Results 1 to 9 of 9
    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    8v Facelift Virtual Cockpit retrofit.
    I was waiting for this retrofit since the virtual cockpit was introduced for 8v platform. Apprently, "MQB-Coding" done this retrofit on a 2015 A3:
    https://m.facebook.com/story.php?sto...30182250375001
    It seems you need to change the whole dashboard since the existing space in pre-facelift models is not enough for the virtual cockpit display! Although it might cost you your arm and a leg, it would make my 16 S3 the perfect car.
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    Nov 17 2014
    San Francisco, CA
    I was just reading an article on mqb coding. I an taking to them right now about trying to enable the tire pressure and tire temperature in the mmi.
    Sent from my SM-N910V using Tapatalk
    Jun 16 2016
    Ontario
    Quote Originally Posted by mroberte View Post
    Awesome. Please update this thread if you found out anything interesting.
    Instagram
    Nov 17 2014
    San Francisco, CA
    Said some extra parts are needed but should work, will out up coding when provided. They are doing some amazing work!
    May 17 2016
    Hong Kong/LA
    It's been done a million times over here... You don't really have to change the dash, people usually just trim the dash housing to fit, and it's pretty much plug-n-play but you'll still need to have component protection removed, and a FL steering wheel to have the view and zoom in and out function. Also, you'll need MMI2 to utilize the whole screen, otherwise, navi will just be half the screen on VC... The whole thing including the VC/steering wheel/MMI2 is about $4K retrofit...
    Senior Member Three Rings TomPaul10's Avatar
    Aug 04 2014
    albany, new york
    I honestly think the cluster in the 8V currently ( the classic "S" cluster ) is more classy in a CERTAIN way than the virtual. now that doesn't mean its not cool as hell !
    Current: 16 mythos black S6 prestige
    past:
    13 S5 stage II+ awe track/ H&R
    2016 SQ5
    2016 Sepang S3 premium
    2010 Ibis White S4 P+ / A.W.E Track /
    2010 Stage II A5 / G.I.A.C. / A.W.E. / H&R /
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Bump.....
    Looking into getting the VC for my 16". I see a few brand new clusters and some used ones on Ebay. Even if I don't have it 100% working, I would love it! Also looking into getting the rear dynamic tails retro fitted. Please send me info on this.. Thanks!
    Junior Member Two Rings
    Feb 14 2018
    San Diego, CA
    Quote Originally Posted by TomPaul10 View Post
    That's what pre FL owners tell themselves to be able to sleep at night
    '18 GWM S3 / Tech Pkg / Black Optic Pkg / S Sport Seats / S Sport Pkg / Audi Beam Quattro /
    Mods IE Stage II ECU-TCU / IE Downpipe / 034 Carbon Fiber Intake and Air Duct / Unitronic Turbo Inlet Pipe / EMD Carbon Fiber Front Splitter / eMMOTION Rear Sway Bar kit and Link Kit / APR A01 Wheels 19x8.5 ET45 w/ 245/35R19 Michelin Pilot Sport 4S /
    Active Member Two Rings bent.'s Avatar
    Apr 04 2012
    San Diego, CA
    Quote Originally Posted by jiannu View Post
    Bump.....
    The FL taillights are one of my favorite mods so far. I picked up everything from Alexander at Europrice.us.
    Quote Originally Posted by c0ld View Post
    You're not wrong.
