Page 1 of 4 123 ... LastLast
Results 1 to 40 of 123
    Sep 09 2010
    Destin, FL
    Fault Code List, Trouble Shooting and Fixes
    Audi OBD 2 & DTC Fault Codes List
    This is a place where all fault code questions and trouble shooting should be located. If you have a fault code and need help, post here for future users that might have the same issue. All fixes of this fault code should also be posted for further help.
    16394 P0010 Series 1: failure of the regulator valve timing
    16395 P0011 Series 1: shift timing in late parties do not reach the rated value
    16396 P0012 Series 1: shift timing in early parties do not reach the rated value
    16397 P0013 Series 1 exhaust camshaft: the failure of the regulator valve timing
    16398 P0014 Series 1, exhaust camshaft, timing shift in late parties fail to reach a nominal value
    16399 P0015 Series 1, exhaust camshaft, timing shift in the early parties do not reach the rated value
    16400 P0016 Series 1, position sensor raspredvala.-G40 / crankshaft position sensor-G28: mismatch signals
    16401 P0017 Series 1, position sensor raspredvala.-G300 / crankshaft position sensor-G28: mismatch signals
    16402 P0018 Series 2 encoder raspredvala.-G163 / crankshaft position sensor-G28: mismatch signals
    16403 P0019 Series 2 encoder raspredvala.-G301 / crankshaft position sensor-G28: mismatch signals
    16404 P0020 Series 2: The failure of the regulator valve timing
    16405 P0021 Series 2: shift timing in late parties do not reach the rated value
    16406 P0022 Series 2: shift timing in early parties do not reach the rated value
    16407 P0023 Series 2, exhaust camshaft: the failure of the regulator valve timing
    16408 P0024 Series 2, exhaust camshaft, timing shift in late parties fail to reach a nominal value
    16409 P0025 Series 2, exhaust camshaft, timing shift in the early parties do not reach the rated value
    P0030 16414 Bank 1 Sensor 1: break the electrical circuit heating
    P0031 16415 Bank 1 Sensor 1: short to ground electrical circuit heating
    P0032 16416 Bank 1 Sensor 1: short to positive electrical circuit heating
    16417 P0033 Turbocharger bypass valve failure in the electric circuit
    16418 P0034 Turbocharger bypass valve short circuit to ground
    16419 P0035 Turbocharger bypass valve
    P0036 16420 Bank 1 Sensor 2: break the electrical circuit heating
    P0037 16421 Bank 1 Sensor 2, electric heating circuit: short circuit to ground
    P0038 16422 Bank 1 Sensor 2, short to positive electrical circuit heating
    16423 P0039 Turbocharger bypass valve-N249: invalid signal
    16424 P0040 messed number 1 Sensor 1 and Bank 2 Sensor 1
    16425 P0041 messed number 1 and number 2 probe 2 probe 2
    P0042 16426 Bank 1 Sensor 3: Open the circuit heating
    P0043 16427 Bank 1 Sensor 3: short to ground electrical circuit heating
    P0044 16428 Bank 1 Sensor 3: short to positive electrical circuit heating
    16434 P0050 Series 2 Sensor 1: failure in the electric circuit of heating
    16435 P0051 Series 2 Sensor 1: short to ground electrical circuit heating
    16436 P0052 Series 2 Sensor 1: short to positive electrical circuit heating
    16440 P0056 Series 2 Sensor 2: failure in the electric circuit of heating
    16441 P0057 Series 2 Sensor 2: short to ground electrical circuit heating
    16442 P0058 Series 2 Sensor 2: short to positive electrical circuit heating
    16448 P0064 Series 2 Sensor 3: short to positive electrical circuit heating
    16449 P0065 pneumatic control valve injectors-N212: invalid signal
    16450 P0066 pneumatic control valve injectors-N212: short to ground
    16451 P0067 pneumatic control valve injectors-N212: short to positive
    16452 P0068 Pressure inlet / air mass <-> deviation angle of the throttle position
    16453 P0069 Intake Air Pressure <-> air pressure: improper relationship
    16455 P0071 Ambient temperature sensor-G17
    16456 P0072 Ambient temperature sensor-G17: too low signal
    16457 P0073 Ambient temperature sensor-G17: too high signal
    16458 P0074 Ambient temperature sensor-G17: open circuit
    16473 P0089 fuel metering valve: implausible signal
    16474 P0090 fuel metering valve, a failure in the electrical circuit
    16475 P0091 fuel metering valve, a short to ground
    16476 P0092 fuel metering valve: short to positive
    16481 P0097 Sensor -2- IAT G299: too low signal
    16482 P0098 Sensor -2- IAT-G299: too high signal
    16483 P0099 Sensor -2- IAT-G299: no signal
    16485 P0101 Air flow meter-G70: implausible signal
    16486 P0102 Air flow meter-G70: too low signal
    16487 P0103 Air flow meter-G70: too high signal
    16488 P0104 Air flow meter-G70: no signal
    16489 P0105 Pressure Sensor Manifold-G71: Supply Voltage
    16490 P0106 ​​Inlet pressure / air pressure => - G71 / -F96: implausible signal
    16491 P0107 Inlet pressure / air pressure => - G71 / -F96: too low signal
