,bit,{A:1},0
    0178,EGT13 support,0,1,bit,{A:2},0
    0178,EGT14 support,0,1,bit,{A:3},0
    0178,EGT11 Temp,-40,6513,F,((B*256+C)/10-40)*9/5 + 32,0
    0178,EGT12 Temp,-40,6513,F,((D*256+E)/10-40)*9/5 + 32,0
    0178,EGT13 Temp,-40,6513,F,((F*256+G)/10-40)*9/5 + 32,0
    0178,EGT14 Temp,-40,6513,F,((H*256+I)/10-40)*9/5 + 32,0
    0179,EGT21 support,0,1,bit,{A:0},0
    0179,EGT22 support,0,1,bit,{A:1},0
    0179,EGT23 support,0,1,bit,{A:2},0
    0179,EGT24 support,0,1,bit,{A:3},0
    0179,EGT21 Temp,-40,6513,F,((B*256+C)/10-40)*9/5 + 32,0
    0179,EGT22 Temp,-40,6513,F,((D*256+E)/10-40)*9/5 + 32,0
    0179,EGT23 Temp,-40,6513,F,((F*256+G)/10-40)*9/5 + 32,0
    0179,EGT24 Temp,-40,6513,F,((H*256+I)/10-40)*9/5 + 32,0
    0110,Instantaneous MPG,0,100,mpg,MPG,0
    0110,Average MPG,0,100,mpg,AMPG,0
    0105,Trans temperature,-40,500,ЎF,(A-40)*9/5 + 32,TCM
    01B4,Trans temperature (1),-40,500,ЎF,(A-40)*9/5 + 32,0
    2011 S5 Sportback
    Aug 23 2015
    Texas
    Some of the PIDs are wrong on OBD Fusion though so I may try some of yours
    Nov 10 2014
    Apex, NC
    I used both of yours the boost A sensor has me idling at 4.5 and peaking at 30 .. that doesn't seem right and the user pid has me idling at 30 and peaking at 0
    Well it's better than nothing I guess
    Present:
    Aug 23 2015
    Texas
    Try this
    Nov 10 2014
    Apex, NC
    Try this
    added... will try tomorrow.. thanks for all your help
    Present:
    Nov 10 2014
    Apex, NC
    Try this
    This is much better thank you
    Weird thing the CSV didn't have Boost though I was logging it
    Present:
    Apr 11 2016
    Phoenix, Arizona
    Does anyone know how to get it to work for the tranny Temp?
    21 RS6 Stage 2
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    Can anybody post these pids on a *csv file so as to try and add them to Torque???
    A4 B8 Avant TDI 143 MY2009
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Anyone know what PID to use for EGT's on OBD fusion? I tried bank 1 + 2 sensor 1 and get no data.
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Anyone else have any new Custom PID , they discovered and what should my boost be at when idling , 0 ?
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    For some reason it's not working For me ) I'm getting 30 all the time ! any updates with boost ? I would like to see vac as well
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by UkuRiSh View Post
    Mine works but aren't you Turbo? Not sure if that makes a difference
    Present:
    Jan 09 2010
    New York
    At the moment without turbo, I will install the turbo closer to the fall and there is no difference if turbo or non turbo the difference will be boost curve. IAT works fine for me, there is the way I can change to celsius?
    Nov 10 2014
    Apex, NC
    Present:
    Jan 09 2010
    New York
    Yes I did that and getting number 30 (
    Nov 10 2014
    Apex, NC
    Only difference I can see is spaces in the formula but I doubt that could be an issue
    Present:
