Results 1 to 16 of 16
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Considering a S3 (Currently have V8 S5)
    Looking for general impressions of the S3. I currently own a 2010 S5 that I absolutely love, but I'm thinking it may be time for something slightly newer with 4 doors that I can play with. My S5 has just about every bolt-on that money can buy and I suppose I'm starting to investigate fresh canvasses to work with. The NA V8 is tough to squeeze extra power out of so I really do like the idea that the S3 is turbocharged and can yield more power with a simple tune.
    Anything that I should keep in mind with this model? It would be my daily driver.
    What are some "must do" mods? I wouldn't expect to get crazy with it, but I would certainly consider anything that improves handling ability and power output.
    Key maintenance items to consider? Any pain points?
    Thanks!!
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    My biggest issue is a relative lack of interior storage space in the S3.
    Sent from my Nexus 6 using Tapatalk
    Senior Member Two Rings MkUrMark's Avatar
    Aug 09 2015
    Southern Cali
    I agree with the above statement. You'll miss out on that V8 sound, there's no replacing that, even with an exhaust system. Other than that S3 is amazing car
    2016 S3
    12' Golf R:. Stg 1+sold
    10' Gti sold
    06 A4 sold
    Veteran Member Three Rings audinator's Avatar
    Nov 17 2005
    B9S4, 91 CRX, 85 CRX, 17 Thundra
    SoCali
    I now have a 2016 S3, I have had B8 S4's and S5's with the 3.0T, I also had an RS5 briefly. I like torque. I found the RS5 to be a dog down low, but it was built to be a high HP NA car so if that's what you're into it's great. I like torque down low, mostly city driving. In the RS5 by the time I really got into power I was doing 80. So after that I actually went back to an S4 3.0T. At first I was not a fan of the S3, mainly because I soooooo used to my S4, but then it kinda grew on me and now I truly love it. It's like a belt sander. Light and quick. I can have fun in the canyons because it's light and torquey. I plan to do a few simple mods but the car is a blast so far (700 miles). I am really looking forward to more miles!!
    You may miss the sound of the V8 for sure, but you will trade for agility and quick torque down low. I love 4 doors and the overall size of the S3 is great. I also still own my B5 A4 1.8Tq.
    2018 B9 S4 Daytona Gray | Rotor Gray
    . . . and many other Audi's over the years . . .
    Nov 15 2009
    Aurora, IL
    I'm also considering the S3, but the dealer also as a 2014 S5 3.0T for a similar price. Does the S5 3.0T respond to a simple tune as well as the S3 does?
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by auburnjosh View Post
    I thought the S5 that year was supercharged, not turbocharged? There are some gains, but not nearly as much as a turbo.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Nov 15 2009
    Aurora, IL
    Quote Originally Posted by Baggio View Post
    You're right....I misread it....It says 3.0L TSFI. Well that makes getting the S3 decision easier!
    Jul 13 2016
    Portsmouth, NH
    I was looking at S3's and ended up going with a 2014 S5. It has a little higher trim level inside and I personally like the looks of the S5 better. I am also a tall guy and didn't fit very well/comfortably in the S3. The better AWD system was another selling point for me too.
    And the engine badge is also referred to as 3.0T, which is basically just forced induction.
    Feb 13 2015
    VA
    3.0T definitely has a different feel than the S3, driving them back to back often makes the lag of the S3 stand out more but it's really a nonissue with DSG. Tune the S3 and you'll never look back.
    2015 S3 - Revo Tuned
    2016 SQ5
    2008 F350 - Pistons/Cam/Studded/Deleted/Single Turbo
    2010 GT500 - Twin Turbo
    Sep 14 2006
    I love my S3! It handles great and can easily make power. Sub 4 second 0-60's (I've seen as low as 3.5-3.7 on several stage 2's) and low 12 or high 11sec quarter miles with a stage 2. On top of that, you get easily get 27+ mpg's. Also, I'm 6'0 and I found it to have plenty of room.
    Honestly, the only thing I don't like about this platform is the way the doors open lol. When I park in close proximity to other cars, there is no "center" position so the door won't open wide enough, or it will swing open too far if that makes any sense. If you're not careful and you risk hitting the car next to you.
    I've always thought the S5's were beautiful looking cars and if you're also considering the 3.0T motor, they're great. In the end, a stg 2 S3 is a great little car that can keep up with or surpass cars that cost 1.5-2 x's as much.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Established Member Two Rings SimpsonTide985's Avatar
    Aug 03 2013
    Iowa
    This should give you all of my thoughts on the S3:
    http://www.audizine.com/forum/showth...After-One-Week
    Sep 06 2014
    Rochester, NY
    Thanks for the responses guys!
    I stopped by the dealer this afternoon and sat in one in the showroom. Definitely a difference in the interior coming from the S5. It was certainly appealing, however did not seem quite as sleek/refined as what I have now. Mines a prestige - Not sure which trim level this S3 was.
    Didn't get a chance to drive it unfortunately but I was offered to drive an A3. It definitely exceeded my expectations however I definitely preferred my S5 without any doubt. Hopefully I'll have a chance to actually drive the S3 in the next few weeks so I can get a better comparison.
    A stage 2 S5 with the 3.0T will run low 12s to high 11s. The tune and supercharger pulley will give it an extra ~100hp at all 4 wheels.
    IG: @SLU_S5
    Dec 06 2015
    Columbia, South Carolina
    Do not get 2016 model. Get the new 2017 S3 prestige + black optic package. Price went down $1000 compare to my 2016 configuration.
    Also, you get better design steering wheel and the new virtual cockpit and apple car play??
    Dec 06 2015
    Also, save money by getting 2017 S3 prestige + black optic vs S4 or S5. You dont get the new virtual cockpit on those models and they still more expensive than 2017 S3. with that money saving, you can put Stage3+ on S3. Also, think about performance parts cost. S3 parts are shared with VW golf R so, there is so much demand which means parts are way cheaper than S4 or S5 parts..
    Also, when you buy used parts, there so much chaper on S3.
    Veteran Member Three Rings bkkchris's Avatar
    Dec 05 2006
    Los Angeles & Bangkok
    Quote Originally Posted by SLU_S5 View Post
    Completely agree. I'm considering a 17 S3 in the next few month to replace my 14 S5 coming off lease. The S3 is super fun and a great platform for mods. But other than the new tech in the 17, the interior is pretty spartan even compared to the pretty old interior on the b8/8.5 A/S4/5s... only concern for me really... otherwise a fantastic car!
    2018 RS5 COUPE // SONOMA GREEN
    - Gone -
    2017 TT Mythos
    2017 Macan GTS Rhodium
    2014 S5 Monsoon
    2013 S4 Phantom
    2012 S4 Monsoon
    2008 S4 Dolphin
    2006 S4 Moonlight
    2004 A4 Dolphin
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I love my '16 S3 Prestige package with the 19" performance package. I agree that interior storage is limited, but the car is small. I am only 5'5" tall so the car fits me perfectly. However a 6 plus footer may be cramped. The car runs terrific and handles very well. I think the interior is well appointed and if Audi had offered the memory seats and HomeLink, the car would have been prefect. I had the dealer add the HomeLink, but I had to get over the memory seats - oh well, that was the one concession. I have 9K miles on it now.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