    16492 P0108 Inlet pressure / air pressure => - G71 / -F96: too high signal
    16495 P0111 Sensor IAT-G42: implausible signal
    16496 P0112 Sensor IAT-G42: too low signal
    16497 P0113 Sensor IAT-G42: too high signal
    16498 P0114 Sensor IAT-G42: no signal
    16500 P0116 Engine Coolant Temperature Sensor-G62: implausible signal
    16501 P0117 Engine Coolant Temperature Sensor-G62: too low signal
    16502 P0118 Engine Coolant Temperature Sensor-G62, the signal level is too high
    16504 P0120 Throttle potentiometer-G69, a fault in the electrical circuit
    16505 P0121 Throttle potentiometer-G69, unreliable signal
    16506 P0122 Throttle potentiometer-G69: too low signal
    16507 P0123 Throttle potentiometer-G69: too high signal
    16509 P0125 temperature not reached coolant for lambda control
    16512 P0128 valve in the coolant circuit-N214: the temperature is below the control range
    P0130 16514 Bank 1 Sensor 1: failure in the electric circuit
    P0131 16515 Bank 1 Sensor 1: low voltage
    P0132 16516 Bank 1 Sensor 1 voltage too high
    P0133 16517 Bank 1 Sensor 1: reaction time is too long
    P0134 16518 Bank 1 Sensor 1: No Activity
    P0135 16519 Bank 1 Sensor 1: failure in the electric circuit of heating
    P0136 16520 Bank 1 Sensor 2: failure in the electric circuit
    P0137 16521 Bank 1 Sensor 2: low voltage
    P0138 16522 Bank 1 Sensor 2 voltage too high
    P0139 16523 Bank 1 Sensor 2: Too low speed signal
    P0140 16524 Bank 1 Sensor 2: No Activity
    P0141 16525 Bank 1 Sensor 2: failure in the electric circuit of heating
    P0142 16526 Bank 1 Sensor 3: failure in the electric circuit
    P0143 16527 Bank 1 Sensor 3: voltage too low
    P0144 16528 Bank 1 Sensor 3: too high voltage
    P0145 16529 Bank 1 Sensor 3: reaction time is too long
    P0146 16530 Bank 1 Sensor 3: No Activity
    P0147 16531 Bank 1 Sensor 3: failure in the electric circuit of heating
    16533 P0149 system to determine the fuel-vozd.smesi (number 1): deviation of the injection time
    16534 P0150 Series 2 Sensor 1: failure in the electric circuit
    16535 P0151 Series 2 Sensor 1: low voltage
    16536 P0152 Series 2 Sensor 1 voltage too high
    16537 P0153 Series 2 Sensor 1: reaction time is too long
    16538 P0154 Series 2 Sensor 1: No Activity
    16539 P0155 Series 2 Sensor 1: failure in the electric circuit of heating
    16540 P0156 Series 2 Sensor 2: failure in the electric circuit
    16541 P0157 Series 2 Sensor 2: low voltage
    16542 P0158 Series 2 Sensor 2 voltage too high
    16543 P0159 Series 2 probe 2, the reaction time is too long
    16544 P0160 Series 2 Sensor 2: No Activity
    16545 P0161 Series 2 Sensor 2: failure in the electric circuit of heating
    16546 P0162 Series 2 Sensor 3: failure in the electric circuit
    16547 P0163 Series 2 Sensor 3: voltage too low
    16548 P0164 Series 2 Sensor 3: too high voltage
    16549 P0165 Series 2 Sensor 3: reaction time is too long
    16550 P0166 Series 2 Sensor 3: No Activity
    16551 P0167 Series 2 Sensor 3: failure in the electric circuit of heating
    16554 P0170 Series 1: failure of the system to determine the fuel-vozd.smesi
    16555 P0171 Series 1, the system of determining the parameters of fuel-vozd.smesi: too lean
    16556 P0172 Series 1, the system of determining the parameters of fuel-vozd.smesi: the mixture is too rich
    16557 P0173 Series 2: The failure of the system to determine the fuel-vozd.smesi
    16558 P0174 Series 2, the system of determining the parameters of fuel-vozd.smesi: too lean
    16559 P0175 Series 2, the system of determining the parameters of fuel-vozd.smesi: the mixture is too rich
    16561 P0177 Fuel Quality Sensor G446: implausible signal
    16562 P0178 Fuel Quality Sensor G446: Travel lower limit value
    16563 P0179 Fuel Quality Sensor G446: the upper limit value is exceeded
    16565 P0181 Fuel temperature sensor-G81: implausible signal
    16566 P0182 Fuel temperature sensor-G81: short to ground
    16567 P0183 Fuel temperature sensor-G81: open circuit / short to positive
    16570 P0186 Fuel Temperature Sensor 2-G248: implausible signal
    16571 P0187 Fuel Temperature Sensor 2-G248: Short to Ground
    16572 P0188 Fuel Temperature Sensor 2-G248: short to positive
    16574 P0190 Fuel pressure-G247: a failure in the electrical circuit
    16575 P0191 Fuel pressure-G247: implausible signal
    16576 P0192 Fuel pressure-G247: Short to Ground
    16577 P0193 Fuel pressure-G247: short to positive
    16578 P0194 Fuel pressure-G247: open circuit
    16580 P0196 Oil temperature sensor-G8: invalid signal
    16581 P0197 Oil temperature sensor-G8: the signal level is too low
    16582 P0198 Oil temperature sensor-G8: the signal level is too high
    16584 P0200 Injectors: failure in the electric circuit
    16585 P0201 Injector 1-N30: a failure in the electrical circuit
    16586 P0202 Injector 2-N31: a failure in the electrical circuit
