Results 1 to 13 of 13
    Jul 28 2009
    Jupiter Florida
    Supercharger Belt Replacement, Is it Necessary to do AC Belt Replacement at Same Time
    I have almost 82k miles on my 2012 b8 s4 and getting the supercharger belt replaced this weekend. I've seen some say on the forum that you should get the AC belt replaced at the same time, but I do not see the AC belt as a service item on Audi's maintenance schedule. Is it truly necessary? It will run me about $150 extra. Thanks for your thoughts!
    Current: 2012 Audi S4 3.0TFSI, Ibis White, Black/Silver Alcantara Interior, Navigation Package, B&O, Rear Acoustic Parking Sensors, Sports Differential, Carbon Atlas Inlays, 19" Peelers, AWE Exhaust, V1 for protection.
    Retired: 2006 Audi A4 2.0T S-Line nearly loaded
    Retired: 2003 Acura 3.2 Cl Type S with AEM intake, AlphaWerks headers, O&E Sport springs, Tokico Blue shocks, Eibach Sways
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I believe there are only two belts, SC belt and the large serpentine belt. Have to take the SC belt of to do the other so makes sense to do them and save some labor.
    On a side not I just went Stage 2 and was looking at the SC belt. Had clear signs of getting close to being replaced and I am at 62k.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jul 28 2009
    Jupiter Florida
    Quote Originally Posted by cspcrx View Post
    Now I'm super confused.....the supercharger belt and serpentine belt is different?
    I haven't had any of the belts changed yet, but getting quotes from local shops. I asked for a quote on Supercharger belt and AC Belt. However what should I be getting replaced at 80k?
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    I'd get both done as as said the SC belt needs to come off for the AC belt to be changed.
    Both are at substantial miles now
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Feb 05 2016
    UK
    Timing gear and ancillary units drive
    Replacement interval of the ribbed V-belt for all ancillary units except Roots blower: Lifetime
    Replacement interval of the ribbed V-belt for Roots blower: 75,000 miles (120,000 km)
    Tensioning systems of both ribbed V-belts: Lifetime
    Timing gear chain replacement interval: Lifetime
    Timing gear chain tensioning system: Lifetime
    So in theory no need to change both :)
    Jul 28 2009
    Jupiter Florida
    Quote Originally Posted by xpoweruk View Post
    Thanks the first posters terminology confused me. is the serpentine belt and the Supercharger belt the same or different? what specific ancillary parts are supposed to be replaced?
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by audifan22 View Post
    There are two belts. The crank to supercharger belt, and the large serpentine belt. The crank to supercharger belt is to be changed at 75K miles (2010-2012) or 55K miles (2013+). The large serpentine belt is supposed to be inspected at regular intervals and replaced if worn.
    Jul 28 2009
    Jupiter Florida
    Quote Originally Posted by jsh139 View Post
    Thanks, I have a 2012. I guess I will have them both done at the same time then? The large serpentine typically lasts how long? where can I find the part numbers for both so that I can confIrm the shops are giving me a correct quote? I appreciate the help everyone
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    My car just rolled over 70K miles. I had the S/C belt changed. The serpentine belt was fine so I left it alone.
    Parts can be found here: https://genuineaudiparts.com/parts/2...07&searchText=
    Jul 28 2009
    Jupiter Florida
    Guys I'm very confused. I had a shop replace my supercharger belt today and asked them to replace the AC belt. When I got the car back I asked them if they happened to see the condition of the serpentine belt and they said that the AC belt is the serpentine belt? Is this true?
    Mar 21 2015
    https://genuineaudiparts.com/parts/2...iagram=1399106
    Junior Member Two Rings
    Aug 31 2004
    PA
    Yes, serpentine belt will run the a/c and water pump. People typically don't call it a water pump belt or a/c they just refer to it as a serpentine belt. The s/c belt is called so because it only spins on component. Hope tat helps.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I think you're getting terms confused. AC could stand for either Air Conditioning or Air Compressor. "Air Compressor" is the Supercharger. Like I said before, there are two belts. One long one (Serpentine belt) that runs the air conditioning, water pump, and other accessories. And one shorter one that just runs the Supercharger. The shorter one is the one that needs to be replaced at either 55K or 75K depending on your car's model year.
    Did you tell them to replace the "supercharger belt" or did you tell them to replace the "AC Belt"? They probably got confused and replaced the larger one.
