Results 1 to 15 of 15
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    does anyone know weight of OEM 19" S3 rims?
    just as the title states......I thought I read somewhere that the OEM 19" wheels weigh around 22lbs. I am up in the air for new wheels and just want to compare weight..
    Aug 06 2012
    san diego
    the mag ride wheels without tires weigh 9.7kg or 21.3848lbs
    here is a link to their specs: http://www.fuchsfelge.de/index.php?id=795&L=1
    there was an awesome video showing how they are made but i can't find it right now
    Those are for s3's with mag ride but not the Black optics package. The black optics 19's weigh around 27lbs
    Mar 23 2016
    Ontario,Canada
    Thx!! Yes those are the wheels...
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    Here's the vid. Pretty cool!
    http://youtu.be/_rWYPhUOoTI
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Active Member One Ring P230james's Avatar
    Aug 21 2016
    2006 Mazdaspeed 6
    Florida
    The 19" Black Optic wheel & tire of my Audi S3 is a combined 48 lbs, per my scale. I measured this with a nearly new ContiSportContact 5P 235/35R19 tire. The tire alone is 21 lbs according to Tire Rack. I didn't know the non- Black Optic wheel was so much lighter than my wheel.
    Dec 21 2015
    Melhbach, Germany
    Quote Originally Posted by P230james View Post
    The Black Optic 19" wheels are about 7 lbs heavier per wheel than the 19" Perf. Wheels for the S3. The 19" Perf. Wheels are 21.3848lbs. Black Optics 19" Wheels are about 28 lbs each. Reason why I didn't check the black optics option.
    If you already have the 19" Perf. Wheels the options are slim to find a lighter or as light wheel without costing you big $$.
    2016 Audi S3 (CTS Intake, JB1, dogbone, AWE track catback..)
    2002 Trans Am WS6 (Sold)
    2012 SRT8 (Sold)
    1997 Viper GTS (Sold)
    2006 Z06 (Sold)
    2004 Viper SRT10 (Sold)
    2010 GT500 (Sold)
    Veteran Member Three Rings audinator's Avatar
    Nov 17 2005
    B9S4, 91 CRX, 85 CRX, 17 Thundra
    SoCali
    WOW these Black Optics wheels are heavy!
    I just posted a few minutes ago for 18" big tire options but now maybe I'll just grab a set of 19" regular (non-black-optics) wheels.
    2018 B9 S4 Daytona Gray | Rotor Gray
    . . . and many other Audi's over the years . . .
    Dec 21 2015
    Melhbach, Germany
    Quote Originally Posted by audinator View Post
    I was thinking originally to get some lightweight 18" wheels. In 18" wheels the Forgestar F14 are the lightest for the $$ without going crazy expensive. Weighing in at 18 lbs each.
    Remember to watch what tires you get or getting lighter wheels is wasted. Some EQUAL size tires have weights up to 6lbs in difference each. I use tirerack to compare tire weights.
    2012 SRT8 (Sold)
    2006 Z06 (Sold)
    2010 GT500 (Sold)
    Aug 06 2012
    san diego
    most people don't even know what great wheels they are and end up 'upgrading' them to some riced out super heavy vape-mobile wheels
    check your local craigslist or find someone that has upgraded them- i think i saw a set on CL in my area for around 750-1000$
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Quote Originally Posted by markn1689 View Post
    my thoughts exactly.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Nov 17 2005
    SoCali
    Great infos guys, I would have assumed a lot WRONG things about our OEM wheels without finding out from you all.
    I purchased a set of R8 wheels from a member last night, looking forward to shedding some unsprung weight!
    Established Member Two Rings legacypgmr's Avatar
    Feb 12 2012
    3rd rock from the Sun
    Just found this thread.
    So tell me. What difference would 7 lbs per wheel make for acceleration ? Handling ? Gas mileage ?
    I'm thinking of getting an S3 and changing the wheels to Andros copy of the Audi "Rotor" wheels which are about the same weuight as the black optic wheels. Surprised those wheels are 33% heavier than the performance option wheel.
    TIA
    Feb 16 2004
    Bay Area
    Quote Originally Posted by legacypgmr View Post
    TIA
    If you're thinking of ultimate horsepower and not the area under the curve, you won't notice much of a difference. To an avid racer that competes at a competitive level, 7lbs is huge, acceleration, braking, handling all improve to such a level that different suspension settings would be required.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
    Feb 26 2007
    2018_RS3_Cat_Red_and_2014_S7
    Calgary, AB, Canada
    The biggest advantage of lower unsprung weight (ie lighter wheels and tires) is in ride quality - the suspension manages the lighter weight moving up and down better, transmitting less harshness and impact through to the chassis and cabin. A car with lighter wheels/tires will have a smoother ride with less harshness - smoother doesn't mean softer, it means it gets bounced around less, the tires stay in better contact with the road. The lighter wheels/tires will also make a car feel more nimble and responsive than it does with heavy wheels/tires - in other words, more fun to drive.
    Here's a simulation you can do to see the effect - hold a 20 lb weight in front of you with both hands, and try to move it up and down in front of you rapidly. Now change to a 15 lb weight and do the same movement - see how much easier it is for you to control the travel of the weight and to change direction? That's what your suspension sees with lighter wheels/tires.
    There is a slight penalty with heavier wheels and tires, but not much - the tire compound (sticky or hard) will make a bigger difference on mileage. Same thing for acceleration or braking - only a very slight degradation from heavier wheels/tires.
    Feb 25 2018
    Italy
    Hi guys, I resume this thread..
    Where can I buy 19" Perf. Wheels for the S3?
    Thank you