    16587 P0203 Injector 3-N32: a failure in the electrical circuit
    16588 P0204 Injector 4-N33: a failure in the electrical circuit
    16589 P0205 Injector 5-N83: a failure in the electrical circuit
    16590 P0206 Injector 6-N84, a failure in the electrical circuit
    16591 P0207 Injector 7-N85: a failure in the electrical circuit
    16592 P0208 Injector 8-N86: a failure in the electrical circuit
    16593 P0209 Injector 9-N299: a failure in the electrical circuit
    16594 P0210 Injector 10-N300: a failure in the electrical circuit
    16595 P0211 Injector 11-N301: a failure in the electrical circuit
    16596 P0212 Injector 12-N302: a failure in the electrical circuit
    16599 P0215 Fuel Shutoff Valve-N109: malfunction
    16600 P0216 injection timing control valve-N108: malfunction
    16603 P0219 exceeded the maximum engine speed
    16605 P0221 angle sensor 2 throttle actuator-G188: implausible signal
    16606 P0222 angle sensor 2 throttle actuator-G188: too low signal
    16607 P0223 angle sensor 2 throttle actuator-G188: too high signal
    16609 P0225 Accelerator Pedal Position Sensor-G79: Supply Voltage
    16610 P0226 Sensors 1/2 accelerator pedal-G79 + G185: implausible signal
    16611 P0227 Accelerator Pedal Position Sensor-G79: too low signal
    16612 P0228 Accelerator Pedal Position Sensor-G79: too high signal
    16614 P0230 Fuel pump relay-J17, a failure in the electrical circuit
    16618 P0234 wastegate: the output of the control range (greater than the upper limit)
    16619 P0235 wastegate: the output of the control range (below the lower limit)
    16620 P0236 Boost pressure sensor: implausible signal
    16621 P0237 Boost Pressure Sensor: too low signal
    16622 P0238 Boost Pressure Sensor: too high signal
    16624 P0240 Sensor 2 boost pressure-G447: implausible signal
    16625 P0241 Sensor 2 boost pressure-G447: too low signal
    16626 P0242 Sensor 2 boost pressure-G447, the signal level is too high
    16627 P0243 Solenoid. Reduced valve. boost pressure-N75: open circuit / short to earth
    16629 P0245 Solenoid. Reduced valve. boost pressure-N75: short to ground
    16630 P0246 Solenoid. Reduced valve. boost pressure-N75: short to positive
    16633 P0249 Solenoid. valve 2 is bounded. boost pressure-N774: open circuit / short to earth
    16634 P0250 Solenoid. valve 2 is bounded. boost pressure-N774: short to positive
    16635 P0251 Faulty high pressure pump
    16636 P0252 Regulation of the start of injection, the control range
    16645 P0261 Injector 1-N30: short to ground
    16646 P0262 Injector 1-N30: short to positive
    Deviation 16647 P0263 fuel injection quantity on the cylinder 1
    16648 P0264 Injector 2-N31: short to ground
    16649 P0265 Injector 2-N31: short to positive
    Deviation 16650 P0266 fuel injection quantity on the cylinder 2
    16651 P0267 Injector 3-N32: short to ground
    16652 P0268 Injector 3-N32, short to positive
    Deviation 16653 P0269 fuel injection quantity on the cylinder 3
    16654 P0270 Injector 4-N33: short to ground
    16655 P0271 Injector 4-N33: short to positive
    Deviation 16656 P0272 fuel injection quantity on the cylinder 4
    16657 P0273 Injector 5-N83: short to ground
    16658 P0274 Injector 5-N83: short to positive
    Deviation 16659 P0275 fuel injection quantity on the cylinder 5
    16660 P0276 Injector 6-N84: short to ground
    16661 P0277 Injector 6-N84: short to positive
    Deviation 16662 P0278 fuel injection quantity on cylinder 6
    16663 P0279 Injector 7-N85: short to ground
    16664 P0280 Injector 7-N85: short to positive
    Deviation 16665 P0281 fuel injection quantity on the cylinder 7
    16666 P0282 Injector 8-N865: short to ground
    16667 P0283 Injector 8-N86: short to positive
    Deviation 16668 P0284 fuel injection quantity on the cylinder 8
    16669 P0285 Injector 9-299: short to ground
    16670 P0286 Injector 9-299: short to positive
    16672 P0288 Injector 10-N300: short to ground
    16673 P0289 Injector 10-N300: short to positive
    16675 P0291 Injector 11-N301: short to ground
    16676 P0292 Injector 11-N301: short to positive
    16678 P0294 Injector 12-N302: short to ground
    16679 P0295 Injector 12-N302: short to positive
    16683 P0299 wastegate, the output of the control range (below the lower limit)
    16684 P0300 Misfire Detected
    16685 P0301 Cylinder 1: Misfire detected
    16686 P0302 Cylinder 2: Misfire detected
    16687 P0303 Cylinder 3: Misfire detected
    16688 P0304 Cylinder 4: Misfire detected
    16689 P0305 Cylinder 5: Misfire detected
    16690 P0306 Cylinder 6: Misfire detected
    16691 P0307 Cylinder 7: Misfire detected
    16692 P0308 Cylinder 8: Misfire detected
    16693 P0309 Cylinder 9: Misfire detected
    16694 P0310 Cylinder 10: Misfire detected
    16695 P0311 Cylinder 11: Misfire detected
    16696 P0312 Cylinder 12: Misfire detected
