Page 1 of 3 123 LastLast
Results 1 to 40 of 93
    Senior Member Two Rings Jeremyboukaia's Avatar
    Aug 20 2016
    Elpaso
    2001 audi a8l 6 speed swap
    I am new and this is my first major build.
    Aug 20 2016
    Elpaso
    Here is the car and all its glory
    Pulled the (huge) zf 5hp24a
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Looks like a good base to start with! Interested in this build for sure.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Aug 20 2016
    Elpaso
    hp2 rebuild:)cleaned and ready for paintnow to rebuild with new bushings and sealslooks awsome photos speak more then words:)!
    Jul 10 2012
    buffalo
    what did you do for your clutch pedal? is that a custom job or did you source the euro assembly
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Aug 20 2016
    Elpaso
    so I was at the junkyard yesterday looking for a metal clutch master cylinder so I can make a custom line to my slave cylinder. Checked every audi or vw with no luck. But saw this saab! It was a manual:)! Score looked at the master cylinder and wow it's will work with some custom fabing.
    Aug 20 2016
    Elpaso
    Quote Originally Posted by somedude View Post
    Somedude. I bought another brake pedal for the a8 and it fits on the clutch side I just had to cut it to size. But it fits works great. I am still building the pedals but I should have the clutch working vary soon.! Ps the master cylinder from the Saab. Has a internal spring an a small return spring. So it's will be cake. Let me know if you need a better photo of something.
    Also make sure your car ecu is a me7.1.1 this ecu has the manual file in it already. Just need it coded.
    Aug 20 2016
    Elpaso
    So got some work done yesterday but not nearly enough. A buddy came over with his 05 w12 with a blown air strut. I replaced it with his coolest expansion tank it fixed his problem. The leak was coming out of the top of the strut were the sensor came out.
    Aug 20 2016
    Elpaso
    Here is what little progress I made to the clutch pedal. so to day I will build the bracket and drill the holes. Going to lowes to grab a hole saw in the size I need.
    Mar 17 2014
    Los Angeles, CA
    This is a pretty extensive project. Looks like it is coming along nicely.
    instagram
    Aug 20 2016
    Elpaso
    So far it's been easy
    Aug 20 2016
    Elpaso
    Ok so don't do drill the hole for the master cylinder there!! It needs to be bottom left to clear the brake booster:( no I will have to make a reinforcement mounting plate for it:( but that's not hard just more time
    Aug 20 2016
    Elpaso
    ok so the hard part is done. I will make a dead bolt so the pedal won't wear out the master cylinder. I have a return spring that I still have to fab.
    Established Member Two Rings DirtyVegasTT's Avatar
    Apr 29 2009
    Vegas
    Wow. For those of us that mainly just do boltons, this is pretty amazing!
    2013 A8L 4.0T
    APR | 22x10.5 Vossen VFS1 | 285/30/22
    Gone - But Not Forgotten
    2007 S6 V10
    APR | Miltek Catback | MSDS Filters | RS6 Grill | LLTek Spoiler | H&R Sport Srpings | 20x9 Hartmann B7 HRS4 | 265/30/20 BFG G-Force
    Mustang Dyno: 342 AWHP, 338 AWTQ - Back then it was pretty good for N/A Audi
    Aug 20 2016
    Elpaso
    Clutch pedal is completed:)
    Aug 20 2016
    Elpaso
    Aug 20 2016
    Elpaso
    Just sent out my ecu today to get coded for the 6 speed:) I'll have it back in a week. Early next week I'll send out my axle and drive shaft to get extended. Drive shaft needs to be extended 4 1/2 inches and the axel needs to be 26 3/4 inches long. I measured from end of the splines in side the hub to the flange on the transmission. I have all road axels to they can extend and shorten more then normal axels. Due to the fact that allroad has adjustable ride hight.
    Aug 20 2016
    Elpaso
    So I've been buisy with little time to work on the car but today I had some time to build the new down pipe mounts. And finished the clutch line. they will do the job:)
    Aug 20 2016
    Elpaso
    Update. Car is almost back together, engine covers and air box all put back and wiped down. Kinda disappointed as the elbow from the air box to air pipe has a huge hole from previous owner over tightening the clamp:( so I need a new elbow. Also the smaller hose from air box to I think sai pipe is internally coming apart.
