Results 1 to 12 of 12
    Active Member One Ring itzelmar's Avatar
    Feb 11 2016
    Portland OR
    Pee smell coming out of the air vents! Audi A4 Cabrio
    I have changed the cabin filter and even the engine filter.
    Urine smell coming out with the air out of the vents anytime I use the heater or AC.
    No sure where else to look..if you know something about this problem please help! :) thank so much!.
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I had this problem recently. Do you have cats? Are there feral cats in your neighborhood? They are probably marking their territory on your car. Spray some repellent on it..
    Feb 24 2004
    Minneapolis
    ^^^If he's right, you still have pee to clean up.^^^^ Pull the glove box (might as well lube that stupid little hinge damper that always needs attention on a B7) then pull the blower motor. See if there is any pee in the HVAC box there. That's the most likely place...not sure how it would get past that point but you never know.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Established Member Two Rings 2Low2Go's Avatar
    Feb 22 2016
    San Luis Obispo
    Do you smoke cigs? Sometimes people who smoke in their cars end up with a pee-ish smell from the smoke accumulating in the inside of the vents. Just a possibility.
    Active Member Two Rings Beastopher's Avatar
    Sep 06 2015
    Appleton, WI
    How drunk did you get last night? Seriously though, I've seen cases of feral cats marking on cars.. not very nice at all! Best of luck cleaning it up if that's the case!
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Could be rodents nesting underhood or in the rain tray area as well.
    Feb 15 2016
    Cambridge,Ontario
    either way not fun times coming ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 11 2016
    Portland OR
    No, I dont have cats but yes I have seen cats in my neighborhood..it doesnt sound fun :O
    Established Member Two Rings geerd's Avatar
    Aug 18 2013
    frozen north
    prior owner may have been a smoker get the vent cleaner from chemical guys or auto store and spray in vent from cabin filter opening
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by 2Low2Go View Post
    How does ciggies smell like pee?
    My respray thread
    Feb 15 2016
    Cambridge,Ontario
    I used Lysol .. but it was for bacteria in the vents not cat pee. you may have to look a little harder for the " cat pee" Lysol
    1976 Yamaha XS 360
    Feb 22 2016
    San Luis Obispo
    Once cig smoke builds up in the vents you get a musky pee like smell. It's the accumulation of smoke buildup inside the vents. Not a cig-like smell. Find someone who smokes in their car with the ac on and you get what I'm saying. Just a thought, hopefully it isn't actually pee in the car.
