Results 1 to 25 of 25
    Jul 11 2015
    Auckland, NZ
    The problem wasn't with the coils
    Hi all, you may remember I posted a thread a couple days ago stating that one of my coil packs had gone bad.
    Well we got the coil in today and swapped it out and the problem (misfire on cylinder 2) has persisted. We then replaced the spark plugs and found a decent carbon buildup on all of them, with fuel still on the 2nd cylinder plug. The mechanic also mentioned something about low fuel pressure(?).
    The mechanic has started to look at injectors now and I'm getting really worried. If anyone has any input on what I should be looking for or should try next I would really appreciate it. The car is only 3 years old!!
    TIA.
    2013 P+ A4 B8.5.
    2013 B8.5 S5 3.0T Monsoon Gray | Stage 2 ECU+TCU. APR Pulley upgrade
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Just in regards to the coil pack, I didn't see your other thread so I'm not sure what advice you received, but it would have been a lot easier/cheaper to rule that out by simply swapping the #2 coil with another cylinder to see if the misfire switched with it, if not then it's not the coil. I would think the mechanic would have attempted that prior to trouble shooting by throwing parts at it.
    As far as the plugs, it may simply be a fouled plug on cylinder 2 (carbon build up), which would be why it's wet. Have the plugs ever been changed, not sure on your mileage? Do they have another reason for suspecting low fuel pressure? I'd start with new plugs and see what happens before footing the bill for anything else.
    **Thanks to the post below I just read your other thread, seems you had a lot of people telling you what was wrong but no suggestions on how to actually diagnose what was wrong or a differential diagnosis. Too bad, could have saved yourself $450. As one person so accurately put it " "Diagnostics" for an ignition coil is such a load of shit its incredible", and turns out their diagnostic was incorrect.
    Sep 09 2010
    Destin, FL
    You couldn't have updated us on you original post?!
    http://www.audizine.com/forum/showth...nk-it-could-be
    Established Member Two Rings ap610's Avatar
    May 24 2014
    Atlanta
    Same thing happened to me a few weeks ago--fuel injector was stuck open.
    Established Member Two Rings TJet1.8's Avatar
    Jun 14 2015
    2016 Q5 3.0T
    Ontario, Canada
    Yep...I make it a habit of running Injector Cleaner every 16000Km (10000Miles).
    I just had the Stage 2 Oil Consumption fix performed on my car @ 135000Km (~84000miles) and my service adviser said the tech looked at my injectors and commented on how clean they were.
    Never had these "injector" issues on my A4.
    Were they able to un-stick the injector for you?
    • 2017 A4 2.0T - Custom Stg2 ECU & Stg1 TCU Tune (409HP/395TQ - No Meth) from garageautosports.com (thanks Bill!!), CTS CAI + TIP, CTS Intercooler, CTS Charge Pipes, GFB DV+, CTS 3" Test Pipe, CTS 3" Catback, APR Coilpacks, RS3 Plugs, 034Motorsports Trans Mount Insert, Snow Stg2 Water/Meth., Bilstein B8 Performance, H&R Sport.
      2016 Q5 3.0T - Custom Stg1+ Tune (455HP/395TQ) from garageautosports.com (thanks Bill!!!), CTS Supercharger Pulley, 034 Intake Pipe, aFe Dry Filter.
    Jul 11 2015
    Auckland, NZ
    Thanks guys, I apologise for not updating the original thread. I'm not used to forum etiquette. So is it best to ask him to look at the injector next? I will ask for all the codes that have bee triggered and post them here, maybe it will line up with someone else's experience. Do you guys think I should get a compression test done too?
    Jul 11 2015
    Auckland, NZ
    Spoke to the APR dealer this morning and he suggested I take it into him to have a look and remove the tune tans retest. So after this compression test comes back I'll probably get it taken there.
    Update: 0 compression in cylinder 2. Starting to get pretty worried now, so having it towed to the dealership to have a look. Warranty has just expired so I'm pretty paused I didn't get an extended warranty now.
