Results 1 to 17 of 17
    Established Member Two Rings multiphrenic's Avatar
    May 15 2010
    toronto, ontario
    N249 Mechannical Malfunction - Replaced DV / Wastegate Actuator
    So I've been having turbo problems with the car a for a little while. I was hearing a turbine sound when I would let off the gas and not reaching boost. Had a bunch of codes, including N249, boost pressure not reached, and cylinder misfires. Replaced the DV which didn't seem to help and the Wastegate Actuator which fixed the noise and boost leak, but still getting this one fault code. Not sure what this could be since the DV has just been replaced? Is it a solenoid the controls the DV? If so, where is it? What's the part? I always thought N249 is the DV but I don't know anymore.
    008801 - Boost Pressure Control Valve (N249)
    P2261 - 008 - Mechanical Malfunction - Intermittent
    2007 A4 2.0TQ - Debadged | APR Stage I | LED Interior | RNS-E 2010 Retrofit
    May 15 2010
    toronto, ontario
    Okay so I cleared the codes, drove around again, now that message hasn't (yet) reappeared but I'm getting a new one.
    012555 - Low Pressure Fuel regulation
    P310B - 002 - Fuel Pressure Outside Specification - Intermittent
    I can't see this having anything to do with the turbo, but I don't know anymore. Seems like everything is failing at once these days.
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    It doesn't, that could be a few things but depending if you have higher mileage, I would start with fuel filter first (cheapest) then pressure relief valve, then look at the low pressure fuel pump in the tank. Also if you haven't changed your cam follower ever look at that, the hpfp could be worn not providing enough pressure, my mothers car has the exact same code, we changed everything I just said (including hpfp) but not the prv as I didn't know the car had one, and come to find out after wasting 800$ on the big parts, it is the little 60$ one
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    May 15 2010
    toronto, ontario
    thanks! cam follower was changed a few years ago. will give the fuel filter a try.
    any idea what size the hoses are coming off the wastegate? broke the nipple from the old n75, the one coming off sideways, in the hose. $50 from the dealer??
    Oct 24 2015
    Perth, WA
    Ensure you have the fuel pump and related items including gauge coded correctly, I had the same issue and mine was coded for a quattro (CVT car), you may check.
    My respray thread
    Jul 25 2016
    new hampshire
    Quote Originally Posted by Okedokey View Post
    You referring to me?
    The prv's are known as a failure point so that's where I'm going next, I have one on the way so I'm gonna change it
    How do I check the coding? In vag-com?
    Eric
    Jul 25 2016
    new hampshire
    Quote Originally Posted by multiphrenic View Post
    No but if you bring the hose to autozone or anywhere that sells hose you can match it easily
    Eric
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by pezgoon View Post
    Yeah mate, the out of range codes were a result of my coding being incorrect.
    My respray thread
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    I have a turbo if you need it!
    Jul 25 2016
    new hampshire
    Hmmm what do you mean by the coding for it? What module did you need to change the coding under as there isn't a fuel specific one it is shared by the engine module
    Eric
    May 15 2010
    toronto, ontario
    bringing this back on topic for a second, the code is back:
    what else could it be if not the DV or Wastegate?
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    Are we talking about the prv on the hpfp or the prv thats under the intake manifold?
    Jul 25 2016
    new hampshire
    What? The valve that is on the hpfp is a regulator which I guess prv could stand for but if I'm not mistaken it's called a fuel pressure regulator, the prv (pressure relief valve) is the one under the intake manifold
    Eric
    Oct 24 2015
    Perth, WA
    Yes, the one on the HPFP is a Schroeder valve for diagnostics and pressure release, the PRV is on the fuel rail and is a different component.
    My respray thread
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    Where did you get the replacement Waste gate Actuator from? I want to rebuild my ko3 turbo and i think its a good idea to replace it seeing the car has high mileage.
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
    Senior Member Two Rings arankaspar1's Avatar
    Feb 20 2018
    Oakland CA
    Was it the coding or was it a part? What part if so? Or if coding, what control module sections should I check?
    Jan 07 2021
    2000 New Beetle, 2007 A4 Cabriolet, 2010 A3 S-Line
    California
    Quote Originally Posted by arankaspar1 View Post
    I wouldn’t hold your breath waiting for a reply as that member hasn’t been on the site since June of 2017…
    In the process of de-beatering a 2007 A4 Cabriolet
