Results 1 to 7 of 7
    Established Member Two Rings J4EZ's Avatar
    May 10 2016
    Colorado
    Centre Brake Light is out
    Easier to DIY or bring it in to have done? Anyone know of a 3rd party light?
    2009 Audi A4 Premium Quattro 2.0
    Active Member Two Rings Sublinx's Avatar
    Oct 12 2015
    Audi A3 8P, Infiniti G37
    Atlanta
    I just got mine on eBay for around $45. Works great and no more error. With the DIY video floating around I had a hell of a time getting mine back into place. There's a tool a guy uses on YouTube if you search replacing the 3rd brake light in a A4 B8. That tool looks to make it a lot easier.
    Active Member Two Rings moai's Avatar
    Jan 12 2013
    West Texas
    Here's the video referenced above.
    https://youtu.be/vFYQWeh5lNg
    Jan 13 2014
    nyc
    Removal is easy...its getting it back in thats a bitch.
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    Everything is easy.
    Put your fingers under and pull down(hard).
    Slide the light down along with the window.
    Disconnect the connector.
    Is your light working from time to time? If yes, then its the 2 pins you attach the connector to that is loose. You need to solder them back in place.
    Aug 17 2015
    California
    Wow, this just happened to me today. No idea why. 2011 with only 60k miles.
    New Member One Ring
    Aug 13 2020
    hereford
    just a wiggle on the switch fixed my warning light ..plug connector was dodgy ..2013 with 29k on the clock
