Results 1 to 10 of 10
    Oct 23 2013
    Troy,Mi
    Idle fuel pressure
    I have been chasing around misfires and lean/rich fuel trims on my car for the past year and have only recently got to attaching a fuel pressure gauge on the fuel supply line to the rail. The pressure reads around 63psi at idle with vacuum hose connected to the FPR and around 70psi with it disconnected. I have a 4 bar FPR, and was wondering if this points to an obvious problem and what that problem would be. I also have a walbro 450. Any help and imput is appreciated. Thanks.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    4bar = 58psi, so that should be your fuel pressure with the vacuum line disconnected from FPR.
    Assuming your idle vacuum is 20 in.Hg (9.8 psi), then with the vacuum line connected you should see ~48psi.
    My conclusion is you're seeing too high of fuel pressure. I'm no expert, but this tells me either your fuel pump is out-flowing the FPR, or your return line cannot flow enough (due to blockage, kink, or otherwise).
    2001 Corvette (C5) Z06
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Do you have your 450 wired to a relay and then battery? People tend to overrun the stock FPR when running a direct wired 450.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Yep same setup here, Walbro 450 4 bar fpr, 63psi on my inline fuel pressure gauge at idle.
    The pump simply flows too much for the stock fpr/return system at idle
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Had a similar issue recently. Found that my return lines had a kink in the tank. Fixed the kink and it only dropped it 4 psi from 67psi. My final fix was to buy an adjustable FPR to lower the pressure to OEM spec: 58/51 psi
    Oct 23 2013
    Troy,Mi
    The fuel pump is wired just like stock, and could this higher pressure cause misfires? And does the fuel pressure have to be within the 58/51 psi oem spec? Thanks
    Oct 27 2014
    Flag/Phx, AZ
    What are your fuel trims? What codes do you have? Who did the tuning? Mine runs fine at 63psi at idle and my fuel trims are within spec but I'm tuned for it.
    IG: CJ_s4
    Oct 23 2013
    Troy,Mi
    fuel trims are 0.6% and 0.4% idle, and 6.5% and 1.1% partials throttle, no codes at the moment, I am on a base file from daz
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by MCP View Post
    Getting your fuel pressure is not going to enrichen those trims. However, the misfires are suspect. I would look at ignition.
    Oct 23 2013
    Troy,Mi
    Ill give it another look, on another note, does anybody know if the n75 from the 1.8t (audi,passat ect) is interchangeable with the 2.7t?
