Monday: Drove it 6 hours, about 80mph. Nothing out of the normal. Went ahead and changed the oil the week of my trip.
Drove like normal on tuesday and wednesday.
Thursday: Was driving the car to my business spot in Charlotte NC, and the car misfired. going about 75 on the highway, just cruising. The CEL started flashing, so I limped it off the highway. The car was misfiring pretty dang badly. Turned the car off. shook my head, hoped it was a dream, and tried re starting. Still misfiring. I let it sit for 5-10 minutes. Tried to restart and it wouldnt start. Smelled like 93 octane. So, I decided to get it towed. Took it to a local shop that knew european cars, but couldnt get it to the dealer without a wait.
So: Here is what we did.
1) Scanned the car. tons of misfires on cylinder 4. It deactivated cylinder 4. misfires on other cylinders as well. Coilpacks, right?
2) replace coilpacks with genuine Audi, latest revision.
3) replace sparkplugs with new NGK BK6REs.
4) test drive: car would still sputter and wouldnt want to idle. Not fixed.
5) ran dry compression check: WHATTTTTT! 60,50,60,50psi on cylinders 1,2,3,4, respectively. This engine has 88k miles on it. I have changed oil religiously on it. Never overboosted, only APR stage 2 tune on it. Havent done any audi recall-type stg1/2 oil consumption repairs on it. FYI, I only use 1 qt per 3500-4000 miles.
6) looked at the cylinders with borescope. they looked like they were caked in carbon.
7) I decided to drive the car for a bit and see if something loosened up. It drove fine on the highway, but wouldnt idle well. I did some thinking, and decided to drive it home after the business trip with a bad idle. Made it 6 hours home just fine. I just wanted to get the car home in my garage.
8) did some research. Double checked compression in my garage. Still low. Decided that low compression could be one of a few things:
a) head gasket (it's all 4 cylinders, so unlikely)
b) rings (wouldn't I see a gradual decline? also, I only have 88k!)
c) valves (could have a crazy amount of carbon buildup or all bent valves?)
d) jump in timing (possible with these engines)
e)bad compression tester
So, I decided to go ahead and pull the intake manifold. The valves were NASTY. About 1/8" of carbon buildup on the walls of the intake. I have now cleaned up the intake valves/intake and am ready to reinstall the manifold. I have learned that carbon cleaning is no joke.
I have been doing some timing research recently and got scared that my timing tensioner had gone bad. I checked each cylinder with a borecsope. No evidence of piston vs valve. Whew.
So, before I start putting things back together, can you advise of anything else to check for if I'm getting approx 50psi across all cylinders? Any help would be greatly appreciated.
