Results 1 to 12 of 12
    Active Member One Ring spddmn012's Avatar
    Aug 07 2016
    Austin, TX
    Seat belt locked after accident
    After an accident, the driver seat belt is totally locked up and the air bag warning is illuminated (though it didn't deploy). I've done some light reading and it appears the pretensioners may have been deployed. Is the seatbelt useless now? Can/should it be fixed?
    I've looked for replacement seat belts online but haven't found anything (with the exception of ebay) which concerns me a bit. If they can't be fixed, is it best to call the dealership and have them replace it? *shivers*
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    I've never heard of 1 time use seat belts before.... must be a German thing
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    This happened in my Maxima back in the day. Had an accident, airbags deployed, and seatbelt got stuck. I had to replace the belts with new ones IIRC. I found mine used I think from junked Maxima.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    May 18 2012
    2005 S4
    Portland, OR
    Yeah, the pretensioners fire their charge and that's it. You can probably find a used seatbelt for a reasonable price, and the airbag warning can be reset using VCDS (I think the modules are good for 3 resets before a new/used module is required).
    Apr 26 2016
    Metuchen New Jersey
    Quote Originally Posted by 924Carrera View Post
    Are you guys shittin me?? I was only kidding when I said the belts were single use ... what kinda German backwards engineering crap is that?.....
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by chain_slappins4 View Post
    The Germans aren't the only ones using pretensioners. In fact, pretty much all modern cars have this feature....the idea being, your life is generally worth more than a seatbelt, and any collision at a high enough speed to fire them will probably total the car.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Lots of people parting out cars. Check the classifieds.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Senior Member Two Rings Malv1's Avatar
    Nov 23 2012
    1995 Volvo 850 T-5 R
    Rochester Hills, MI
    Common place in the industry. If you have a pretensioner in the seatbelt, you only get one shot at it and then it's done. Didn't your insurance company cover the repair?
    - 2014 Glut S4 DSG. Stock
    - 2007 Imola RS4. Milltek catless, non resonated exhaust, APR tune, RS5 20" Rotors... SOLD
    Aug 07 2016
    Austin, TX
    They wanted to total it for cosmetic damage. They gave me a check and the car back and it's not salvaged so I'm doing work myself.
    Sep 21 2016
    Los Angeles, CA
    Hey,
    Did you happen to find a solution to your problem? I am having the same issue with my 2015 a3. All of my seat belts are locked and everywhere I looked it said that they need to be replaced and that is 1k fixture, but if it needs to be done, it needs to be done. I have seen websites that say they repair triggered seat belts, but is that even possible?
    Aug 07 2016
    Austin, TX
    I am taking it to Audi to have it done. Being that it's for safety, I'd rather have new parts and professional services do it.
    Senior Member Two Rings Bonz099's Avatar
    Jun 30 2015
    Rockville, MD
    Not only do most cars have pre tensioners, but most seat belts are attached in a fashion so they can "peel" away from the car, like opening a can. This helps slow down the disbursement of energy during a crash and slow the body down in a more controlled fashion. The pretensioner does exactly what it sounds like. It does this to lower the amount of slack in the belt to keep your body more restrained.
    Nobody designs a car to be crashed more than once....