    16697 P0313 Misfire Detected, reason: lack of fuel
    16698 P0314 Misfire in separate cylinders
    16702 P0318 Inform. on a bad road / mot given moment. Control of the unit. ABS: a failure in the electrical circuit
    16705 P0321 engine speed sensor-G28: implausible signal
    16706 P0322 engine speed sensor-G28: no signal Error 16708 P0324 knock control
    16709 P0325 Knock Sensor 1-G61: a failure in the electrical circuit
    16710 P0326 Knock Sensor 1-G61: implausible signal
    16711 P0327 Knock Sensor 1-G61: too low signal
    16712 P0328 Knock Sensor 1-G61: too high signal
    16715 P0331 Knock Sensor 2-G66: implausible signal
    16716 P0332 Knock Sensor 2-G66: too low signal
    16717 P0333 Knock Sensor 2-G66: too high signal
    16719 P0335 engine speed sensor-G28: malfunction
    16720 P0336 engine speed sensor-G28: no wave
    16721 P0337 Crankshaft Position Sensor => sensor-G4, the signal level is too low
    16724 P0340 Camshaft position sensor, malfunction
    16725 P0341 Camshaft position sensor => sensor-G40: implausible signal
    16726 P0342 Camshaft position sensor => sensor-G40: too low signal
    16727 P0343 Camshaft position sensor => sensor-G40: too high signal
    16729 P0345 Camshaft position sensor => sensor-G163: a failure in the electrical circuit
    16730 P0346 Camshaft position sensor => sensor-G163: implausible signal
    16731 ​​P0347 Camshaft position sensor => sensor-G163: Short to Ground
    16732 P0348 Camshaft position sensor => sensor-G163: short to positive
    16735 P0351 ignition control, cylinder 1: malfunction
    16736 P0352 ignition control, cylinder 2: malfunction
    16737 P0353 Control ignition cylinder 3: malfunction
    16738 P0354 ignition control, cylinder 4: malfunction
    16739 P0355 ignition control, cylinder 5: malfunction
    16740 P0356 ignition control, cylinder 6: malfunction
    16741 P0357 ignition control, cylinder 7: malfunction
    16742 P0358 ignition control, cylinder 8: malfunction
    16743 P0359 ignition control, cylinder 9: malfunction
    16744 P0360 Control ignition cylinder 10: malfunction
    16745 P0361 Control ignition cylinder 11: malfunction
    16746 P0362 Control ignition cylinder 12: malfunction
    16749 P0365 Camshaft position sensor => sensor-G300: malfunction
    16750 P0366 Camshaft position sensor => sensor-G300: implausible signal
    16751 P0367 Camshaft position sensor => sensor-G300: too low signal
    16752 P0368 Camshaft position sensor => sensor-G300: too high signal
    16764 P0380 Glow plug-Q6: failure in the electric circuit
    16774 P0390 Camshaft position sensor => sensor-G301: malfunction
    16775 P0391 Camshaft position sensor => sensor-G301: implausible signal
    16776 P0392 Camshaft position sensor => sensor-G301: too low signal
    16777 P0393 Camshaft position sensor => sensor-G301: too high signal
    16784 P0400 EGR: malfunction
    16785 P0401 EGR: too low bandwidth
    16786 P0402 EGR: too high bandwidth
    16787 P0403 EGR valve-N18: malfunction
    16788 P0404 EGR, the control range
    16789 P0405 temperature sensor in the EGR-G98: too low signal
    16790 P0406 temperature sensor in the EGR-G98: too high signal
    16791 P0407 EGR potentiometer-G212: too low signal
    16792 P0408 EGR potentiometer-G212: too high signal
    16794 P0410 secondary air supply system: malfunction
    16795 P0411 secondary air supply system: reducing bandwidth
    16796 P0412 Control valve for secondary air-N112: a failure in the electrical circuit
    16797 P0413 Control valve for secondary air-N112: open circuit
    16798 P0414 Control valve for secondary air-N112: short circuit
    16799 P0415 valve 2 controls the secondary air-N320: a failure in the electrical circuit
    16800 P0416 valve 2 controls the secondary air-N320: open circuit
    16801 P0417 valve 2 controls the secondary air-N320: short circuit
    16802 P0418 secondary air pump relay-J299: malfunction
    16803 P0419 Secondary air pump relay 2-J545: malfunction
    16804 P0420 Series 1, catalyst system: loss of efficiency
    16805 P0421 Front catalyst, row 1: decrease in efficiency
    16806 P0422 Series 1, a basic catalyst: reduction efficiency
    16811 P0427 Catalyst Temperature Sensor 1-G20: short to ground
    16812 P0428 Catalyst Temperature Sensor 1-G20: short to positive
    16814 P0430 catalyst system, a series of 2: reduction efficiency
    16815 P0431 Front catalyst, row 2: decrease in efficiency
    16816 P0432 Series 2, the main catalyst: reduction efficiency
    16820 P0436 Catalyst Temperature Sensor 2-G132, unreliable signal
    16821 P0437 Catalyst Temperature Sensor 2-G132: Short to Ground
    16822 P0438 Catalyst Temperature Sensor 2-G132: short to positive
    16824 P0440 tank ventilation system: the failure of
    16825 P0441 tank ventilation system: reducing bandwidth
    16826 P0442 tank ventilation system: A small leak
