Results 1 to 8 of 8
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Front Lower Control Arm Ball Joint Not Coming Out of Spindle
    I think I tried everything except a proper Ball Joint Separator (my Gearwrench model doesn't seat in the spindle / ball joint area fully)
    I did try using the ball joint separator pickle-fork which did no good.
    I tried Direct Shock to the Spindle, also tried hitting the threaded portion of the ball joint (forgot to add nut to prevent damage to threads); did damage to a couple of threads and used an angle grinder to cut out of the defective threads.
    Also tried OTC 2-Jaw Puller, which slipped as it couldn't grip the spindle fully.
    I feel like I'm out of options here, and was very close to completing the Driver Side today.
    What are the next steps I should take? Should I try a larger ball joint separator (purchase from Harbor Freight)?
    Btw, sorry for the multiple threads on my suspension; just felt that each dilemma I came across deserved its own thread.
    I even searched for other solutions (such as http://www.audizine.com/forum/showth...ed-like-a-mofo ) but no further solution available.
    I just now sprayed the area with PB Blaster (liberally).
    Aluminum uprights, not steel-type.
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    https://youtu.be/L-0cvMxherU
    This is what I have and works like a charm - search Amazon for Astro 78807 5-Piece Pickle Fork Ball Joint Separator Set
    Sometimes I load the suspension (jack it up) to release some of the stress off the ball joint.
    Sent from my Nexus 5 using Tapatalk
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, I've watched the Bentley Publishers video too many times now, lol. Unfortunately, doesn't address Northeast Winter Months.
    I already removed the front lower control arm bolt from the subframe-side. It's the spindle-portion that's troubling me. I think I'll have to get the appropriately-sized ball joint separator (scissor-type) from Harbor Freight. The Gearwrench scissor-type Ball Joint Separator barely fits over the spindle and balljoint threads.
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    pry bar, a decent sized one, and man handle it out
    end of story
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by arjun90 View Post
    I have used this one from HF for several years and it works like a charm, every time ...
    http://www.harborfreight.com/3-4-qua...tor-99849.html
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, I'm on my way to Harbor Freight, hopefully this larger size should work.
    Quote Originally Posted by 02 A6 2.7T View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    You'll need to grind the throat of that tool out larger. The taper on all of our ball joints is too large to fit. I've used my modifed one many times and it holds up fine. Do not use an impact on the tool, it will strip the threads.
    Since you have aluminum uprights, you'll want to be mindful of the steel inserts that may press out of the upright with the ball joint. These have to be reinstalled.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, I just returned and used the ball joint separator from Harbor Freight and Voila, the Ball Joint successfully popped out. I didn't have to adjust the position of the separator much (probably due to the fact that I shaved off the first couple of threads from the ball joint with an angle grinder). At first I thought I damaged the tool (kept looking away as I was turning the ratchet)--but a closer inspection revealed the positive news. Used Deep Creep (Seaform) and PB Blaster in conjunction. I can now return the OTC Ball Joint Separator (which I also ordered yesterday). Won't really need the Astro Pneumatic Pickle-forks as well. I was very close to buying the entire OTC Front Service Kit (very good price, but not really needed for project enthusiasts working on one car).
    Let me just that that Deep Creep is certainly worth the extra cost. I believe it contains Kroil and really penetrates the rust in areas which PB Blaster does not reach.
    Current:
    70,xxx Miles
    182,xxx Miles
