Results 1 to 4 of 4
    Senior Member Two Rings audi silver's Avatar
    Feb 09 2010
    Florida
    Help with stripped bleeder screw!!!
    Anyone know what diameter repair kit to get for brembo bleeders? I have the b7 rs4 calipers and can't find specs for bleeder size. Repair kits have 1/4, 5/16, and 3/8 size. TIA!!
    https://www.ecstuning.com/Audi-B7_RS...iper/ES427848/
    Bleeder screws for reference
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    Quote Originally Posted by audi silver View Post
    I assume that you're just asking for the thread type of the bleeders, so I took a quick look at Speed Bleeders at http://speedbleeder.com/automobile_applications.htm and scrolling down to the Audi section, it looks like most of them use SB1010 or SB1010S, and http://speedbleeder.com/size.htm shows that as being M10 (10mm) x 1mm thread pitch. Are the threads on the bleeders messed up, or the threads in the calipers? Anyway, to me, it looks like the thread is probably M10 x 1.0mm. - Jim
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Not sure on the b7 ones, but my 17z are def m10 x 1mm. I used old fw bolts to plug the holes when I painted them.
    Wouldnt surprise me if Brembo uses it on most (maybe all) of them.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Feb 09 2010
    Florida
    Threads on the calipers, thanks for the info. M10 is about 7/16. I'm just going to have machine shop drill and tap them to use a repair kit.