    16827 P0443 Solenoid valve 1 activated charcoal canister-N80: a failure in the electrical circuit
    16828 P0444 Solenoid valve 1 activated charcoal canister-N80: open circuit
    16829 P0445 Solenoid valve 1 activated charcoal canister-N80: short circuit
    16833 P0449 Solenoid valve 2 activated charcoal canister-N115: a failure in the electrical circuit
    16836 P0452 Pressure sensor circuit in the ventilation system fuels. Tank: too low signal
    16837 P0453 Pressure sensor circuit in the ventilation system fuels. Tank: too high signal
    16839 P0455 tank ventilation system: A major leak
    16840 P0456 tank ventilation system: A small leak
    16842 P0458 Solenoid valve 1 activated charcoal canister-N80: short to ground
    16843 P0459 Solenoid valve 1 activated charcoal canister-N80: short to positive
    16845 Signal P0461 fuel level: invalid signal
    16846 P0462 Sensor fuel reserve-G: too low signal
    16847 P0463 Sensor fuel reserve-G: too high signal
    16854 P0470 Exhaust Pressure Sensor 1-G450: open circuit
    16855 P0471 Exhaust Pressure Sensor 1-G450: implausible signal
    16856 P0472 Exhaust Pressure Sensor 1-G450: Short to Ground
    16857 P0473 Exhaust Pressure Sensor 1-G450: short to positive
    16864 P0480 Radiator fan 1: failure in the electric circuit
    16865 P0481 Radiator fan 2: failure in the electric circuit
    16873 P0489 EGR Control: short to ground
    16874 P0490 EGR Control: short to positive
    16875 P0491 secondary air supply system, a series of 1: reducing bandwidth
    16876 P0492 Series 2, secondary air supply system: malfunction
    16882 P0498 Solenoid valve 2 activated charcoal canister-N115: too low signal
    16883 P0499 Solenoid valve 2 activated charcoal canister-N115: too high signal
    16885 P0501 Vehicle speed sensor: implausible signal
    16886 P0502 Vehicle speed sensor, the signal level is too low
    16887 P0503 Vehicle speed sensor, the signal level is too high
    16889 P0505 Idle control system: the failure of
    16890 P0506 Idle control system: rpm below rated value
    16891 P0507 regulation system idle revs higher than the nominal value
    16894 P0510 Throttle position sensor (switch operates when the DMZ in the position corresponding to XX) -F60: malfunction
    16897 P0513 Invalid code immobilizer
    16915 P0531 Load signal from air conditioning compressor: implausible signal
    16916 P0532 Pressure Sensor circuit conditioner-G65: too low signal
    16917 P0533 Pressure Sensor circuit conditioner-G65: too high signal
    16928 P0544 Exhaust gas temperature sensor 1-G235: a failure in the electrical circuit
    16929 P0545 Exhaust gas temperature sensor 1-G235: Short to Ground
    16930 P0546 Exhaust gas temperature sensor 1-G235: short to positive
    16931 P0547 Exhaust gas temperature sensor 1, row 2-G236: a failure in the electrical circuit
    16932 P0548 Exhaust gas temperature sensor 1, row 2-G236: Short to Ground
    16933 P0549 Exhaust gas temperature sensor 1, row 2-G236: short to positive
    16934 P0550 Pressure regulator on the power steering: a failure in the electrical circuit
    16935 P0551 Pressure switch in the circuit of the amplifier of a steering-F88: implausible signal
    16944 P0560 Power Supply: implausible signal
    16945 P0561 unstable voltage supply
    16946 P0562 Power supply: voltage too low
    16947 P0563 Power: Too high voltage level
    16952 P0568 switch the cruise control: invalid signal
    16955 P0571 brake light switch-F: implausible signal
    16981 P0597 Thermostat electronic control engine cooling system-F265, an open circuit
    16982 P0598 Thermostat electronic control engine cooling system-F265: short to ground
    16983 P0599 Thermostat electronic control engine cooling system-F265: short to positive
    16984 P0600 Data Bus Drive: no message
    16985 P0601 Faulty control unit
    16986 P0602 Programming control units malfunction
    16987 P0603 Faulty control unit
    16988 P0604 Faulty control unit
    16989 P0605 Faulty control unit
    16990 P0606 Faulty control unit
    16991 P0607 Control Module: invalid data
    16992 P0608 Power supply to sensors and perform. mechanisms
    16993 P0609 Power supply 2 at the sensors and perform. mechanisms
    16994 P0610 Engine control unit: improper coding
    16997 P0613 processor is faulty gearbox control unit
    16998 P0614 Transmission Control Unit: incorrect software version
    16999 P0615 supply a control signal to the starter relay, open circuit
    Sep 09 2010
    Destin, FL
    Sep 09 2010
    Destin, FL
    I've never had an issue... until today. Here's my issue.
    From what I've read, I need to clean or get a new sensor.
    https://www.ecstuning.com/Audi-B8_A4...sors/ES275346/
    - The turbo boost pressure sensor A is contaminated or clogged with debris or carbon deposits.
    - The turbo boost pressure sensor A is slow to respond to changing pressure due to deterioration with age.
