Thanks for the responses, much appreciated.
Originally Posted by
Okedokey
Check your DV again mate. Easiest option at this stage and yes, even after a year, I wouldn't be surprised if its done.
I do have a spare DV so I'll try swapping it out to see it it makes any difference.
canadianA4B7
When I first started my upgrades (s3 K04) the same code came up. Went over the system checked for leaks same thing no leaks nothing was broke over used or anything. Unitronic then revised the tune for a few (baldy I believe was another big influence on them adjusting tune). Next when I went to the 2863, same thing upgraded unitronic tune and code again. Unfortunately this was a pin hole in a weld. There was no smoke exiting the hole, the boost pressure test was run up to 25 psi and that's the only time I cud hear it. And only way I found it was baking soda. Knew the general area tossed some baking soda close to the sound and the stuff went everywhere from the pressure.
If jhm confirms the tune is ok then you've got a leak. It's finding it that's going to be hell.
On this rebuild I back yard assembled the complete engine. I tightened every clamp every but every bolt. So far 100km into this rebuild no codes. Other then the few things I missed plugging in and a knock sensor that was not tightened to spec.
Where was this pinhole leak? Just curious as manufacturing defects tend to occur in the same spots.
And how were you able to pressurize your system to 25psi? Seems that the air escapes into the crankcase and makes a lot of noise as it gurgles out, making it tough to diagnose any leak sounds.
BKLYNAUDI
n75 valve Part # 06F906283F
Is there any way to test the N75? Or specific symptoms to the N75 being bad? From what I have read, a bad N75 would likely cause sudden boost drops or inconsistent boost. In my case, it seems like more of a steady fade of boost or lack of hitting peak boost at WOT. Luckily they're not too expensive so may just try installing a new one.
- - - Updated - - -
jamerican1
Mine was the wastegate...
How did you narrow it down to the wastegate? Did you try the wastegate adjustment? Any luck with that?
