Results 1 to 10 of 10
    Aug 22 2016
    Boston
    S5 19" wheels with 32 offset on A4 b8.5
    Hi,
    Looking to pick these S5 19" 5 double spoke wheels for my b8.5. I'm concerned on the offset. Anyone has these wheels on their b8.5? Any issues? Will they fit? Do I need spacers? Will I ruin/ add wear and tear to the bearing etc?
    19" x 8.5" 5x112 w/32 offset on 255/35/19 tires
    Nov 05 2009
    '09 B8 A4 2.0t quattro '15 Q5 3.0T
    Chicago, IL
    I have these on my B8, so I think my review is still relevant.
    They are perfect in every way. IMO, the most underrated wheels for the A4. Everyone's obsessed with the S5 rotors, but the double spoke S5's look just as, if not more amazing. I refinished mine in gloss anthracite and they seriously look dope (still has an OEM look to it, but the darker metal gives the curves and inflection point a lot more visual depth).
    No spacers needed. Sits very flush with the outer wheel wells. It is BORDERLINE outside.
    Basically it's perfect.
    Active Member Two Rings A4B8C16D32's Avatar
    Jun 01 2016
    Halifax, Nova Scotia, Canada
    I'm also running this exact setup on my B8. They sit flush with the outer fenders perfectly like gtg196w said, and they look great. Might be clearance issues if your car is lowered like 1.5 inches or more... but stock height they fit great
    2010 A4, 6-Speed Manual, Quattro
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by A4B8C16D32 View Post
    ^+3, if you lower it more than 1.5" , ask your alignment tech to give you -2.0 degrees of rear negative camber and you will be good to go.
    Stage 1 more than you RS3
    Aug 20 2016
    Taipei Taiwan & Walnut Cali
    The edge of the rim will protrude a little bit relative to the front fenders at the front end.
    But that also makes pretty much perfect for the back end where the wheel track is narrower than the front.
    For me the pefect set up is for B8.5 is:
    19 x 8.5 ET40 front (but very rare to find, most after market wheels are either ET35 or ET45)
    19 x 8.5 ET30 back (via custom-made wheels or use of wheel spacers)
    Picture of my B8.5 with 19 x 8.5 ET36 all around with no spacers
    Front end protrudes a tiny bit, rear end is recessed a tiny bit.
    Aug 22 2016
    Boston
    Thanks for the helpful feedback, guys! Can't wait to pick them up.
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Those wheels are less aggressive than the S5 19x9 et33 wheels I'm running. You'll be perfectly fine.
    Here's how the 19x8.5 et32 will sit:
    And here's the 19x9 et33:
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Active Member Two Rings imbeamer's Avatar
    Nov 03 2011
    2016 A6 3.0, 2008 GMC Yukon Denali XL (for the boat)
    OC Cali
    I have those on my 2011 A4 Avant and they look great. The one issue I am having now is the wheel gap is much more noticeable but like others have said have to watch the lowering as my shop said may be rubbing if I lower to much. Wish i could lower like 1/2 to 3/4 inch and think it would be great, but most kits are 1 inch or more.
    Nov 03 2011
    OC Cali
    Sorry not great photo
    2017 S3 Daytona Grey Pearl With Magma Red Seats
    Aug 22 2016
    Boston
    got the new wheels today!
