Results 1 to 8 of 8
    Established Member Two Rings carysb7478's Avatar
    Nov 09 2006
    former: '05 S4 stick
    Jacksonville, FL
    Driver's window one touch auto up/down not working
    The one touch up/down feature has stopped working on my driver's window. I've searched already and tried the "roll all the way down, hold, roll up, hold" method and that hasn't worked. I've checked VAG settings with the Carista app (not sure if that fully functions like a true vag cable). Any suggestions on why this is happening and how to fix? Window operates completely normal otherwise- no sounds, crunch etc.
    '11 S4 Prestige DSG Quartz grey | EPL Stg II + TCU Tune| ECS Kohlefaser Luft-Technik Intake | VMR 803 19" x 8.5 | ECS 2 piece LW rotors + SS lines + Akebono ceramic pads | P3 Gauge | Beltronics STiR Plus + Laser Interceptor Dual | tint | JL sub | B8.5 S4 shift knob | RS4 pedals | Relak paddle extenders
    Former: '05 S4 manual
    Established Member Two Rings no_money2supe's Avatar
    Nov 15 2011
    Sepang Blue 2016 Audi Q5 2.0T (Unitronic Stg1+)
    Calgary, Alberta, Canada
    Similar thing happened with me. Tried the "roll down, hold, roll up, hold" method too but didn't work either. Took it into Audi and was told the actual window switch 'board' itself is broken and the entire board needs to be replaced. I haven't opened it up myself to confirm (apparently only a 3 min process), just too lazy really, but open yours up to confirm.
    If you need to replace yours too, I found the part here (cheapest):
    http://www.switchdoctor.net/audi-a4-...tch-2009-2012/
    Apparently b8's and b8.5's are the same.
    Or if you absolutely must get oem, ecstuning sells it here:
    https://www.ecstuning.com/Audi-B8_S4...Door/ES452541/
    Sent from my HTC One_M8 using Tapatalk
    2013 Audi S4 (Misano Red)
    *TRANS/ENGINE: 6MT; EPL Stage 2 w. CTS pulley; JHM Short Shifter
    *WHEELS/TIRES:
    Summer: Avant Garde m580 reps (silver), [F]19x8.5 +35, [R]19x9.5 +35, 255/35R19 Pirelli P-Zero's
    Winter: TSW Max (matte black), [F/R]18x8.0 +32, 225/45R18 Nokian Hakka R2's
    *SUSPENSION/HANDLING: KW V3 Coilovers; CR-15 strut bar; EC Alu-Kreuz
    *EXHAUST: AWE Touring w. 102mm Black Diamond tips
    Nov 09 2006
    Jacksonville, FL
    Quote Originally Posted by no_money2supe View Post
    awesome, thanks!
    So that leaves me with how do you remove the switch? Just looked and I didn't see anything intuitive. Also, what am I looking for that would be broken?
    Nov 09 2006
    Jacksonville, FL
    so I swapped out the switch, and unfortunately that did not fix the driver's window one touch not working. Any other ideas?
    Nov 09 2006
    Jacksonville, FL
    anyone?
    Mar 21 2015
    Did you actually scan for any codes?
    Nov 09 2006
    Jacksonville, FL
    I did with Carista, nothing there
    Senior Member Two Rings Turbocoop's Avatar
    Jun 08 2014
    Charleston, SC
    When doing the re-learn- dont hold the switch all the way down to the "one-touch" position. press it to the first "click" and go all the way down, and do the same going up- just to the first "click" you feel. Its hard to explain, but thats what I had to do to fix all 4 of mine once. I didnt have any codes either
    - - - Updated - - -
    Oh, and hold it for 5-10 seconds at the top and bottom after it reaches the limit each way
