Results 1 to 9 of 9
    Established Member Two Rings denako's Avatar
    Jun 29 2016
    Chicago, IL
    19x10 with a 255/35/19?
    Got my eyes set on the Rotiform IND/T 19x10 ET 35's. Question I have is, will a 255/35 fit okay without any rubbing issues? I have a B8 S4 on Solo Werks Coilovers. If it helps, I'm specifically looking to get Michelin Pilot Sport A/S 3's. (Chicago Daily)
    11' S4 6MT / 03' GTI 24v / 97' 318i
    Established Member Two Rings speedemon92's Avatar
    Aug 02 2016
    Birmingham, AL
    I am running 20x10's ET33's with a 255/30r20 lowered 2in on stasis CO's. I checked everything after mounting and it looks like I could have run 35's no problem. I would say go for it especially since you've got 1in less circumference than I do.
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    Et35 is a bit aggressive and may rub slightly on dips, depending how low you are. I am running 19x10 ET40 on 255/35/19 PSS and I have zero rub, lowered to about 25.5" FTG.
    Veteran Member Three Rings Lou-quattro's Avatar
    Dec 29 2009
    B5 S4
    Peoria, AZ
    You'll be just fine depending on your ride height. I'm able to go pretty low on my H&R coils before I start to rub. Just have to find the right ride height.
    I'm settled in right here with no issues...
    B8.5 S4 manual | AWE x GIAC stage 2 | CTS turbo intake | AWE track exhaust w/ non-res DP | H&R Street Performance Coilovers | Rotiform IND
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Can you say streeeeeeetttttch
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Aug 02 2016
    Birmingham, AL
    Quote Originally Posted by Lou-quattro View Post
    mmmm yes. perfect.
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Quote Originally Posted by denako View Post
    If your roads are bad I would recommend finding an less aggressive offset to provide more sidewall protection. Had 19x10 et40 with 255/35/19s and two have cracked already. They're Forgestar's though so that may explain why.
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    19x10 on 255/35? that's quite the stretch. i have 19x9.5 on 255/35 and there is stretch but not too much.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    255 is not that much stretch on a 10 inch wheel. 255mm is basically 10 inches...technically 10.0394 inches. A 255mm will show light stretch depending on manufacturer, a 265mm tire will be flush...again manufacturer dependent.
    Below is a 255mm tire on a 10" wheel from my old B6.
    Not a crazy amount of stretch...
    The ET you've posted is a bit high for an S4... you may need camber, fender work, or additional ride height to remain rub free. Any option or combination should work.
