Results 1 to 20 of 20
    Active Member Two Rings jalx's Avatar
    Nov 05 2006
    2007 A4
    B8.5 S4 vs F30 340i
    Hi Guys, would love some advice.
    I have had an B7 A4 for 8+ years, and it is time to upgrade. I plan to keep my next car for long time as well, 7+ years.
    After a lot of test driving I’m between a 2016 B8.5 S4 with sport diff or a 2016 F30 340i x-Drive with M Performance Pkg. Both pretty much fully loaded, slightly used, and about the same price.
    The B9 is out of the equation because I will have to wait 2 years before they are at price range I can afford. Also, drove the Golf R, fast, but didn’t like it.
    I love the V6 supercharged and sport diff combination. But the 340i i6 pull to the red line effortless. Also the 340i is way better equipped, not to mention a completely newer generation (that’s something to consider when you plan to keep the car for long).
    I know this forum is biased, but I would love to hear what you think.
    Thank you
    J
    Established Member Two Rings roydle's Avatar
    Oct 25 2015
    FL
    Hard decision, I was in your same shoes a couple of months ago and ended up getting a 2016 S4. I never test drove the 340 but decided for the S4 as it is more unique than the 340. Better seats, amazing DSG transmission and overall more racing touches than the 340. The only advantage the 340 has is the newer body style. The B8.5 in couple of years or even now might look kind of old style. Seems you are into all wheel drive, and my understanding, Quattro system is much better than the X-drive. Good luck.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    When I was looking for new car to replace my 2000 BMW. 528, I drove a new then 2015 435 BMW coupe then took home a 2014 s4 for week end test drive, then drove the 435,coupe again. My response was different from yours, the S4 was so much nicer than the bimmer . Faster better interior, nicer seats, better electronic interface, intergrated display, better engine & transmission.So I oredered my new 2015 s4 the way I wanted and never looked back . Quattro is so much nicer than x drive, BMW are a dime a dozen, the S4 is very special. M3 is a closer rival , faster ,but not AWD. S4,is the best of all worlds for me . My 2 BMW s were both troublesome from the beginning. The first one 1984,325,e was so bad BMW Replaced it after 44 months. My 2000 had idle issues in cold weather, fixed once after warranty expired , then to return five years latter, as the fix f was temporary and the vanos. Unit, part would go bad again as the replacement vanos was the same as the original again , as the design was not changed.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Dec 21 2013
    Same here test drove the 2015 335i and it drive like crap so I went with the B8.5 S4
    Current: 2021 R8, 2019 A6, 2017 Ghibli SQ4
    Past: 2009 C300, 2011 C63, 2013 535i, 2014 S4, 2016 M4, 2016 Macan, 2017 Macan Turbo, 2017 E350, 2017 750i, 2018 Panamera Turbo
    Apr 05 2016
    Portland, OR
    I haven't driven a 340 but like most here I drove a 335i Xdrive and ended up going with the S4.
    Just liked the S4 way more.
    Veteran Member Three Rings Mr.Tan's Avatar
    Sep 02 2014
    '01 GTI
    York, PA
    i'll be the one--- i'd go with the BMW. Like you said, newer generation. You also mentioned it was better equipped. I do love the b8.5, dont get me wrong.... Its a really fun car to drive, however the bmw always just felt more refined and comfortable. When the time comes i will probably go back to a bmw of some sort.
    www.epautohaus.com for all your aftermarket performance parts, wheels & tires
    Nov 05 2006
    2007 A4
    Completely understand the comments on the 335i/435i. But the 340i is BMW's mid cycle refresh car. It has a newer engine, no lag what so ever. Revised suspension, transmission, and idrive.
    On the other hand the supercharged engine / dsg on the S4 is sweet...
    Decisions... decisions...
    Sent from my STV100-1 using Tapatalk
    Julian
    2007 A4 2.0T Manual S-line
    Mar 09 2014
    Boston, MA
    Check the steering. See how it feels before you decide.
    2024 Audi RS5 Competition
    2024 Tesla Model Y Performance
    2018 Porsche Cayenne Turbo
    2018 C63s Coupe
    2012 C63 Coupe (P31 Package)
    2014 E350 Coupe
    2013 S4
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
    Oct 31 2013
    Morris County, NJ
    Sounds to me like you have your mind made up
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    I test drove both a 335i x-drive and an 340i x-drive and while I liked both cars 340i especially..it didn't have that feel or communication with the road as they felt isolated and artificial..they were smoother with the tranny shifts though but couldn't pull me away from my 10' S4.. you will have to decide for yourself..good luck
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Jul 14 2013
    British Columbia, Canada
    I would probably say go with the S4 since the performance is very similar however the 340i looks like a normal 3 series unless its the M performance variant. The S4 looks more sporty in comparison to a 340i. Driving dynamics of a 340i would be much more balanced compared to S4 being more nose heavy. Also if you care, gas mileage would be better too. I only get 18MPG in the S4 vs my friend in his 340i getting 21MPG with a similar driving distance and city/highway.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Junior Member Two Rings adganga's Avatar
    Apr 25 2016
    Detroit, MI
    I actually did the exact same comparison. Was shopping the 2016 340 to the 2016 S4. I thought that the S4 was much more of a drivers car. It felt special driving it, while in the 340, I felt very normal. The same problems occurred to me as well...if the lack of completely up to date technology would bother you, the 340 might be better, however the S4 will put a smile on your face every time you get in it. It's the 'fizz' that was missing from the 340 that pushed me into an S4
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    I went from 07' 335i coupe to the 13' S4. Looked at the new 335i before getting it and I felt like it was a downgrade from my 07'. I thought the S4 was way better looking, more fun to drive, faster, way better interior, more refined, more luxurious and felt special. The S4 makes you feel special having an S car while the 335i just wants to pretend to be an M car. Gotta give technology to the BMW but that's all.