    Aug 20 2016
    Elpaso
    Also my right head light sprayer is leaking and my cross oil vent hose is torn (engine hoised did it so mad! )
    Mar 17 2014
    Los Angeles, CA
    Dang, sorry to hear that man! Hopefully you have those items fixed soon.
    instagram
    Jul 10 2012
    buffalo
    keep posting info. I am so on the fence on what to do with my a8 track car. the lifter tick stopped after running the snot out of it so now I am back to wanting to swap it to 6 speed.
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Aug 20 2016
    Elpaso
    So I would do the swap but I would only buy the transmission only and not the full swap kit off of eBay. The only thing I used was the transmission the rear end and one axle so all the other stuff I wasted money on:( if you have any questions on this swap I can help you out. Its was easy for me but lots of work. I probably pulled the transmission out 5 times. I am finished with the car but waiting on a shop to do my wiring! I can do it but I would rather have the comfort of everything being right so I can drive my family around safely.
    Aug 20 2016
    Elpaso
    Aug 20 2016
    Elpaso
    Fixed all my head rest they all go up and down now:) there is a good you tube vid that explains everything. I also am thinking about fixing my wheels they all have curb rash from the owner before me.
    Aug 20 2016
    Elpaso
    Mods that are still to come. St coils and spacers for that lowered look:) and full stainless steel exhaust.
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    Absolutely beautiful car and amazing work you have done!
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Aug 20 2016
    Elpaso
    Quote Originally Posted by RRF985 View Post
    Thanks brother :)
    Mar 17 2014
    Los Angeles, CA
    Wow, that swap came out great! Looks like it came like that from the factory.
    instagram
    Aug 20 2016
    Elpaso
    Quote Originally Posted by jmeenach View Post
    Thanks buddy
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Nice work, you made some fast progress! If the A8L I am looking at pulls though, I'll be looking into the same thing.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Aug 20 2016
    Elpaso
    ok so I noticed my shift boot wasn't holding the way I did it the first time. So on to a new boot clamp that will get pop rivets and the bottom plate will get welded to the shifter mount. Let's hope this idea works lol
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Where in Texas are you? I am near fort worth and have 2 d2s. Both 2001 a s8 and a8l
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Aug 20 2016
    Elpaso
    Quote Originally Posted by audinutt View Post
    Elpaso tx
    Aug 20 2016
    Elpaso
    ok I got some time it's now fixed
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    Just picked up my D2 A few months ago, feel like I might be going down this path eventually.
    Thanks for documenting, have a few questions for you however.
    1.
    Any reason why you didnt just use an OEM Master?
    That way you wouldnt have to cut through the firewall plate - Just two holes for fluid lines.
    https://jhmotorsports.com/shop/catal...ad-p-2217.html
    2. What clutch did you use? 4.2 RS4 (07)?
    2 1/2. did you use a spacer plate for the trans?
    3. Any reason why a a4 a6 shifter box wouldn't fit in the center console?
    4. I read in another thread that the S8 Rear Differential for Auto trans is the Same Ratio as the 01E. Can you confirm?
    5. The 01E I have came from a 2001 S4. - What are the chances the mount brackets are correct.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Active Member Two Rings Y888's Avatar
    Jun 24 2015
    2002 S8///2014 Lincoln MKS
    Chicago
    How many hours of labor is needed to complete the swap?
    I would like to do it but i would have to hire somebody to do it.
    2002 S8
    Aug 20 2016
    Elpaso
    Quote Originally Posted by iamshayan View Post
    1.
    The a4 a6 shifter box wouldn't fit. But I am sure a earlier one would. I got everything out of a 2.7t all road. I used the clutch that came with the trans. I am still wiring the car been super busy. I do not know about the s8 rear end gear. My car is a A8l so I just used the rear that matched the tranny I got. I used the spacer plate it bolts up but I had to notch the spacer plate for the lower starter bolt. I used the master out of the sabb because I was at the junk yard and found it for 10$. It was easy. The a6 pedal assembly won't fit at all. It was just way easier to buy a brake pedal and slide it onto the pedal mount. It's already set up for a clutch pedal. I can not comment on any fitment of any other car parts. I just made what I had work. The s4 mounts might bolt up I don't know though. I hope this helps. Once you start it was easy
    Aug 20 2016
    Elpaso
    Just rebuilt my hp2 big brake setup on my A4 b6 avant new head old one was miss firing.
    Aug 20 2016
    Elpaso
    Will be installing these and st coils on the a8 vary soon.
    Brembo z17 from a vw SUV rebuilt (by me)
