Results 1 to 10 of 10
    Registered User Four Rings CTS Turbo's Avatar
    Nov 12 2008
    01 S4, 04 A4, 15 GTI, 15 S3
    Vancouver
    CTS Turbo Audi A4 B8 & B8.5 Product List
    Hello Audizine! CTS Turbo is proud to offer a large assortment of products for the B8 & B8.5 A4.
    ctsturbo.com is our website, We have a massive online store to take care of all your shopping needs.
    B8 A4 Front Mount Intercooler Kit $849.99
    Click here for ordering
    The new CTS Turbo B8/B8.5 A4 FMIC kit will enhance the performance and power of your vehicle substantially by maintaining lower charged air temperatures even under the most extreme abuse. Boasting a high density bar and plate intercooler core (rated for 600HP) the CTS FMIC kit is ideal for modified B8 A4's with K03, K04 or even big turbo applications. Smooth transitions in our hand crafted intercooler piping ensure quick boost response and optimal flow while the aluminum piping ensures maximum heat dissipation. Fitting an intercooler this size is no easy task, but our design requires absolutely no trimming to the bumper or bumper reinforcement.
    Product details:
    - High density bar and plate intercooler core
    - Core dimensions 20" x 11" x 3"
    - 2.5" hand fabricated, powder-coated aluminum piping
    - Stainless steel T-bolt clamps and 4 ply silicon connectors
    - Bead rolled pipe ends to prevent hoses popping off
    B8 A4 Catch Can Kit $449.99
    Introducing the all-new CTS Turbo oil catch can kit for B8 Audi A4 TFSI and B8 Audi A5 2.0TFSI (TSI motors).
    The oil catch can is used prevent oil vapors entering the intake manifold and clogging up the intake valves on direct-injection motors. Oil deposits on intake manifold and valves cause reduced performance, bad fuel mileage and could damage the fragile intake “flaps” and motor.
    Kit Includes:
    CTS Turbo billet aluminum valve cover breather – CNC machined for beautiful finish
    CTS Turbo Billet aluminum catch can with billet oil-level dipstick
    -10 AN Black-Series braided hoses
    Clamp-on style catch can mounting bracket
    Modular intake manifold plug
    Hose-Wrangler clamp
    Kit Fits:
    · 2008+ B8 Audi A4 2.0 TFSI
    · 2008+ B8 Audi A5 2.0 TFSI
    Click here to see a video of one of our kits being emptied
    All installation hardware is included as well as o-ring for the rear PCV breather.
    Keep your B8 Audi A4 or A5 running smooth, clean and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
    FREE SHIPPING ON ONLINE ORDERS!
    B8 A4 2.0 BorgWarner K04 Turbo Upgrade Kit $2399.99
    The heart of the CTS Turbo B8 A4 2.0T turbo upgrade kit is the Borg Warner K04-0064 turbocharger. This turbocharger is commonly used in OEM applications such as the Audi S3 available in Europe. The highlight of this Borg Warner turbocharger in our kit is the 'forged mill' compressor wheel, which brings numerous benefits to the enthusiast. The technology used in the production of these turbos provides us with a variety of benefits, reduced compressor wheel weight (faster spool), increased strength, and greater surface area of the compressor wheel. Because of the 'forged mill' technology Borg Warner can increase the effective surface area of the compressor wheel, which results in greater air flow than conventional cast compressor wheels.
    In addition to the Borg Warner K04-0064 the CTS Turbo B8 A4 2.0T turbo upgrade kit uses a set of custom silicon hoses to relocate the factory diverter valve. Our diverter valve relocation uses the same principles as the OEM Audi S3, Audi TTS and Golf R. In addition to the diverter valve relocation our kit includes a new diverter valve housing to relocate the diverter valve, associated OEM gaskets, nuts, studs and hardware and test pipe to connect to your factory downpipe. This kit is by far the best 'bang for the buck' modification available for B8 enthusiasts with the 2.0T engine.
    B8 A4 Silicone Intercooler Hose kit $199.99
    CTS Turbo now offers a full silicone intercooler hose set for the B8 Audi A4/A5 2.0T FSI. The hoses that come stock with your car age and deteriorate over time. This will lead to inevitable boost leaks leading to loss of power and increased wear on the turbo. CTS Turbos hoses are far more durable and are guaranteed to not crack. Our super rigid construction eliminates hose expansion and deformation under high boost pressure. Included in the kit is our Billet Aluminum 2.25" Turbo Outlet Adapter.
    A recommended addition to this kit is our B8 A4 Turbo Inlet Hose. Click here for more info. Seen below.