    Just to note I was a BMW guy before my S4. If anything I was biased for BMW.
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
    Feb 01 2013
    NoVa
    Quote Originally Posted by adamkb26 View Post
    I was also a BMW guy before an Audi. Had a 325ci, a 325i, and a 128. Even tried an 14 E350 and an 11 C350...all leases. All of which I was shopping for cars many months before my term was up. Bought a 13 S4 in December and never looking back. Before the S4, I tested a 2016 435I Gran Coupe which I thought I would love. It was okay at best, I felt cramped, the steering was numb, and by the time I ticked all the boxes I wanted it was a 60k car.
    The exclusivity of the S4 is also something to be mentioned, nothing new but the way BMW structures its leases means that anyone with a half decent credit score can walk out the door paying $4-500 for a new BMW. You can't go wrong with the BMW but it won't be anything special.
    2019 Q8 P+
    2016 A7 TDI Prestige
    2013 S6 Prestige
    2013 S4 P+
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Test drove the 340i.
    Then test drove the S4.
    Bought the S4.
    /thread
    Murdered B8.5 S4
    Build Thread
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Quote Originally Posted by cval3 View Post
    Yeah I also drove a 15' 435i xdrive M Sport last year. Was not impressed at all. Very disappointed in BMW.
    Jul 05 2016
    I am also a former BMW guy before getting my 2013 B8.5 S4. I had a 2008 BMW 335xi coupe with full suspension done, tune, FBO, and ton of exterior mods. If you compared the s4 to the e9x 335 then I would say go with the BMW, but the new F30 are a downgrade. The engine isn't as performance based and easily tunable like the N54 engine. I'd definitely go for the S4 over the F30 340i.
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    B8.5 S4 vs F30 340i
    OP, to add another choice I cross shopped a 2016 S4 against a 2016 BMW 340i x drive, a 2016 MB C450 and ended up with the 2016 S4.
    The torque vectoring Sports Diff was the key differentiator, at least for me. You can't go wrong with the BMW though, as the 340i X drive optioned out with M-Perf package looks like a baby F80 M3, not to mention the residual is better on the BMW compared to Audi if you lease (I know you said you're buying). All the magazines love the MB interior as a lot of features look/feel like they came from the S-class, but personally thought it was too gaudy inside and was not for me. Performance wise, the C450 AMG felt slightly faster but didn't give me the same feeling as I did on the S4.
    TL;DR, S4 with sport diff then upgrade to F80 M3 down the road if Audi doesn't bring the B9!RS4
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I was/an a bmw guy. Had a '07 328i coupe, a 2010 135i and then a' 13 335i coupe. Loved all those cars and modded were fun as hell. As of now I don't like the direction bmw has gone. Too many models and you now feel that the 3 series is so watered down. I ended up in a 2015 s4 6mt which is awesome. If I didnt find a manuel would have still probably went with bmw though.
    Sent from my SM-G925V using Audizine mobile app
    Jul 05 2016
    Ontario
    I'm a long time BMW owner and I just went through this myself. Came from various E36 models, an E46 330 M-Sport and even an E34 m5... All fantastic driver's cars. Looked at an m235, 340 and a few older 335s. Found all of them lacking in what I really loved about the older bmws... Road feel lacking, steering is numb, styling was overstated and obnoxious, colour choices are red, white and blue and reliability of the BMW turbo motors is sketchy at best. Most of the choices around my area were 4 wheel drive slush boxes too - which just completely ruin an otherwise almost-tolerable platform (though the ZF auto in the m235 was quite snappy). None of them really interested me. Maybe a new M2... Maybe. To be fair, the S4 is no "driver's" car either - steering feel is numb, balance way is off, the v6 sounds like crap and it corners like a three legged pig when you really push it (sport diff is gimmicky but doesn't solve the real problem of total lack of turn-in) - but at least it's drop-dead gorgeous inside and out, far more refined than the bmws, understated, and can still be plenty of fun almost all the time. Better value too IMO.