    Address 01: Engine Labels: 06H-907-115-CAB.clb
    Control Module Part Number: 8K2 907 115 AL HW: 8K2 907 115 D
    Component and/or Version: 2.0l R4/4V TF H16 0001
    Software Coding: 0104010A190F0160
    Work Shop Code: WSC 27637 002 1048576
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F3C6F0F8302E8AE7-802C
    2 Faults Found:
    7019 - Oxygen (Lambda) Sensor Signal B1 S2
    P2271 00 [096] - too Rich
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 67988 km
    Date: 2016.07.12
    Time: 11:57:04
    Engine speed: 2510.00 /min
    Normed load value: 7.1 %
    Vehicle speed: 113 km/h
    Coolant temperature: 96 °C
    Intake air temperature: 36 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.112 V
    Unlearning counter according OBD: 18
    4173 - Manifold Pressure / Boost Sensor (G31)
    P0236 00 [237] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 68298 km
    Date: 2016.08.08
    Time: 11:02:26
    Engine speed: 831.50 /min
    Normed load value: 26.7 %
    Vehicle speed: 0 km/h
    Coolant temperature: 49 °C
    Intake air temperature: 44 °C
    Voltage terminal 30: 12.557 V
    Unlearning counter according OBD: 40
    Readiness: 0000 0000
    Well, looks like that was the obvious problem since the code does most of the trouble shooting for you but this has never happend before. I might take my front bumper off and take off the piping and intercooler to drain out whatever oil is in there.
    There was a little bit of oil on the outer part and not sure how it got there. It wasn't loose and I'm guessing it blew out through the green seal.
    You can see it's clearly covering the senor and messed with the readings.
    Update: I took the front bumper and piping off to find a little bit of oil as expected. I cleaned it out and cleared the codes, haven't had an issue since doing so. Very odd for this to happen but now it's on here for anyone else.
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    Can anyone lead me in the direction of solving the p1627 code? Is this directly related to the hpfp??
    Car is sitting in my driveway and just keeps cranking over and over but won't start.
    Battery is good, fuses are good, could replace the sensors but I just pulled this code....
    "P1627 - data bus powertrain missing message from fuel injection pump"
    Sent from my beeper
    @martino_motorsport
    Sep 25 2010
    Syracuse, NY
    No one has had this code??
    Sent from my beeper
    @martino_motorsport
    May 27 2016
    Maine
    Quote Originally Posted by 968Reckless View Post
    Sent from my beeper
    I just got this code last week but the car seems to be running normally
    Engine
    Part #: 8K2907115AL
    Coding: 0104010A180F0160 (hex)
    Component: 2.0l R4/4V TF
    Fault codes:
    P1627 Data-Bus Powertrain, Missing Message from Fuel Injection Pump
    Tim R.
    2010 A4q MT Premium+, Brilliant Black
    Injen intake
    Eiback Sportline Springs
    Sep 25 2010
    Syracuse, NY
    Quote Originally Posted by Tim R. View Post
    Engine
    Part #: 8K2907115AL
    Fault codes:
    Hmm that's so weird. I can't even start the car, the engine just keeps cranking but won't turn over. I wonder if a sensor went bad.....
    Sent from my beeper
    @martino_motorsport
    Senior Member Three Rings itlnstallion818's Avatar
    Apr 28 2013
    Columbus, OH
    2013 A4 6MT, stage 2
    P19A0:
    1 Fault Found:
    10335 - Thermostat for Transmission
    P19A0 00 [047] - Short to Plus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 139116 km
    Date: 2016.07.31
    Time: 10:49:44
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Coolant temperature: 51 °C
    Intake air temperature: 46 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 11.897 V
    CAN status - engine control module-Bit 0: 0
    CAN status - transmission control module-Bit 0: 0
    CAN status - brake control module 1-Bit 0: 0
    CAN status - brake control module 2-Bit 0: 0
    selected gear-Bit 0: 0
    2013 Scuba Blue A4 | S-line Prestige | AVG M590 | K&N Typhoon | VCDS | 034 HFC
    May 27 2016
    Maine
    Sent from my beeper
    Did you get this sorted out?
    Tim R.
    Injen intake
    Sep 25 2010
    Syracuse, NY
    No I'm not sure what it was but I took the car to the dealership.....timing chain stretched, rocker was screwed up along with valves. Car only has 72k on the clock and the chain already went....wonderful.
    Sent from my beeper
    @martino_motorsport
    May 27 2016
    Maine
    Sent from my beeper
    Sorry to hear that. Did the tensioner go? Why the fuel injection pump message?
    Tim R.
    Injen intake
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    @The Infiltrator I can't tell form your sig but are you running a catch can? When i put on my cts fmic i also installed their catch can and my MAP so far is completely dry, no residue at all. probably 8-10k miles. Conversely, when I took the factory silicon hoses off prior to install, oil came out of both sides of my stock FMIC FWIW.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Sep 25 2010
    Syracuse, NY
    Yeah believe it was the tensioner. I'm not sure why that code was thrown. Maybe as a result of no compression but the engine still cranking?
    The worst part is this is my girlfriends car and that same day it broke she had bought a new car a few hours prior. We planned on taking pics and listing it that night. I would have felt bad though if someone bought it and had that happen hours later.
