Results 1 to 23 of 23
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    Continental SureContact RX Tires
    Has anyone purchased the Continental SureContact RX tires? They look like the DWS06, but they're only sold at TireMerchant & NTB Stores. They have a buy two get two free deal right now and I need to buy some new tires. My buddy is the store manager at my local NTB so he'll make sure the install is done correctly without damaging my wheels.
    It's $768 installed for four 255/45/20 tires, road hazard, alignment w/ 1 year unlimited mileage warranty, lifetime balancing & rotation, and free repairs if they pick up a nail or anything
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    That is a screaming good deal. I don't know much about these tires, but the reviews seem positive. Looks like you're conceding maximum grip and road feel for all-weather confidence and tread life. If those characteristics - along with budget - are your primary concerns, I can't imagine you'd find a better tire. Good luck.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Dec 08 2015
    Tulsa/OK/USA
    Give us your review once you get them on. Right now I'm running TOYO versado cuv on q5...love them.
    Mar 07 2004
    Charleston, W.V.
    I ordered them and they'll be in Friday. I'm taking the car in next Sunday to have them installed. The specs are the same as the DWS06 and the thread looks the same. The only difference is the DWS have "DWS" on the thread and these have some lines. I researched them online and most of the info I found is on a BMW forum, but the reviews are all good.
    My Q5 has Nitto Motivo's on it now and they last about 14k miles.
    Established Member Two Rings Probmxstyle's Avatar
    Dec 19 2015
    Quote Originally Posted by BarryT82 View Post
    Let me know how these tires work out, that is a hell of a price.
    Mar 07 2004
    Charleston, W.V.
    Will do. They're being installed Sunday morning.
    Oct 26 2015
    Norman/OK
    If they are anything like the DWS06 tires get them, I have the DWS06 on our SQ5 and I love them.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Two seemingly identical tires could have been made using the same mold, but most assuredly, their compounds will be different.
    How do their specs compare (UTQG, mileage, etc)?
    Mar 07 2004
    Charleston, W.V.
    Mar 07 2004
    Charleston, W.V.
    The tires are on and they ride great. They're go smooth on the highway and take turns well too. I'm going to increase the tire pressure a little bit to 38psi and they should handle even better. $768.51 out the door after tax for the tires, lifetime balancing and rotation, road hazard, 1 year unlimited mileage alignment, and free plugs if the tires pick up anything such as a nail..
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Price point is great for those, no doubt.
    Glad they handle well.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Mar 07 2004
    Charleston, W.V.
    I filled the tires to 38psi and they feel good in the turns. What psi is everyone running on their Q/SQ5 with 20" wheels?
    Senior Member Three Rings Tinpusher's Avatar
    Sep 27 2009
    Caledon, ON. Canada
    41 F&R like the sticker says.
    Mar 07 2004
    Charleston, W.V.
    The sticker on mine doesn't say 41 psi. I think it says 32. I'll have to check it tonight.
    Sep 27 2009
    Caledon, ON. Canada
    SQ5 is 41. Other Q5s may be different but 9psi seems like a lot of difference for the same wheel/tire combo.
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    You want to go by what's in your manual and not the sticker (which is max load) as your starting point.
    I think most people are running somewhere in between the SQ5 and Q5 recommendations. I'm at 36 psi now but am running a wider tire so have lower pressure requirements.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    i've been running 33-35psi on my 3.0T with the v-spoke 20" wheels. not sure why an SQ5 should run 8psi higher. in fact, the v-spokes are available as options in both the 3.0T (black optics) and the SQ5.
    hmm...maybe if i up the pressure to 35-38psi, i'll get better gas mileage? suggestions, anyone?
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Oct 26 2015
    Norman/OK
    I am running the 41f/40r as the tire pressure label says to run. I also watch the wear pattern on the tires and adjust from there, if I see the tire isn't wearing fully to the edge I will reduce the pressure by 1psi until I get a full even tire wear across the tire.
    Mar 26 2015
    New York, NY
    I'm fairly certain the difference in tire pressure recommendations is due to the top speed differences. The Q5 is limited to 130 mph and the SQ5 is 155 mph from the factory.
    Current
    Past
    Mar 07 2004
    Charleston, W.V.
    I've been told by a few people to run the psi at 80% of the tires max psi. That would be 41 psi (if I round it up). The dealership normally sets it at 34-35 psi. I called Audi customer service about the difference in the manual and they couldn't tell me why there was such a big difference for the same size tires on the Q5 and SQ5. Below 35 psi it doesn't take turns well.
    Jun 07 2013
    orange county, ca
    Quote Originally Posted by riceboy22 View Post
    so i assume there would be no safety issues with running the 3.0T tire pressure in the high-30s psi. i'm looking to get better gas mileage out of this thing. on trips b/w SF and LA, i top out at ~25mpg. i can do slightly better if i set cruise at 70mph, but no one drives at the speed limit, esp not on that stretch of the 5!
    Mar 26 2015
    New York, NY
    Quote Originally Posted by jomama229 View Post
    Yeah, as long as you're not exceeding the max inflation for the tire you should be good.
    See this table from Tire Rack on tire pressure adjustments based on vehicle top speed. There's probably some additional variables in play like HP that led Audi to their recommended pressures.
    AIR PRESSURE/LOAD ADJUSTMENT FOR HIGH SPEED DRIVING (Z-SPEED RATED TIRES)
    Current
    Past
    Nov 23 2009
    How are you liking the tires now? Has anyone else purchased the Surecontacts? I was recently going to purchase the Continental Purecontacts until I called Merchants Tire for a quote and they mentioned the same deal BarryT82 got - the only difference is my tire size is 245/45R-17. Since this tire is only available to certain retailers, there isn't as much information as your more popular tires, so curious to know how they are holding up over time. Thanks.
