Results 1 to 6 of 6
    Sep 19 2016
    Finland
    IMMO3 -issues and solutions
    Long story short, while replacing the 24 LEDs in my instrument cluster, I accidentally turned on the IMMO3 -system. (The LEDs are nice, but car won't start..)
    1. One solution would be to fix the reason for the activated immo -system
    a) For instance, by using VCDS + the secret 5-digit pin code and recode all keys. The problem is this doesn't work for me, even when following key recoding procedures (for Immobilizer integrated in Instrument Cluster: Instruments, Login (0+4-digit pin), Adaptation (Channel 21, enter new nr of keys, save, return, exit. Repeat for all keys within 60 sec.
    b) Another could be to use the faults reported by VCDS to identify the potential reasons, such as 17978- Engine Start Blocked by Immobiliser, P1570- 35-00; 01128 - Immobilizer Pickup Coil (D2) 35-10 Intermittent, or 01176- Key 07-00 - Signal to Low. For instance, key battery replacement and Green+Blue+Grey cable check connectors, testing the pickup coil, and checking battery at least 12.5 V during programming.
    2. Using an Emergency Engine Start Procedure for Audi/VW.
    a) Ex. Insert key into the ignition and turn the switch to "Run". Twist the knob for the Clock in the clockwise direction + press reset button for the Trip Odometer Counter. The Odometer counter should have all zero's and the first zero should be blinking. To set the first number, press the reset button for the trip odometer until the first number of your Secret Code appears.
    Doesn't seem to work on my mode. As far as I know the Emergency starts does not work on all models (immo3 and newer).
    b) Using a hack, such as disconnecting the battery, leaving the key in the run position for 10 minutes, etc. Again, didn't work for me.
    3. Disabling / deactivating the IMMO -system
    Pulling out the Engine ECU EEPROM and locating the chip tagged 95040 (or similar) and desoldering the 8-pin chip.
    a) With special equipment reading the 8-pin chip bin-file, making hex edits, reflashing the bin file in boot mode, and desoldering the chip.
    b) Sending the chip to a tuning services pay a fee, and desoldering the chip.
    4. Using a sw tool to read and reprogram (disable) the IMMO-chip via the OBD-II connector
    NefMoto?
    5. Buying a used instrument cluster and swapping it
    Presuming the error that triggers the IMMO is in the cluster. Ross-tech has good procedures for this.
    Any other solutions?
    Which would be the easiest / quickest or recommended?
    Senior Member Two Rings frankwizzle's Avatar
    Oct 08 2008
    Derby City
    Not sure if you're APB or BEL but there's some good info here.
    http://nefariousmotorsports.com/foru...p?topic=2973.0
    If it were me I'd just disable it. Just need to 00 or FF one byte location.
    Sent from my Nexus 5 using Tapatalk
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    how hard was it to change all the lights?
    Sep 19 2016
    Finland
    Yeah, but how. I can't write to the 95040 chip, which to my knowledge contains the immo.
    Sep 19 2016
    Finland
    Quote Originally Posted by Terry.Reese View Post
    All in all a few hrs. After you have picked apart the instrument panel, there are 24 SME white LEDs that you need to desolder. You also need to check the polarity of LEDs before desoldering. If I remember right, 6 of the LEDs in total had to be reversed (upside down) from the rest. You can check the polarity with a multimeter prior to desoldering, since each LED lights up when you put the multimeter on it and have the right polarity.
    It's somewhat tricky to desolder and solder the new one's in place because of the small size of the LEDs and you have to be careful not to overheat the pads on the circuit board. I recommend that you use a magnifying glass with lamp. And watch out with the amount of solder you use, since it easily flows over to a nearby component.
    With the above caveats, it's a fairly easy job.
    Oct 08 2008
    Derby City
    Quote Originally Posted by simonitz View Post
    Take this file and write to your eeprom with ArgDub's tool
