Results 1 to 23 of 23
    Aug 08 2016
    Will 35 offset rims rub?
    Looking for new 18x8 rims but I'm not sure about what offset is best. I know the stick 18" have a 46 offset but the rims I'm looking at have 35 offset. I'm not sure if I will ever lower the car but if I do it won't be a drastic drop. Anybody know if 35 will work?
    Oct 14 2007
    Orange County, California
    Quote Originally Posted by AnthonyA3 View Post
    According to Tire Rack an offset of +35mm will fit.
    However, I don't know what you mean by "best" or asking whether it "will work." Assuming all else (wheel weight, tire selection and pressure) being equal, an 11mm decrease in wheel offset:
    (1) Increases the track width, which increases stability, but decreases the scrub radius, which decreases stability. Hard to say what the net effect on stability would be.
    (2) Increases the steering "feel" or effort, and thus torque steer.
    http://www.motoiq.com/MagazineArticl...and-Scrub.aspx
    In short, changing wheel offset will most likely change the way your A3 feels and handles, and not necessarily for the better. So if you don't want to do so, stay as close as possible to the "stock" offset. (An offset of +46mm appears to be the lowest wheel offset among all the different stock wheels installed on A3 and S3 models.)
    When I recently upgraded my wheels and tires, I bought the lightest wheel available at my budget (Enkei PF01 18x8, +45mm offset) and mounted wider 235/40-18 Michelin Pilot Super Sports on them. This setup does not sit flush with the fender, which makes it a mortal sin to most Audizine and VWvortex forum members.
    Aug 08 2016
    Thanks for the info. I'm just want to know if the 35 offset will rub with the oem tire size. Probaly going to play it safe and stick with 45 if I don't find someone that has a 35 offset with 225/40/18 tires
    May 03 2016
    Champaign, IL
    You should be alright running ET35. I have 18x8.5 ET35 rims and I'm lowered, and they do not rub. They are pretty close to flush with the fender. If you're at stock height, there should be no risk of rubbing at all.
    Can't say I feel any discernable difference in handling.
    Aug 08 2016
    Quote Originally Posted by A3_Yuppie View Post
    Can I ask why you went wider? For looks and handling or does it protect the rim better?
    Mar 29 2016
    Illinois
    Nice rims
    Great looking rims Do you mind sharing model name?
    May 03 2016
    Champaign, IL
    Quote Originally Posted by mr.IgorZ View Post
    Thanks! They're VMR V710s.
    Oct 14 2007
    Mostly for better rim protection, with the hope for minor improvements in braking and cornering.
    May 03 2016
    Champaign, IL
    Yeah, this is pretty much the same reason I'm going to move up to 235 super sports after the stock tires wear out.
    To the OP, if you're not looking to buy new tires immediately or want to save some money, the stock tires will work fine on 8/8.5 width rims.
    Oct 14 2007
    Quote Originally Posted by bigxie View Post
    Very nice finish on these wheels!
    In your case the 11mm decrease in wheel offset is offset by a half inch (12.7mm) increase in wheel width, so you are moving the inside of the wheel outwards only by < 5mm (compared to stock). With the assumptions that the VMR710 weighs about the same as stock and that you are still using 225 wide tires, any difference in handling would be relatively minor compared to the OP's inquiry re: using 18x8 wheels with a +35mm offset.
    May 03 2016
    Champaign, IL
    Gotcha, thanks. Yeah my fuzzy mental math knew that the wider wheel makes a difference but didn't realize it was as extreme.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    245 tires on 19x8.5 ET35 will fit fine even with just 1/2 finger gap drop.
    -cW
    2023 X3 M40i Alpine White
    Aug 08 2016
    I have the stock 17s. Going to use them for winter.
    Feb 21 2016
    1950 Chevrolet Business Coupe
    Orange Couty, CA
    I'm running 19x8.5" with 235/35 I'm on H&R deep coils with a 1/2 gap - hardly rubs unless under hard cornering with pavement transitions
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    i have 19x8.5 +42 with 7mm spacers and rub in the rear drivers side
    i am pretty low and have the camber set to stock settings which doesnt help with the rubbing. im sure with a little more camber i could have it not rub
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Senior Member Three Rings gamegenie's Avatar
    Aug 04 2014
    I have ET35 wheels and I don't think the ET will determine if your wheel rub against the wheel hub. Lowered suspension and large wheels will determine that.
    The lower offset will increase the potential for your wheels to rub up against a curb since the wheel will be more outward.
    2015 Audi A3 2.0T Quattro
    2012 Hyundai Sonata GLS
    1996 Jeep Grand Cherokee
    1996 Hyundai Elantra GLS
    Oct 14 2007
    Quote Originally Posted by gamegenie View Post
    True, but irrelevant. Wheels are mounted onto wheel hubs; they should not rub under any circumstances.
    Increasing wheel offset (while maintaining same wheel width) moves wheel inwards and increases chances of rubbing against suspension and/or steering components.
    Decreasing wheel offset (while maintaining same wheel width) moves wheel outwards and increases chances of rubbing against fender, a fitment issue. Hitting a curb is a driving issue.
    Aug 04 2014
    All of these are driving issues.
    Senior Member Three Rings miro01's Avatar
    Mar 26 2012
    '97 B5 A4, '15 8V A3
    OC
    I had no issues when I had the same wheels as bigxie (looks great btw) and was on stock sport suspension. 18x8.5 et35, 235/40 tires.
    Sent from my SM-G925T using Tapatalk
    Jul 24 2014
    Sweden
    Have 18×8 et 35 rims with 245 tires.
    No rubbing what so ever and perfect stance in my opinion.
    Went on europe roundtrip with mrs and lots of luggage without any issues.
    Have stock suspension though.
    Also, anything wider than this would probably look silly.
    Aug 08 2016
    Thanks guys, I'm going to go with et35 and 235 tires.
    Feb 22 2017
    2017 BMW X1 (wife's)
    Burlington, NJ
    What springs are you lowered on? I am looking at the H&R sport so lowering 1.2" and I'm on the stock (non-sport) suspension
    May 03 2016
    Champaign, IL
    Quote Originally Posted by razorbilo View Post
    I'm lowered on the Emmanuele Design springs:
    http://www.emmanueledesign.com/colle...nt=22065145927
