Results 1 to 11 of 11
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    Are we supposed to lube the electronic parking brake at some point?
    When I engage the electronic parking break it makes a little squeal. Works fine but I assume it may need a little "lube" action. Almost sounds like if you stepped on baby kittens tail lol.
    I wonder if this is this is something I can accomplish myself. I'm coming up on 80k on my 2010 S5. I'd like to go over the door hinges, sunroof rails etc with some of the one grease.
    Aug 30 2013
    KY
    It uses the same rear calipers and pads. Do you get noise when regularly using brakes? Mine makes a noise when EPB is engaged and released as the piston electronically presses in on the pads.
    There are some spots that use grease where the pads slip back and forth.
    SLOWER TRAFFIC KEEP RIGHT
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    I've noticed that squeal recently too. Curious if it needs a line lol
    Sent from
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    May 20 2015
    PA
    Quote Originally Posted by DreDay View Post
    Sent from
    Thankfully only when engaged and released. I probably wash my wheels to often and I have dried up the damn line grease back there with adams AP cleaner lol. It has always made a noise, i just feel its louder than normal. I notice it a lot lets say if i am parked and my door is open and i engage it.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    It's a sealed unit so you're washing technique must be pretty thorough if you've cleaned the grease out, might just be the pads that need a little copper grease on the slides?
    If you have VCDS you can fully open and close the rear pistons, do that a couple of times to see if it clears the noise. I would recommend having the battery connected to a charger if you are going to do it though.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Drop a vid clip of the noise so we can hear it.....this all sounds normal to me right now......
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    May 20 2015
    PA
    Here's it from the outside. I can't really hear it when the doors are closed while inside.
    Feb 27 2014
    Dubai
    Mine has always made a similar noise to that, as does my wife's Touareg.
    Apr 25 2010
    Morris County, NJ
    Yup that's the noise mine makes. I never heard it until recently.::
    Sent from
    Senior Member Two Rings rmbrown09's Avatar
    Sep 27 2014
    United States
    Only part of the car I lube is the tailpipe.
    Feb 27 2014
    Dubai
    Quote Originally Posted by rmbrown09 View Post
    Makes it sound faster?