    B8 A4/A5 Silicone Turbo Inlet Hose $69.99
    Turning up the boost in your car increases wear on your stock rubber turbo inlet hose. Eliminate cracking, stretching and deformation with this CTS Turbo B8 A4/A5 Silicone Turbo Inlet Hose. Increased rigidity and higher flow mean less restriction and more power.
    This is a recommended addition to our B8 A4/A5 Intercooler Hose Set seen here. Seen above.
    B8 A4 Test Pipe/HFC $174.99
    The CTS B8 A4/A5 2.0T test pipe is the premier test pipe for your Audi A4 or A5 2.0T. Our test pipe is designed to seamlessly fit in place of your restrictive stock catalytic converter, which is situated immediately after the turbocharger. Our test pipe features 3" stainless steel piping, smooth mandrel bends, two 02 sensor bungs with an option for a third. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our test pipe. Upon inspection you will notice a flare which is nearly 4", this flare then tapers to 3" and is designed to allow for optimal flow as the exhaust gas transitions from the turbocharger to the test pipe. In addition to being one of the best bang for the buck performance upgrades for A4/A5 owners our test pipe is also very attractive piece. Each 3" test pipe is mandrel bent, hand tig welded and comes with the standard CTS swag (lanyard and plate frame). Do you need an additional 02 bung for data logging? Well that's no problem! Tig welding additional 02 bungs can be done for an additional charge.
    Product Details:
    T304 stainless steel construction
    Mandrel bent stainless steel
    Fully tig welded design
    Optional third 02 bung
    Install hardware included
    Throaty sound
    Great power upgrade
    B8 Audi A4/A5 Downpipe $399.99
    The CTS B8 A4/A5 2.0T downpipe is the premier downpipe for your Audi A4 or A5 2.0T. Our downpipe is designed to seamlessly fit in place of your restrictive stock downpipe, which is situated immediately after your Catalytic converter/Test Pipe/HFC. Our Downpipe features 3" stainless steel piping, smooth mandrel bends, and a stainless steel flex section. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our downpipe. In addition to being one of the best bang for the buck performance upgrades for A4/A5 owners our test pipe is also very attractive piece. Each 3" test pipe is mandrel bent, and hand tig welded.
    Product Details:
    Versatile flex section
    Throaty sound
    Great power upgrade
    CTS A4 B8 2.0T Exhaust
    CTS Turbo has been dedicated to manufacturing performance parts for enthusiasts by enthusiasts since its inception. Our continued development of the B8 A4 platform is not limitted to FMIC kits or Turbo kits, our all new exhaust system is evidence of that. The CTS Turbo B8 A4 exhaust system is hand tig welded using the finest T304 stainless steel.
    Each CTS B8 A4 exhaust is 100% tig welded, constructed using T304 Seamless Stainless Steel, and includes installation hardware and stainless steel clamps. Lesser products can be had without stainless steel construction, or with seamed stainless steel, which can crack and decay over time. The CTS Turbo B8 A4 exhaust increases turbo spool up, and peak power. Our catback is constructed using 2.5in T304 Stainless steel. It will bolt up directly to the OEM downpipe or our CTS downpipe.
    Product Details:
    - True Stainless steel exhaust
    - Aggressive sound under hard driving, but subtle when cruising
    - Water jet cut flanges
    - CNC mandrel bent stainless steel piping
    - Polished stainless steel exhaust tubing
    - 3" stainless steel exhaust tips
    - Requires the use of Audi rear dual exhaust valence
    - Fits manual and auto transmission cars
    Muffler Delete $129.99
    CTS Turbo is proud to release our high flow Turbo Muffler delete for 1.8T and 2.0T engines equipped with IHI Turbochargers (see application guide below). The CTS Turbo Muffler delete is a one piece design CNC constructed from T6 6061 aircraft grade aluminum and hard anodized to reduce wear. Our Turbo Muffler delete replaces the restrictive, power robbing OEM Turbo Muffler, which is designed to reduce turbocharger harmonic noise. Our kit installs in 30 minutes with hand tools, seals using the included O-ring seal with standard hand tools and looks stealthy like the OEM unit. For those of you that want optimal power and boost response the CTS Turbo Muffler delete is your answer.
