Results 1 to 20 of 20
    Oct 03 2016
    Sacramento, CA
    245/40 vs 245/35
    Has anybody run 245/35 tires on 18x8" wheels? My stock tires are 235/40 and I'm looking to upgrade to 245s, but I'm not sure if 35 or 40 works better with that width. Looking for opinions about track performance too, if anybody has experience with either ratio.
    Thanks
    Edit: stock tires are 235/40R18 not 235/45R18
    2008 A4 3.2L Quattro S-line 6MT, Dolphin Gray
    RS4 rear sway bar, slotted rotors, EBC yellowstuff pads
    Veteran Member Four Rings Firefox250's Avatar
    Nov 17 2009
    BT B7 A4 Sedan Quattro & B7 A4 Avant Titanium 2.0T Quattro
    Aurora, Colorado
    245/40 vs 245/35
    I run Toyo R888 235/40R18 on a 18x8.5 ET35 with rolled finders and -1 camber and I'm 25" from fender to ground. I don't have any rubbing but damn track tires are WIDE!
    Tuned by UNITEDMOTORSPORT
    HTA3073 Build page
    Bluewaters Performance blog on my build
    Oct 03 2016
    Sacramento, CA
    How do you like the 45 profile ratio on your setup? With a 235 tire, that puts the thickness at around 105mm... which is 20mm more than a 245/35!
    Nov 17 2009
    Aurora, Colorado
    Ooops I meant 235/40R18
    HTA3073 Build page
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    245/35/R18 are 2.4% smaller in diameter than the 235/40/R18, that means a bit more acceleration by sacrificing maximum speed in any given gear.
    How come you're running 235/45? The 40s are recommended for B7s on 18"?
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Oct 03 2016
    Sacramento, CA
    Oops, like firefox here I didn't even notice that I wrote 235/45. That should be 235/40... like you said, the recommended tire size for 18" B7 wheels.
    A little more acceleration would be a nice byproduct of the 245/35s, but I'm mainly looking for handling benefits. Not sure if the 40 vs 35 will really reduce tire roll-over in hard corners, but I thought I'd see if anyone has experience running them.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I'm running 245 40r18. Never had any issues or concerns going into or out of corners. I'm 2.5 degrees camber all 4 tires. Anmbout the same height at Firefox and no rubbing that I've ever noticed, no rolled fenders just the front upper screws removed from fender liner. I think et 35 front, et 30 rears.
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I'm 245/40/18 and have slight rubbing in the passenger rear tire going over some crazy bumps. other than that, no issues. my rims are +48 I believe as well.
    Oct 03 2016
    Sacramento, CA
    Are you guys running on 8" or 8.5" wide wheels?
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    245/35/19
    245/40/18
    245/45/17
    End thread/
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jun 27 2011
    235/40 tires shouldn't have any appreciable roll in hard cornering, assuming you have properly specced sidewall ratings.
    I wouldn't consider 245s crammed on 18x8s as an "upgrade" either. you get more meat, but when the width of the tire exceeds the width of the wheel, the contact patch can wobble side to side and in theory could degrade handling and traction.
    Also, though, its only 1/2" so realistically you're not going to gain any sort of appreciable traction on the road by doing this. You're MUCH better off spending a bit more coin on better tires at the appropriate size than you are oversizing tires...
    For instance get some Michelin/Bridgestone Max Perf Summer tires at 235/40/18 and tell me that they don't have enough traction for your needs...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 03 2016
    Sacramento, CA
    This is what I was looking for. I guess I assumed 245 width would be better for dry handling since it's wider than 235, but your post makes sense given the other factors at play. 235/40s seem to be a little cheaper than 245/40s too (for the same tire anyway).
    Thanks for the input
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    265/35R18 on 9.5" wheel... Do it.
    Jul 17 2015
    miami
    Quote Originally Posted by NorCal_B7 View Post
    I believe mine are 8.5"
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    I ran 265/30/r19's and honestly they were great. I had a bit of rubbing on the outer wall when my rear subframe wasn't aligned but nothing too horrible. They were super wide though so be aware. I ran 245's in the front. No way the 265 would have fit.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Jul 18 2015
    Quote Originally Posted by yeoj112689 View Post
    I'm thinking of running the same size tire setup. With the right wheel offset, camber adjusted, and a fender guy that know his shiz, I plan on getting 265s all around.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    I run 245/35/19 on a 19x8.5 ET 35 on my lowered avant with no issues, keep the 18' s for winters and go 19's.
    Stage 1 more than you RS3
    Jul 18 2015
    Quote Originally Posted by o1turbo30v View Post
    I have the same size wheels. I originally tried 245/35R19s, my buddy rolled all the fenders and they still rubbed... Too much that I didn't want to drive it like that. He said they could fit if he pulled the fenders a good amount but I wasn't feeling it at the time so just slapped on some 235s and there's no rubbing at all. Have you adjusted for a good amount of camber or have you had fender work done?
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by b7_Andy View Post
    Did nothing to the rear, the front i only removed the fender liner bolt that's on the bottom lip of the fender, no rolling, pulling, cutting, trimming, etc. Lowered about 1.5" on Eibach springs with Bilstein Sports. Its a close fit so maybe your tires you had carried a slightly wider profile than my Pirellis. My Pirellis had a very slight stretch on the 8.5 wide wheel that's why i think they work.
    Jul 18 2015
    My 235s have a slight stretch. My 245s looked pretty beefy as seen in the picture
