Results 1 to 14 of 14
    Sep 11 2016
    CA
    Does fuel grade matter?
    I am a new Q5 3.0 owner. Does it really matter is I use 91 vs 89 octane fuel in my Q5?
    Oct 26 2015
    Norman/OK
    I would run what the owners manual or inside of the fuel door says to run if it was me.
    Junior Member One Ring 711wildcat's Avatar
    Apr 20 2016
    1967 Porsche 912, 2005 BMW R1200GS, 2015 Audi Q5 TDI Prestige
    Tucson, AZ
    Short answer, IMO, yes. I wouldn't compromise performance and overall fuel economy for about $0.15/gal...but that's just me.
    2013 S4 - Misano Pearl Red | DSG | CF inlays | Alcantara | B&O | Sports Diff
    2015 Q5 TDI - Glacier White Metallic | Beige Leather | B&O | Other Stuff my Wife Doesn't Use
    Established Member Two Rings goblues38's Avatar
    Aug 14 2016
    STL
    short answer = no fuel grade does not matter
    long answer = it is complicated
    any "modern" car can run on any fuel at any pump. 87-94 octane. The car monitors each spark and constantly adjust timing for the most power and exhaust cleanliness.
    So, if you use cheap fuel, the car will sense knock and retard timing to stop the knock. Knock or predetonation is what harms a motor. but when you have to retard timing you lose power. suddenly your 300 hp motor is only putting out 260 hp. The loss of power can cause the motor to have to rev hiring to make up for it. So saving .30 cents a gallon on 87 versus 93 octane may end up costing you more money in lost fuel economy.
    Also, many gas companies put more / better additives in the high octane fuel that will keep you motor cleaner on the inside.
    all that being said. Here is what I do.
    I always put 93 octane in my cars unless I am on super ling road trips that will run out a tank of gas in one stint. Like when I drive from STL to Orlando. 1000 miles on the highway @ 75mph means I need no extra performance and just need the car to loaf along. The gas with no additives will not have a chance to sit around because the motor will constantly be hot and moving deposits out.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by j4sharks View Post
    a premium car deserves premium fuel....
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Quote Originally Posted by q5 dave View Post
    100%
    If you can't afford the extra change to use 93 instead of 89/91 then maybe you shouldn't have bought an Q5 with a SC engine.
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Aug 14 2016
    STL
    Quote Originally Posted by bmoreS4 View Post
    100%
    that is a little harsh. And not 100% accurate. As I said above, there are a few times when 87 octane is the correct choice for the application. Most cases it is not though.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by goblues38 View Post
    What does it say inside the fuel door and owners manual? "Premium fuel only"
    California already has bad fuel, not sure why one would want to put in anything but the best available. Also it would only save $4 or $5 per fill up...
    Sep 11 2016
    CA
    OK, I can see we have borderline personalities on this board! It's not a matter of being cheap. There is a lot of scientific literature suggestive of the fact that there is no genuine value in the higher octane fuels given how they are formulated and how modern engines operate. In other words, suggestive that it's a lot of oil company "hype." Just curious what the experience of Audi Q5 owners has been.
    Apr 27 2011
    MD
    Next study....
    Synthetic oil no better then regular oil.
    I'll stick to the premium Audi calls for.
    IG: @s4dad
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Next study....
    That is not even a close comparison. I agree that there is no need for premium especially when the situation doesn't call for it.
    May 21 2010
    higher octane isnt "better"...it has higher octane. If owners manual calls for 91 then 93 is a waste of money as performance will not change. As mentioned earlier, using lower octane will change performance but only marginally. Like others have said, go with what manual says. I believe when they say Premium they mean 91?
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    I want to maximize performance and efficiency in my Audi's so I only use top tier fuel, most often Shell v-power (93 octane).
    Quote Originally Posted by Audi USA
    As an Audi owner, you appreciate the exceptional performance of
    one of the world’s finest automobiles. One way to help maintain that
    performance is to use only an Audi approved gasoline. By fueling with
    gasoline from a TOP TIER retailer, you help to ensure that your Audi
    will deliver all the performance it was designed to provide.
    Lower quality fuels can build up deposits in your engine, which may
    degrade engine performance and vehicle emissions.
    https://www.audiusa.com/content/dam/...l-Brochure.pdf
    sure, you can put in cheap fuel. but it DOES matter.
    Jun 12 2015
    CA
    If you get your Q5 tuned, and want to drive it spiritedly, then it absolutely matters.
    2015 Q5 3.0T | EPL E85 | APR SC pulley | KI 194mm crank pulley | CTS Turbo intake | AMS Alpha cooler | EC headers | Milltek valvesonic exhaust | KW V3 coilovers | 034 X-brace | 034 Trans mounts | 034 Rear sway bar | 034 ACAs | Girodisc LW front rotors | JHM LW back rotors | HRE P104 21x9.5 | Michelin PSS 285/35/21 | Autotech HPFP
    11.788 @ 115.64mph [ KI 194 / APR 57.73 | 104 | -350 ft. D/A ]
    11.950 @ 113.61mph [ KI 194 / APR 57.73 | E85/91 | +300 ft. D/A ]
    0-60 in 3.71
