Results 1 to 19 of 19
    Senior Member Three Rings Borg54's Avatar
    Nov 07 2005
    Sprinter Van, Too many motorcycles
    Marin, CA
    My First Few Mods On My A7
    I was finally lucky enough to get an A7. I have an irrational thing with hatchbacks and fell in love with the lines of the A7. I wanted to share my first few mods. These are mostly inexpensive DIY but I think they add to the look of the car. More importantly they can all be easily removed should I want to sell the car. Most folks on here know that selling a customized car is way harder than a stock one.
    First up was the steering wheel and gear shift. This was super easy and only took about 5 mins to swap. The stock steering wheel in the A7 made the car look like a old Lexus IMO.
    Next I used Plastidip to blackout the grill. It was quick and I can always peel is off if I sell the car. I know plastidip is a little ghetto but its fun and so easy to remove.
    Before:
    After:
    Blacked out the chrome (I HATE CHROME) window trim with matte black vinyl:
    Grayed out the rear badges (they look black in photos but are a matte gray in real life). I liked this better than pure black:
    Soon I would like to add some H&R springs and possibly an AWE exhaust. The exhaust on the A7 is way too quite
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    Looking good. Where did you pick up the wheel and airbag if you don't mind me asking?
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Feb 25 2014
    Texas
    Steering wheel was crucial! Looks great
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by psiaddict85 View Post
    I got the wheel on eBay with the airbag included. It isn't cheap but its great quality and I thought it was worth it for how much it changed the interior. All controls work perfectly
    https://www.ebay.com/itm/222265430279
    Established Member Two Rings Davor_'s Avatar
    Nov 10 2015
    St. Paul
    Did you follow a DIY tutorial for these (I have the same wheel in the mail) and I also want to switch my gear shifter :/
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by Davor_ View Post
    I used this video:
    https://www.youtube.com/watch?v=BBs-YTEUCCY
    The video quality isn't great but it works. The idea to use a phone's front camera to see the clips was a good idea. You will need a torx bit to remove the center steering wheel bolt. I used a flathead screwdriver to remove the airbag clips. Install is reverse of removal. Make sure the wires to hook up the controls aren't kinked when you put the airbag back in. The airbag just presses back into place and you will feel the clips click. Make sure both are clipped.
    Sep 28 2009
    suburb
    Yeah get some springs and to hold you off, have muffler shop do some cutting (search this forum for options) and it will sound better. Looking good!
    Oh I put alu kruez chasis stabilizer on my car the other day. Wanna buy my stock s7 one? it should be thicker than yours and will reduce body roll. Easy bolt on.
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Established Member Two Rings Scooter1's Avatar
    Oct 05 2015
    Jacksonville, Fl
    Quote Originally Posted by Borg54 View Post
    Before:
    After:
    Rear badge looks great. May I ask how you did it?
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by Scooter1 View Post
    I used a gray matte plastidip spray. Just mask off the general area then spray the badge with about 4 coats. Peel off the overspray with a toothpick and your finger. No need to remove the badge and if you want it can also be removed from the rings later
    Senior Member Two Rings Glacier6's Avatar
    Mar 11 2014
    Chicago
    Car looks great! How many coats of dip did you do on the grille?
    2019 Q8 Prestige Daytona Gray / Year 1 / Black Optic / S Line / Luxury Package / Alcantara
    2012 A7 Prestige Quartz Gray / Innovation Package / Driver Assistance Package / Sport Package / LED Headlights / B&O / 20x10 Niche M116 (Gone)
    Mar 11 2014
    Chicago
    Quote Originally Posted by Glacier6 View Post
    I did the same to mine but you might want to double it up since the rock ships begin to show with only 4-5 coats.
    Other than its a super easy mod that looks great and like you said, just fun to do on your own.
    Nov 07 2005
    Marin, CA
    Thanks for the heads up
    I did about 10 coats on the grill. It is my first time using it so I'm curious to see how it holds up. Only takes about 20 mins to touch up but if it becomes a problem I'll probably just put in a mesh RS7 style grill.
    Mar 11 2014
    Chicago
    You should be set! It's surprising how well it holds up. No fading whatsoever in over a year.
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Great progress so far and nice choice on the steering wheel. That was one of my first mods as well.
    Definitely change out those pedals. I got a full set (with dead pedal) on Amazon for $50. Makes a huge difference in looks and you couldn't tell the difference from a real oem set.
    Also, let me know if you're interested in a k&n filter. I know...shameless plug.
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    Aug 01 2016
    San Francisco
    [QUOTE=Borg54;11950041]I was finally lucky enough to get an A7. I have an irrational thing with hatchbacks and fell in love with the lines of the A7. I wanted to share my first few mods. These are mostly inexpensive DIY but I think they add to the look of the car. More importantly they can all be easily removed should I want to sell the car. Most folks on here know that selling a customized car is way harder than a stock one.
    Was the vinyl wrap for the window strip easy to cut and install? I was thinking about doing plastidip or do you think the vinyl wrap gives a cleaner look?
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    I like everything except for the grey rings.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Nov 07 2005
    Marin, CA
    [QUOTE=Charlie_41510;11953394]
    I plastidipped them first and it didn't work well. I grab the A pillar as I get in the car and it would start to peel it off. The vinyl is a little more durable.
    It is pretty easy to do if you have any experience with vinyl. If you don't it still isn't rocket science just need to be patient and use spray (soapy water) underneath to get the bubbles out. I installed then cut with a razor blade. Went pretty fast.
    Aug 01 2016
    San Francisco
    Got it. Thanks!
    Active Member One Ring Deelow29's Avatar
    Oct 27 2016
    Atlanta Georgia
    That steering wheel made a big difference, gives me an Idea to change out my own!
