Results 1 to 9 of 9
    Nov 29 2011
    Salem Oregon PNW
    2009 a4 cabriolet B7 or B8??????
    Just bought a 2009 a4 cabriolet. And want to start modifying it asap. I know it's a b7 body style but most parts sites don't list the 2009 only the 2008 just like this site. Does any one know if the 08 and 09 are the same? I know mine is the first year for 2.0t Quattro (that's why I bought 09) but it's making it a pita for parts like suspension and exhaust.
    Thanks
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Some B7s were sold under the 2009 banner. Not only the but the Cabriolet is an entirely differant 2 door body. A pic might help.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    if its a B7 then parts from 05.5-08 should be the same...
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I don't think there were any B8 cabs in the US. The B7 cabs continued on to the following year (2009).
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 29 2011
    Salem Oregon PNW
    This is what the outside looks like
    This is the interior
    Sep 16 2013
    Pa
    Looks like an S line B7 to me.
    Nov 29 2011
    Salem Oregon PNW
    But it's a 2.0t Quattro the only year for the b7 to have a 4cly Quattro. So what exhaust fits? Is it the same suspension as the 3.0 Quattro?
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    You might also want to post this question here: LINK
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    Sep 16 2013
    Pa
    If im not mistaken i believe the S4 and the 3.0 exhausts are compatible. Also as i understand it, the 2.0 has its own configuration, and so a differant exhaust.
