Results 1 to 40 of 64
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    To all B8 Avant owners rocking the B12 Kit
    This is posted in the A4 B8 forum as well - a majority of us just had the Bilstein B12 Pro Kit installed after Bilstein was back-ordered for a few months.
    While I have nothing but great things to say about ride quality - myself and a few other have some serious rake - more so than the kit advertises.
    Curious who all has this kit installed and facing a similar issue? Currently sitting at 26" front and 27.25" rear
    Cheers,
    Ry-man
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    Mine is similar...dark out now but I can post my measurements tomorrow
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    I have Bilstein B8 and Eibach sports line, both show 26.25
    Front
    Rear
    - iKe -
    2011 S5
    2011 A4 Avant
    May 06 2015
    @avantmaniac - did you purchase the kit or buy the shocks and springs separately? This is the drop I was expecting in the rear but I'm an inch higher
    Cheers,
    Ry-man
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by CONative View Post
    I bought separately.
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Posted on the B12 review thread, I'll post here too. Mine has very similar rake, you can fit your hand in the rear gap.
    FRONT:
    REAR:
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    My B12 kit is still in the box. I may switch to the Sportlines..that's the look I was hoping for.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Established Member Two Rings TheOriginal's Avatar
    Apr 03 2014
    Eastern Missouri
    I thought reverse rake is when the front is higher than the back? isn't this just rake?
    2011 Ibis White a4 Avant Prem+
    Established Member Two Rings HRDNTS's Avatar
    Jun 03 2014
    1999 S15 Silvia
    Auckland | New Zealand
    Quote Originally Posted by TheOriginal View Post
    Yep. Seems like lots of people getting it back to front these days.
    2011 B8 S4 Avant | Sprint blue
    May 06 2015
    Yeah you're right, had it backwards - edited post - thanks
    Cheers,
    Ry-man
    Jan 21 2016
    Hayden, AL
    Quote Originally Posted by Avantmaniac View Post
    Hey iKe,
    What part # Sportlines did you use? I've been searching and haven't found that Eibach actually makes an Avant specific set.
    Thanks,\
    Ed
    May 06 2015
    @Phray got in touch with Eibach - anyone wanting to file a complaint fill out the form below, appears we have their attention 🏻
    http://eibach.com/de/en/company/contact
    Cheers,
    Ry-man
    Senior Member Two Rings Phray's Avatar
    Oct 19 2014
    2011 S-Line A3
    Quote Originally Posted by NLPed68 View Post
    Hey iKe,
    E20-15-011-01-22 should be the Avant kit.
    +1... Hopefully this gets resolved.
    2009 A4 Avant Premium+ 2.0T Quattro
    | APR Stage 2 + R8 Coil Packs + Spullen HFC + AWE DP + AWE Touring Dual Exit (Black Tips) | Rebuilt Engine | Bilstein B12 Pro-Kit | VMR v701 19x9.5 | RS4 Grilles + RS4 Spoiler + Carbon Lip | Tint: 35% Sides + 20% Rear |
    Jan 21 2016
    Hayden, AL
    Quote Originally Posted by Phray View Post
    E20-15-011-01-22 should be it.
    That looks like a kit for a TDI?
    Thanks,\
    Ed
    Oct 19 2014
    2011 S-Line A3
    In the catalog it says "1.8TFSI, 2.0TDI, 2.0TFSI, 2.0TFSI flex fuel, 3.2 FSI"
    Sent from my SM-J700P using Tapatalk
    Feb 21 2007
    Houston, TX, USA
    Hey iKe,
    Ed,
    I will ask my shop as they the one who ordered for me. I still remember we tried to order B12 PRO but to longer wait time, he advised me to go separate way on suspension and spring. So he ordered B8 and the sportsline (which is the same as B12 Sportsline). It ended up matched nicely with my Eurocode sway bars (both are red color springs and the bars).
    I will find out from him, it's been 4 months now since we installed these.
    - iKe -
    2011 S5
    2011 A4 Avant
    Jan 21 2016
    Hayden, AL
    ^^^ Thanks iKe. Yours is exactly like I was hoping mine was going to sit.
    Thanks,\
    Ed
    Feb 21 2007
    Houston, TX, USA
    So, this is what he told me it's the one for Avant/2.0/Quattro. He forgot the serial as he needs to dig up the invoice again, perhaps tomorrow when he's at the shop he can try to find copy of it.
    - iKe -
    2011 S5
    2011 A4 Avant
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    +2, looks way better than the B12 prokit. Much more evened out stance. Why, why, why are ours gaped so high in the rear...?
    Hopefully Eibach will respond to someone here. It seems like a few others have submitted complaints.
