Results 1 to 19 of 19
    Established Member Two Rings truethat72's Avatar
    Jul 25 2014
    San Antonio, TX
    Yokohama vs. Michelin
    I know this is a no brainer but the tire shop said the Yokohama Advan Sport A/S is very similar to the Michelin Pilot Super Sport in terms of performance. The Yokohama is about $60 less per tire.
    I am not planning on taking the car to the track or drive it too hard. Anyone has experience with those specific Yokohama?
    ////// 2014 B8 S4; Misano Red; DSG ; APR ECU Stage II with Ultra Throttle Charger; APR TCU; ECS Cold Air Intake; AWE Touring Exhaust with Down Pipes ; H&R rear sway bar //////
    ////// 2006 B7 A4; Black; 2.0T; 6MT; APR Stage I //////
    ////// 2004 B6 A4; Silver; 3.0; 6MT //////
    Veteran Member Four Rings Gusman1's Avatar
    Jun 01 2014
    2018 BMW M2
    San Jose, CA
    I have never run Yokohama but everyone here and online reviews will tell you that the Michelin PSS is the best street tire on the market.
    Allroad
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    A studless snow & ice tire is very similar to a summer performance tire? You might want to find a new tire shop...
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by truethat72 View Post
    I know this is a no brainer but the tire shop said the Yokohama Iceguard IG52C is very similar to the Michelin Pilot Super Sport in terms of performance. The Yokohama is about $60 less per tire.
    You're joking right?
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Wow, seriously. You really do need to find another shop ASAP. Maybe the shop meant that they are both made of rubber and comes in black?
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
    Jul 25 2014
    San Antonio, TX
    My mistake. I meant Yokohama Advan Sport A/S.
    Mar 04 2015
    Somers, NY, USA
    Phew
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Yoko is all-season and won't offer the all out performance of the Michelin. I'm kind of in the same boat. My Conti's are getting kind of worn. I get snow here so the Michelins would not work all year round. They would make sense when running summer wheels and switch back to peelers with Yokos for winter, however.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    If they really said that I would suggest they produce the findings to support such a claim. I very highly doubt the Yoko A/S would even come close to the PSS in terms of performance.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    The Yoko is a great all season but it's not a SS.
    2012 S4 (sold)
    Senior Member Three Rings phxS4's Avatar
    Oct 09 2013
    Phx/AZ
    I have these yoks - get the SS. Yes, they're cheaper, but there is sacrifice and I can feel it in turns.
    Senior Member Two Rings MagillaGorilla's Avatar
    Nov 25 2015
    London Ontario
    Maybe wait for these bad boys if you can.
    http://www.tyrereviews.co.uk/Article...ss-Release.htm
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I happen to love Yokohama tires. I've used both tires in question, and for normal driving you can't go wrong with either.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    There's no way that a Yokohama A/S can match the industry-leading summer performance tire.
    Only you know how you drive your car- if you are never pushing the adhesion limits then it probably doesn't matter, and a set of all seasons will probably last quite a bit longer given the higher treadwear rating (440 vs 300 for PSS). For me personally, I do explore the grip limits frequently, so the Super Sports are a no brainer.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    I've always gotten upwards of 40k miles out of all my PSS tires (non track use). Up front it's more cash but in the long run, people who spring for the yokohamas, hankooks/similar typically replace their tires twice over that 40k period before I've gone through the PSS. Additionally, those 40k miles are driven on weaker performing tires which should also be a turn off.
    Jun 02 2016
    IN
    Not even in the same class..... PSS is far and above the better SUMMER/PERFORMANCE related tire. If you are worried about rain/snow....now there is a difference.
    2011 s4 Prestige---Stage 2 Pulley APR-------APR Intake-------APR Exhaust-------H&R Coilovers-------front and rear sway bars-------Deval front and rear carbon diffusers------ Carbon Fiber Fitted including rear spoiler
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Love it when tire shops come up with these crazy comparisons just to move their inventory. My bet is they make more money on the Yokes.
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    Why no Conti DW? I LOVE mine.
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