    Sent from my beeper
    @martino_motorsport
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by IHave2Turbos View Post
    I do have their catch can. It's off right now since I'm doing the oil consumption process. Not sure how it got in there but there's a first for everything. Lol
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    I got a code a while back that I still havent been able to track down. Since this thread is here, figured I'd post it up to see if anyone has info. The code I got is not on the above lists, and despite all my searches, I have yet to find any information on it. It was a one time fault thankfully, but man, since I cant find ANYTHING related to this for B8s, maybe the AZ knowledge base can help...
    VAG Scan:
    Component and/or Version: 2.0l R4/4V TF H12 0001
    Software Coding: 010C010A190F0160
    Work Shop Code: WSC 01126 444 12187
    VCID: 79F22E1EF827F0E9285-802C
    1 Fault Found:
    7021 - MIL Request Signal Active (Check TCM for errors too!)
    P1624 00 [104] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    For reference, I checked the TCM and it did not have any faults.
    Oct 10 2016
    Colorado
    I just got a 2011 A4. It has check engine light on and after scanning with a reader at OReilly, I got two error codes. P0299 and P0016. The two major issues with this car are:
    Issue 1: when starting, it hesitates. Takes extra few seconds to start. (probably around 4-5 seconds of cranking to start the car)
    Issue 2: when I put it on drive, car is moving but I step on the gas but neither rpm goes up, nor the car picks up speed. It's very sluggish and picks up speed at a very slow rate but eventually it will speed and go faster.
    I'm not sure what is going on with this car mechanically but could you please give me some suggestions if I'm looking at some serious repairs?
    Senior Member Two Rings TurboNate's Avatar
    May 15 2015
    El Cajon/CA/San Diego
    Quote Originally Posted by eclipse1 View Post
    For the P0299, it means underboost. Probably a loose waste gate or something with your turbo that is causing it to not produce enough boost
    As far as P0016, this is your camshaft position sensor, this code usually pops up when there is an issue with timing chain/tensioner
    As far as both of them together, that's going to be pretty pricey to repair. If you're under warranty still I suggest the dealership, if not. Find an indie you can trust. But you should get your car scanned with VCDS just to make sure.
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Established Member Two Rings B8Brit's Avatar
    Sep 27 2016
    NE Ohio
    Just left AUTOZONE and they ran their scanner. P2298 is what it came up as.
    I have a 2011 A4 2.0tq 8spd. Stock for now.
    Sep 09 2010
    Destin, FL
    So I recently have been having issues with all of my car doors unlocking but my drivers door staying locked. Tried the other fob and that didn't work, I did have one code and cleared it for the drivers door, that didn't fix it either.
    Code 02115 - Locking unit
    008 - Implausible Signal - Intermittent
    From what I've read it's the lock assembly / locking drive motor.
    Post#8
    http://www.audi-sport.net/xf/threads...ey-fob.203180/
    Genuine part is $300, so search eBay.
    Part number# 8K0 959 793 B
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by The Infiltrator View Post
    Check this thread, porshe should share same parts but cheaper, number maybe different! Especially post 7!
    http://www.audizine.com/forum/showth...e-with-same-PN
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Gunnark100 View Post
    Not the same part as I have listed. I found one I need for $69 and working on them to drop the price.
    Oct 21 2012
    Earth...
    Lets hope in your case it will be control module which you listed, not the common problem in this case- door lock assembly:)
    Sep 09 2010
    Destin, FL
    The link I have above, the guy fixed it with the control module. But, the link you have, they have the same issue and replaced the locking mechanism.
    Not sure what I should buy now.
    I did find one on ECS.
    https://www.ecstuning.com/b-genuine-...ft/8j1837015f/
    I did find this Porsche one too.
    https://www.parts.com/index.cfm?fuse...-LOCK-ACTUATOR
    EDIT: When I got home last night I flipped the lock around in the door and sprayed WD40 on it, shut the door and cycled the lock/unlock from the fob multiple times. It didn't stick anymore and I tried it again this morning and it's still fine. I'll keep an eye on it but it may have been getting tripped up by something and needed some lube. We will see, at least it's saving me money, for now.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Just a heads up, the B letter at the end is for any car made before 11/2009 and the F is for any made after.
    Sep 09 2010
    Destin, FL
    A little update on this.
    http://www.audizine.com/forum/showth...8#post12124198
    http://www.audizine.com/forum/showth...3#post12106473
    Deactivated Two Rings
    Aug 22 2014
    Netherlands
    Hello. I have the following fault in module 17-Instruments:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 99524 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:54:42
    Resetting the fault does not work, since it will reappear? Anyone any idea?
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by GomegaK View Post
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 99524 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:54:42
    ^ Is this a statement or an actual question? If you haven't tried to reset it, do that first and we will see what step you need to take next.
    Aug 22 2014
    Netherlands
    Sorry for the misunderstanding. It's a statement. I did clear the fault code, but it returns.
    Active Member Two Rings Mr_Skull's Avatar
    Oct 02 2015
    Nashville, TN
    P0100 - MAF - Supply Voltage = Triggers when the sensor wire between the MAF (Pin 3, Black wire w/purple marker) and ECU on a B8.5 A4 / 2013 Allroad breaks. I verified the ground wire and + 5vdc were good before removing the connectors "shroud" to find the broken wire. I'd assume this code could come in if any 3 of the wires broke but that's just an assumption... I also saw 0.0 g/s while viewing the "MAF actual" value while the engine was running after I reviewed the scan text and noticed the MAF code.
