Results 1 to 7 of 7
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Code 1134, Alarm Horn (H12) fault
    Hi guys,
    Trying to clear all the misc codes on my B6 S4. The alarm horn doesnt work per the 1134 code. I've read that the car has a battery back-up unit installed in the truck rear right side, with the actual horn possibly in the front right wheel well?
    Can anyone confirm this. Thanks
    Nov 03 2014
    2009 Gray A3
    California
    Bump
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    I know my B6 has a battery mounted under the sub box in the well behind the passenger rear wheel. It is bolted to the seam where the well is welded to the floor pan. Sedans have it in the same spot as far as in know.
    Apr 08 2008
    New Westminster BC
    Correction, it's the horn with battery box attached. The horn actually "firing" out through the HVAC vent at the back of the well.
    There is aperantly a problem getting the odd size batteries Audi used and I've added a how to I found to modify for different batteries, it shows the unit and location.
    Nov 03 2014
    2009 Gray A3
    California
    Thanks guys. Found the unit in the rear right of the car after removing the liner.
    Sent from my SM-G920F using Tapatalk
    Nov 03 2014
    2009 Gray A3
    California
    After cutting open the sounder found this mess. Will have to get the circuit board checked out before looking for batteries.
    Nov 03 2014
    2009 Gray A3
    California
    http://www.maplin.co.uk/cart
    Found the batteries here. I presume they are the correct ones
