Results 1 to 14 of 14
    Established Member Two Rings Roccorace's Avatar
    Nov 22 2015
    Minnesota
    Front Caliper 10 point Socket - Help
    I need to replace my front rotors and need to remove my calipers. There is a 10 point bolt that requires a special socket that I don't know where to get it. Anyone have a source?
    Mar 21 2015
    These might be what you are talking about
    https://www.amazon.com/Anytime-Tools.../dp/B000I45Y8Q
    Nov 22 2015
    Minnesota
    Unfortunately not. It is for this bolt, 10 point.
    Sent from my SM-N920V using Tapatalk
    2017 Audi RS7 | Daytona Grey Matte
    - Milltek Non-resonated Exhaust
    - Full LED Color-change Interior Lighting upgrade
    - ECS Flush Spacer Kit
    - OBDEleven modified | Lowered 10mm | VIM | Seatbelt Chime | Heater timers
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    Are you taking apart the calliper or just want to remove it from the carrier ?
    Nov 22 2015
    Minnesota
    Remove it. This is the 1LP front caliper.
    Nov 22 2015
    Minnesota
    I am replacing the rotors and pads.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    that is not the bolt to remove it
    there should be 2 19mm bolts that go into the back of the hub (go the same direction as the wheel bolts but towards the outside of the car)
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Nov 22 2015
    Minnesota
    Anyone have a pic?
    Mar 21 2015
    something similar to this?
    http://i.imgur.com/BbfmnCa.jpg
    Nov 22 2015
    Minnesota
    I had searched back there because the Audi maintenance manual shows the bolts entering from that direction. I can't seem to locate them.
    Nov 22 2015
    Minnesota
    That is a far different setup but I get where you are describing them to be.
    Mar 26 2010
    US
    Allegedly this is the bolt that removes the caliper: https://www.ecstuning.com/Audi-C7_S6...iper/ES472036/
    BMW M3 Competition X-drive
    Nov 24 2012
    Livingston, NJ
    Quote Originally Posted by Roccorace View Post
    https://www.aliexpress.com/item/10PT...b-7fe4b548832b
    This is what you need. I just replaced the brake pads on my S8 plus to dustless. The bolt the OP showed removes the bracket with the caliber from the hub. I have not tried that method. I received my socket in 7 days.
    2018 Bentley Bentayga
    2017 Porsche Panamera Turbo
    2016 Porsche Cayenne GTS
    2016 Mini Cooper S 4 door
    2015 Porsche 911 Turbo S
    2003 Audi RS6
    2016 Audi S8+ Sold
    2015 Mercedes S63 Sold
    2015 Range Rover Sport SVR Sold
    2014 Audi RS7 Suzuka Gray Sold
    Mar 26 2010
    US
    Quote Originally Posted by aottley View Post
    That link did not work for me, but this Amazon link does.
    And this one, $15.99: http://www.motors23.net/single-262579802915.html
