Results 1 to 6 of 6
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Anybody ever use this stuff: Bg109 Bg EPR Engine Performance Restoration
    Several friends of mine whom are mechanics/technicians swear by it especially for European vehicles due to the issues of carbon build up in the motor.
    Thoughts ?
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Jun 20 2015
    NC
    Use it every oil change.
    Differences? Maybe I don't know.
    Feb 21 2015
    Ohio
    Quote Originally Posted by Sceanzo View Post
    What's ur process? Get a cheap filter oil, run that thru it for like 20 mins, then immediately swap out with new filter and oil?
    Sent from my SM-G900V using Tapatalk
    Jun 20 2015
    NC
    No. With the engine cold. Pour into crank case. Start engine and let it idle until running temp. (I let my oil temp get to about 190°)
    Cut it off. Drain oil and change filter. Done
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Carbon build up is mostly or maybe even completely due to oil vapour in the PCV system that cakes on hot intake valves. An oil additive shouldn't affect this at all.
    Jun 20 2015
    NC
    Quote Originally Posted by cjw View Post
    Correct. This fluid is supposedly suppose to clean build up on the pistons