    Senior Member Three Rings t28sentra's Avatar
    Nov 18 2007
    B8.5 Allroad ,B6 S4, B5 S4 (Imola - Sold), B6 A4 USP , B5 A4 Sold, Laser B5 S4, Jeep Wrangler (Sold)
    Toledo, OH
    I had similar issue and ended up being an injector seal. Compression test netted 0 PSI on one of the cylinders. Due to these engines being direct injected, if the seals fail, the cylinder will loose compression. You should be able to log this and eventually the ECU will deactivate that cylinder to protect itself. Fingers crossed for you.
    B8.5 Allroad (APR K04 E85), B6 S4 (JHM Goodies), B5 S4 Imola Avant (JHM RS6-R), Touareg V10 TDI, B6 A4 USP (REVO Stage 3) SOLD, B5 S4 (EPL Stage 3 on Meth) SOLD
    Jul 11 2015
    Auckland, NZ
    Thanks t28sentra! I sure hope that's what it is. They're sticking a camera down the valve this afternoon. Hoping for the best!
    May 24 2014
    Atlanta
    Quote Originally Posted by TJet1.8 View Post
    Luckily, I'm still under warranty.
    What brand of fuel injector cleaner do you use?
    Jul 11 2015
    Auckland, NZ
    Hi again everyone. Little update for you all. Have just heard back from the dealership, there is engine damage to the long block and bore damage. They suspect it was caused by a broken piston ring. I'm absolutely devastated to say the least. They have quoted me $21k repair plus labor. Thanks again for all your help.
    Established Member Two Rings Captain Amazing's Avatar
    Mar 22 2016
    BC
    21k? Wow, sorry to hear man. It sucks hearing about all these b8/.5 cars having engine issues.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by EMC2 View Post
    Ha, never let a dealer do it. They will rip you off and jack those prices up!!!!!!!!!!!!!!!!
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    I would go back and say the reason the piston ring broke was because the faulty fuel injector was spraying fuel all the time thus the piston was attempting to compress a liquid and therefore failed. At least try to get a goodwill repair, if not, throw that engine out and get a used one installed, it'll be way cheaper than $21K.
    Stage 1 more than you RS3
    Jul 11 2015
    Auckland, NZ
    Thanks o1turbo30v, I'll keep you all updated.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Ring failure and you have a facelift model?
    For fuck's sake, the ever increasing instances of all these engine failures is starting to have me concerned for long term viability.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I was going to start modding, but it seems like issues are becoming more common, I'm hesitant to do so.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Engine from LKQ is a heck of a better way to go: http://www.ebay.com/itm/13-14-2013-2...item4893496b0a
    Well at least cheaper.
    Jul 11 2015
    Auckland, NZ
    Yeah adamazing. Same car as you. Your build thread was actually what inspired me to get Daytona grey :)
    Nov 23 2009
    NYC, US
    How many miles on this car?
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by A4 Centaur View Post
    Agreed, until I realized that OP is in New Zealand. My LKQ replacement worked out great.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jul 11 2015
    Auckland, NZ
    45k miles
    Established Member Two Rings TVP125's Avatar
    Dec 14 2015
    Palm Beach, FL
    Not on this planet should you pay $21K to the dealer. I had my engine replaced and it was about $5K USD including long block and labor. Check a local indy shop
    12 Audi A4 S-Line
    EURODYNE FrankenTurbo F23L
    K&N Typhoon Intake
    Magnaflow Sport Series 3" Turbo Back Exhaust
    Treadstone TR8L Intercooler
    ST Coilovers
    Established Member Two Rings Mussa's Avatar
    Oct 31 2015
    Istanbul - Turkey
    A complete new engine costs around $15k. How could it cost that much even without the labor included?
    I've had my engine replaced FOC worth $15k including labor. For a 2013 45k miles car you should definitely try for a goodwill repair.
    2011 A4 B8 2.0 TFSI Quattro S line S tronic // APR Stage 2 98 RON - OEM Dual Exhaust - OEM 3.0 TDI FMIC
    - USP HFC - RS4 Black Grille
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I must stop reading these threads.....
