Results 1 to 15 of 15
    Junior Member One Ring RobertPiller's Avatar
    Aug 13 2016
    Ostrov
    Honeycomb grill for the center of S-line bumper
    Hello, I'm looking for a honeycomb grill for a S-line front bumper. I already found a replacement for the hood grill, but can't find anything for the bumper. Can you help me with that? I want it to look like this, thank you!
    Róbert Piller
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    I don't think one exists. If you look closely, you can see that the small mesh openings are shaped differently than the hood grill and the foglight surrounds.
    I think it was custom made.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    The upper and lower grill from the car in the picture you posted was made from mesh purchased from http://lltek.com/ using the stock USP center surround.
    On a side note, there is no such thing as an "S-line" B6, it's an Ultrasport even if you have "S-line" badging on the car. From my experience, '04 Ultrasports did not have any "s-line" badging on them, my '05 USP 1.8T has "S-line" on the steering wheel, and I believe the '05 3.0 USP's also had "S-line" badges on the doors, but as far as I understand B6's are Ultrasports, B7's changed to "S-line".
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by MacFady View Post
    The Ultrasport designation was North America specific; the rest of the world used S-Line.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    There is the MK6 GTI option.....
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by Matt Devo View Post
    This^^^ Plus my 2005 Ultrasport 1.8t has the emblems on the doors and the steering wheel...
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Pretty much the only way you're going to get one:
    http://www.audizine.com/forum/showth...lltek-RS4-mesh
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    May 22 2007
    Santa Monica CA
    Oh, and as far as the S-Line badging goes, some of the 2005 MY USP's have the S-Line badges on the sides (Mine didn't - unless the previous owner removed them). Some of the 2004 & 2005 MY USP's had the S-Line badge on the steering wheel and some did not.
    Feb 12 2008
    Michigan
    Where do you find decent S line door badges?
    Feb 05 2014
    Quote Originally Posted by Fast4esT View Post
    Probably the dealer....
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Quote Originally Posted by RobertPiller View Post
    That's a pic of my car.
    For the hood grill, you have multiple choices. The one in the pic was sourced from LLTek.com - Uberhaus hood grill. There's also a good one offered on eBay which I think was originally supposed to be a part of the OEM Votek body kit Audi once offered.
    For the lower center grill, that one is 100% custom made. I started with the regular S-Line/Ultrasport lower center grill and cut out the slats to leave the outer frame. I then sourced a mesh screen from LLTek.com to epoxy onto the frame, paint the frame black, and screw into the lower bumper (clips lost when cutting out center slats). LLTek.com has an RS style body kit for a B5 S4. They list the mesh screen that you can order separately. Measure the length and height of the opening and add about 2-3 inches when giving the order to them. They will then send you the sheet to line up and cut down to size.
    USP CLUB MEMBER #34
    Jan 09 2019
    Portland Oregon
    Quote Originally Posted by CyberPMG View Post
    I know this is a old post, But I was curious as to if you know if there is a way to find the Honeycomb fog light parts? and If you know where I can find black window trim, and black trim for around the lower center grill. I am trying to black out my 2005 B6 S4.
    Jul 21 2013
    B6
    You can get the grilles from ecs, but you’ll have to have the usp bumper for them to fit.
    I’m going to try plastidip on my window trim this weekend. I’ll let you know how it turns out. I was quoted $140 from a vinyl wrap shop. I assume actual black window trim would be more than that.
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by PDXDragon View Post
    If your S4 has the standard S4 front bumper, then I'm not aware of anyone making honeycomb grills for the fog lights. You would have to make them yourself. You could use this in a frame and a cutout for the fog light... Clicky click
    For window trim and the lower center grill, it might be easier to use a vinyl wrap or use PlastiDip. Otherwise, check eBay.
    USP CLUB MEMBER #34
    Jan 09 2019
    Portland Oregon
    Thank you for the direction. I guess I will be making them for my car. Not sure if I would want to go the vinyl rout. plastic dip might work, I would rather have them black from the factory but can't seem to find them anywhere.
