1. Ground clearance. I am not driving that low, but I am tired of my subframe scraping over speed bumps.
2. Stock subframe suffers from poor welds and have several problems where they like to "shift" and cause a popping sound, especially in reverse. This can be addressed by seam welding, but this could lead to the subframe deforming since it is only stamped steel.
3. Stock subframe likes to rust. For me this isn't a huge issues since I live in Florida for the time being, but up north this is a major concern.
With all this in mind, I started researching and looking into the different options I had and the more I thought about it, the more I realized that a custom solution may be required. It would also work between platforms, so B5/6 A4, B5 S4, B5 and B5.5 Passat.
I have finally found a fabricator who is willing to make a tubular subframe for me. I dropped off the tubing for him this morning. He told me he is going to start fabricating the jig today and should be able to start bending all the piping this week. Stay tuned because there will be many more pictures to come!
In the meantime, this is the tubing I dropped off to him:
And if everything goes according to plans, this is what I will end up installing in the car:
Bottom:
Top:
I am actually going to set up the subframe to use the factory mounts just in case there is too much NHV with the 034 Motorsports solid inserts.
If you have any questions, please feel free to ask. I am bringing home the jig with me as well so if I would need to make a few more in the future, I can.
