Results 1 to 7 of 7
Thread: A8 vs S8 ?
    Aug 07 2012
    France
    A8 vs S8 ?
    Hello guys,
    For the past couple of days i can not sleep well... constantly looking, reading and searching forums for some kind of answer.
    Could someone please explain to me. What are the major differences between a d4 s8 and a 4.0t a8 ??
    I am looking to get a 2012/13 model with up to 50k miles... but don't know if it's worth overpaying 20% for the " S " sticker? Is this the case ? Or the S8 is a must buy over a a8 4.0t ?
    Thank you very very much !!
    Registered User Two Rings
    Apr 26 2016
    Houston, TX
    Hi, the S8 has a more robust 4.0T. It has a bigger crank, bigger turbos, better cooling, bigger brakes. The aftermarket tuning for the S8 will also produce very large gains. The S8 can run in the 10 second range when properly equipped pretty easily. I hope this helps with your decision.
    Apr 12 2010
    Iowa
    The A8 is also available in the long wheel base, whereas the S8 is not. The S8 is a total hot rod.
    Feb 09 2016
    Houston
    You would buy the S8 for more but you would end up selling it for more as well. I chose the S8 because the A8, even in the 11 second quarter mile range when modded, was not going to be enough.
    The long wheelbase option is one of the biggest differences. You can get your A8 in stretched limo form, but not the S8. When I was looking the only A8s I could find were the LWB versions.
    Also, I'm not sure the 2012 A8s have the 4.0T motor.
    Aug 07 2012
    France
    I somehow can't find the correct information about the s8 engine. Is it the same, as the rs6 ?
    They also share the same transmission as well, right ?
    Veteran Member Four Rings ThewhippetsS5's Avatar
    Jul 12 2013
    MD & HI
    Quote Originally Posted by Chris Morales View Post
    Correct, our 2012 has the 4.2 V8 motor
    Quote Originally Posted by dimSlip View Post
    That I don't know the answer to. I believe the S8 is slightly detuned from the RS6, but I could be wrong. I also want to say that they do share the same trans but I also could be wrong about that
    Sent from my Galaxy S6 Edge using Tapatalk
    - Jeremy | Instagram: Oahu.Homes
    2012 Audi R8 GT
    2016 Audi RS7
    2015 BMW X5M
    Jul 10 2012
    buffalo
    they have different transmissions as well
    https://en.wikipedia.org/wiki/ZF_8HP_transmission
    the a8 has a ZF 8hp55
    the s8 has a ZF 8hp90
    the ...90 has a higher rated capacity for greater power handling.
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