    This code was 3 seconds ahead of MULTIPLE other codes which is a testament to save your original scan before attempting to clear and then re-scan. This code also illuminated the TPMS module failure on the dash, ESC module failure on the dash, and check engine light. Dash lit up like a Christmas tree and freaked the wife out since it's her car and I was driving it like I stole it.
    Other codes triggered were:
    Transmission P2637 - Torque management feedback signal A along with multiple descriptions on toque converter lockup. Lot's of other modules had "function restricted due to Faults in other modules." I tried clearing before I found the broke wire and all of these codes returned. The transmission code freaked me out needless to say...
    ABS Brakes - Engine control module - 013 Check DTC Memory
    Parking Brake - 464384 - Function restricted due to Faults in other modules.
    The fix involved removing the pin and splicing in 000979034E "VW/Audi repair wire" which is a yellow wire that included the crimps pre-installed. I lengthened all 3 wires to extend the MAF connector as it apparently had less slack than it needed upon heavy engine loading after installing an aftermarket intake...
    Junior Member Two Rings
    May 18 2015
    westchester
    Just went apr stage 2
    No cel but monitors reading not ready.
    Comments, suggestions, help?
    Sent from my SM-G935T using Tapatalk
    Sep 09 2010
    Destin, FL
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 99524 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:54:42
    http://wiki.ross-tech.com/wiki/index.php/00003
    Active Member Two Rings Krogers's Avatar
    Jan 28 2016
    01 jetta
    Blacksburg,Virginia
    So this is what I got today. Cel, code po420, Sirius xm quit working, epc, tpms, abs, e brake and traction control light all on at same time? Please help!!
    2010 A4 Prestige / Tinted Windows / LED Interior / H&R Sport Springs / ECS 10mm & 17.5mm Spacers / ECS Turbo Inlet Pipe / more coming
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Thanks for putting this together @infiltrator.
    I'm getting a code 00230 Transmission Park Selector Switch (F305) from Carista. I couldn't locate any info on the Ross Tech Wiki but from current research this has happened to Q7s and A6s (there's a TSB for the A6). The symptoms are related in that I am not able to remove the key from the ignition time to time. I have to put it in Acc and then it will usually come out. From what I read there are two switches that work in conjunction to tell the ignition key withdrawal lock to release the key.
    Since I'm getting F305 it sounds like it's the transmission park selector switch but I can't locate any info on this part or a parts diagram. Anyone else have or had this issue and can point me in the right direction?
    Cheers,
    Ry-man
    May 06 2015
    Quote Originally Posted by Krogers View Post
    Did your hazards start blinking as well? I had a very similar issue about a month ago when backing into a spot where there was a decent amount of snow. Had dash lights flashing along with my hazards and they wouldn't shut off until I shut the car off and turned it back on. I never got a code though...
    In any case - this might help for the p0420 code. http://wiki.ross-tech.com/wiki/index...4/P0420/001056.
    Cheers,
    Ry-man
    Jan 28 2016
    01 jetta
    Blacksburg,Virginia
    Quote Originally Posted by CONative View Post
    Thanks for the info. So yesterday I started the search. It happened after I hit a good size pothole so I started checking wheels and found that on the drivers side of my a4 a wire was damaged. I recently installed upper adjustable control arms and had to trim a little metal for them to clear properly. So when I hit that pothole the arm came up and damaged these wires. I never thought it would hit them although I did see them during install. So I sliced them back together and problem solved but not the siris radio problem. It's going to dealer tomorrow not to expensive of a fix.
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    I recently changed my coil pack connectors. I changed them because I had a misfire code and determined my r8 coil packs and recently changed plugs were fine. I do need to change one more connector that is located on a cam solenoid actuator. Now the car has been running fine, no issues other than some licence plate led flickering, that seemed to happen after I Adjusted my DRL brightness with carista. Weird.... I have searched but unable to figure out what these codes are. The codes are specific to engine I believe. Anyone familiar with these codes??
    Sent from my SM-G925P using Tapatalk
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Fastbke170 View Post
    Are those codes from before you replaced the coil packs? If so, clear them and see if they come back.
    May 01 2015
    Northport
    The codes were after. After running vcds the codes were due to cam actuator connector. After repairing the connector all but one code remains 7219. Carista app showing the code. Car is running fine. Checked all connectors to cam actuators and all seem fine.
    Sent from my SM-G925P using Audizine mobile app
    Veteran Member Three Rings Olde_English's Avatar
    Dec 07 2016
    Singlespeed S-Works Epic Hardtail and Specialized Epic Evo
    Prescott, AZ
    Anyone know what 02615: Locking fuel tank cap or 02616: unlocking fuel tank cap codes mean? I have a new gas cap on, not sure if these affect anything though.
    Established Member Two Rings AWellman's Avatar
    Jul 21 2011
    2000 audi s4
    Cincinnati, OH
    What was wrong with the connector? i too am having this fault:
    7213 - Cam Adjustment Actuator A; Cylinder 2
    P11A5 00 [109] - Elec. Malf. or Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 148186 km
    Date: 2017.01.29
    Time: 00:25:16
    Engine speed: 182.00 /min
    Normed load value: 42.4 %
    Coolant temperature: 8 °C
    Intake air temperature: 8 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 10.107 V
    2009 A4|STOCK|DAILY|
    2000 S4|APR STAGE 3 + METH|APR 93 METH BETA TUNE| (SOLD)
