Results 1 to 8 of 8
    Senior Member Two Rings usaf655's Avatar
    Mar 12 2014
    Florida
    P0299, Possible causes?
    Good evening everyone, So my car has the terrible P0299 Error code. Ill try to list all relevant (or possibly) relevant info.
    -Sometimes (before warming up to running temp) the car will hit full boost
    -Car jumps into limp mode, randomly, I could be in park and then go into drive and itll go into limp mode. Or I can be on cruise control, turn it off and attempt to accel. and see the car is in limp mode. But occasionally, not often, itll begin to run normal again. When in limp mode, the car will only run up to 5Lbs of boost.
    BRAND NEW PARTS IVE TRIED (less than 5000 miles on these)
    -Diverter Valve
    -PCV Valve (not the breather hose though)
    -N80 valve, 10k miles ago
    Mods
    -APR carbonio intake
    -034 Test Pipe
    I do not have a RossTech cable sadly. The car will be taken to the stealership this weekend, I plan on doing a boost test on the lines to check for a leak as well. Just curious if you gear heads may have an idea of whats left that may be faulty. I just really hope I wont be flipping a turbo rebuild bill.
    2018 Florett Silver RS3
    2019 Florett Silver Q5
    Sold 2007 Brilliant Red A4 2013 Estoril Blue Crystal S4
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Everything. Stop throwing parts and get the smoke test done.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    May 15 2014
    Whittier, CA
    When my car had the exact same symptoms you are describing it was a bad boost solenoid (N75). It worked intermittently so it was tough to diagnose. Once I replaced it, full boost all the time. I got it from ebay for $35 shipped.
    Mar 12 2014
    Florida
    Thanks, if the leak test runs no leaks. I plan on just having them replace my N75 solenoid.
    Apr 24 2016
    California
    it could literally be anything, so best to have some diagnosis done before throwing parts at it. My 0299 was due to a worn LPFP that was cutting fuel, accompanied by an intermittent 310B code as well. Other causes are the N75 wastegate solenoid, leaks in the intake tracts, bad valve cover, PCV including breather tube, bad turbo, dirty or faulty MAF, the list goes on and on.
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Jun 11 2015
    EDMOND OK
    Gents if I use Ross tech vag com cable would it let me know exactly what's wrong and what I need to replace mine is kind comes and goes on the winter the check engine light just goes off and once the weather start warming up check engines comes back up
    I don't trust stealership that much when it comes to diagnosis ?
    May 18 2018
    Any UPDATES?!? Having same issue
    Quote Originally Posted by usaf655 View Post
    -Diverter Valve
    Mods
    -034 Test Pipe
    My 2007 A4 B7 is having the same issue, car goes to limp mode (under 5psi) when engine warms up.
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    N75 - Had same issue (low boost when engine warmed up), did a bunch of diagnosis and it pointed to N75. I put all the diagnosis steps in a post in another bigger P0299 thread.
    Linky
    https://www.audizine.com/forum/showt...1#post12724091
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