    Jan 21 2016
    Hayden, AL
    Ed,
    I've still been looking into the part # that Phray posted, and he's right...it does list all the Avant's, but it also seems that they fit the sedans as well. So iKe if you could confirm your part # for your Sportlines, I'd be ordering up a set so I can be just like you
    Thanks,\
    Ed
    Jan 21 2016
    Hayden, AL
    Okay, after talking to AJUSA (where I purchased my still unopened B12 kit), Eibach USA, conversing back & forth with several other folks I've decided to pull the trigger and try the Sportline part #4.10515. This part # doesn't show the Avant as proper fitment, but the part # that Phray provided (which is a European #) states that it fits both the Saloon & the Estate. So I'm going to give them a try. I want mine to sit like iKe's and that's the part # we think he has. Wish me luck... Oh, and anybody need a brand new set of Eibach Pro's for a B8 Avant
    Thanks,\
    Ed
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Thanks for taking the leap Ed! I'm in the same boat with AJUSA. NO DICE. Looking forward to seeing how things fit. Good luck!
    Feb 21 2007
    Houston, TX, USA
    Congrats guys!, pls post pics when they're up.
    - iKe -
    2011 S5
    2011 A4 Avant
    Jan 21 2016
    Hayden, AL
    The Sportlines came in today. I'm going to try and get them installed this weekend, along with the bilsteins, EC sway bars/end links, and the AK.
    Apr 17 2014
    MA
    wondering if anyone has trimmed or removed their rear bump stops to avoid this rake issue...
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by kdaffy View Post
    I didn't trim mine, but again mine is sportsline spring not the pro spring.
    - iKe -
    2011 S5
    2011 A4 Avant
    May 06 2015
    I trimmed my rears, I noticed there is still about a 1 inch of play so I know for a fact I'm not riding on them.
    However, a small annoyance has recently developed and doesn't happen all the time. Occasionally it sounds like the bumpstop gets pushed into the cup and then drops out. I have yet to take the wheel off and inspect. Doesn't affect ride quality or anything though.
    Cheers,
    Ry-man
    Jan 21 2016
    Hayden, AL
    Finally installed the "modified" Bilstein B12 kit today along with EC sways/end links, AK brace along with the EBay braces & the CR15, and finally the trans & rear diff inserts. Also installed the 19x9.5 Avant Garde's and alignment.
    I will get it all cleaned up and then I'll shoot some pics. The Sportlines are PERFECT!!!!
    Jan 21 2016
    Hayden, AL
    Finally, a few pics of the "modified" B12 ride height. Thanks to all that helped with the decision to go with the 'sedan' Sportlines. The ride height is perfect and the ride is utterly superb!!! Sorry, but I forgot to bring my wifes camera today, so these are just crappy iPhone pics, but you get to see the ride height.
    Thanks,\
    Ed
    Oct 19 2014
    2011 S-Line A3
    Looks great! Love the plate btw!
    Got mine on and I have the rake issue- no surprise there . Here's mine:
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Man, that came out great!
    Jan 21 2016
    Hayden, AL
    Thanks guys. I feel like it's the perfect stance for me.
    Thanks,\
    Ed
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Thanks for taking the leap, now you've got me second guessing. Haha! That rear end sits so much better.....ugggh
    Jan 21 2016
    Hayden, AL
    Quote Originally Posted by avantagg View Post
    And rides FANTASTIC.
    Thanks,\
    Ed
    Feb 21 2007
    Houston, TX, USA
    Nice Ed! Glad everything works out! :)
    - iKe -
    2011 S5
    2011 A4 Avant
    May 06 2015
    Well done, Ed - Avant is looking good! Those gold wheels on that blue...damn
    Cheers,
    Ry-man
    Jan 21 2016
    Hayden, AL
    Thanks Ike! I appreciate you pointing me in the Sportline direction. I'm completely happy with the ride, handling and certainly, the stance!
    Thanks CONative! I'm extraordinarily pleased with the overall results.
    Thanks,\
    Ed
    Oct 19 2014
    2011 S-Line A3
    So I got the Sedan springs as a possible alternative to the ones provided with the Avant kit. I was looking at the part list and it said that the same springs fitted the Avant and the Sedan- hence why the person who bought his Bilstein B8 separately from his springs didn't have any issue.
    Will keep everyone posted after I install them either Friday or Sunday.
    Jan 21 2016
    Hayden, AL
    Those of us that did it separately (Avantmaniac & myself) ended up going with the Sportlines and called it a win.
    Thanks,\
    Ed
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Made the swap from pro kit springs to sportline spings this week. Loving it! Stance is now where it should be IMO. They should have designed it this way from the start. Ride quality is only slightly firmer than the pro-kit spring. Thanks for leading the charge @Avantmaniac and @NLPed68