    Application Guide:
    Audi - S1 EA888 Gen 3 - 2.0 TFSI
    Audi - A3 & S3 (MK3) - EA888 Gen 3 - 1.8 TFSI and 2.0 TFSI
    Audi - A4 / Allroad (B8 & B8.5) - EA888 Gen 2 & 3 - 2.0 TFSI
    Audi - A5 (B8 & B8.5) - EA888 Gen 2 & 3 - 2.0 TFSI
    Audi - A6 (C6 & C7) - EA888 Gen 2 - 2.0 TFSI
    Audi - Q5 - EA888 Gen 2 & 3 - 2.0 TFSI
    Audi - TT / TTS (MK3) - EA888 Gen 3 - and 2.0 TFSI
    VW - Golf / GTI / R (MK7) - EA888 Gen 3 - 1.8 TSI and 2.0 TSI
    CTS TURBO 2.0T BOV (BLOW OFF VALVE) KIT (EA113, EA888.1) $269.99
    CTS Turbo is proud to release our 2.0T Atmospheric BOV KIT for EA888.1 equipped vehicles. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) is made of billet construction and completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
    Fitment:
    Audi A3 8P (EA113 & EA888.1)
    MKII Audi TT (EA113 & EA888.1)
    MK5 GTI (EA113 & EA888.1)
    MK5 Jetta (EA113 & EA888.1)
    MK6 GTI (EA888.1)
    MK6 Jetta (EA888.1)
    EOS (EA113 & EA888.1)
    Tiguan (EA888.1)
    B6 Passat (EA113 & EA888.1)
    Passat CC (EA888.1)
    Beetle (EA888.1)
    Audi S3 8P (EA888.1)
    Golf R (EA888.1)
    B8 Audi A4 (EA888.1)
    B8 Audi A4 (EA888.3)
    B7 Audi A4 (EA113)
    Product Features:
    T6061 billet aluminum construction
    Black anodized stealth finish
    Fully compatible with OE electronics
    Fully serviceable piston design
    No additional wiring required
    Substantial reliability improvement over OE
    Compact design fits into tight spots easily
    CTS TURBO 2.0T DIVERTER VALVE KIT (EA113, EA888.1) $269.99
    CTS Turbo is proud to release our 2.0T DV (DIVERTER VALVE) KIT for EA113 and EA888.1 equipped vehicles. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT is made of T6061 billet construction and is completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
    Fitment:
    MK6 GTI (EA888.1)
    MK6 Jetta (EA888.1)
    Tiguan (EA888.1)
    Passat CC (EA888.1)
    Beetle (EA888.1)
    Golf R (EA888.1)
    B7 Audi A4 (EA113)
    Product Features:
    CTS B8 A4 TFSI Crank Pulley Kit
    The CTS Turbo crank pulley is lightened to reduce parasitic drag on the engine. This results in faster revving and more horsepower.
    Included in the kit is the lightened crank pulley, replacement OEM bolt and a shorter belt.
    The pulley is made from T6 6061 aircraft grade aluminum and hard anodized to reduce wear. Gains of 5-7 horsepower can be expected.
    NOTE: VW TOOL T10355 IS REQUIRED FOR INSTALLATION
    In addition to our own products above, we are also distributors for the following companies & many more.
    Solo-Werks Coilovers
    ST Coilovers
    SouthBend/DXD Clutches
    If there are any questions, comments or to place an order you can PM or email me at [email protected] or call us at 604-530-3092 - Visit our website at www.ctsturbo.com
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Would this fit the A4 Allroad?
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Nov 12 2008
    Vancouver
    Quote Originally Posted by ed@mtl View Post
    Hello,
    Yes this will fit the Allroad also.
    Let me know if you have any other questions,
    Rob
    Aug 04 2010
    Queenz/Westchester
    I'm sure many enthusiast's have had good results with CTS's products and service, I unfortunately did not:
    http://www.audizine.com/forum/showth...1#post11809152
    Just a warning of what happened to me.
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by shonseb View Post
    Wooow that totally sucks. Thanks for the warning!
    Sent from my iPhone 6s
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    This basically sums up my CTS downpipe experience as well. Their initial reaction was to blame my install. It's a downpipe..... It only goes on one way.
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Nov 12 2008
    Vancouver
    shonseb,
    Just an FYI, I am not sure if you received a tracking number, but you were sent out a new intercooler pipe and it is supposed to be delivered today or tomorrow.
    If you have any questions or concerns please send me a PM or email me directly at [email protected]
    Rob
    Senior Member Two Rings NRigs's Avatar
    May 21 2015
    Ma
    With an additional 10% off the k04 I will buy it right now
    2020 SQ5 Prestige | IE Stage 1 | BMC Air Filter | 034 Transmission Insert
    Gone:
    2011 335xi | Custom Tune | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
    2014 A4 | CTS K04 l Euro Code HFIP l TR11 l 034 Mounts & Inserts l ECS Luft-Technik l DV+ l LED Light Swap l R8 Coils l NGK plugs l RS4 Grille l Niche Targas M129 l Continental DWS 06 l CR-15
    Nov 12 2008
    Vancouver
    Quote Originally Posted by NRigs View Post
    No can do my friend
    Nov 12 2008
    Vancouver
    TTT
