Hey All,
I'm trying my best to avoid a trip to a shop to hunt down the source of my electrical drain. I would really appreciate some help if anyone has seen an issue like this before. I'll do my best to concisely, but thoroughly, explain what is going on here.
My car's battery has been draining from full charge to no start in 2-3 days. When fully charged, the battery tests good as far as voltage while sitting, holding voltage while under starting load, and the alternator is putting about 14volts to the battery at idle as well. The battery is about 4 years old so I am fairly confident the battery and alternator are good.
A couple other things I've observed lately: The fuel pump doesn't prime when I open the door anymore but the car starts and drives just fine, the light that illuminates the window lock stays on ALL the time and so does the light that illuminates the headlight knob. Yes, the dome lights go out when I close the door and the alarm system arms so at least part of the car's brain knows that everything is closed, locked, etc.
In order to start testing the current draw on my car, I closed the drivers door latch and hood latch so the car thinks everything's closed and is willing to lock and arm the security system. Then, I waited for a bit (15-20mins) to let everything power down. Next, I used a multi-meter to test the current draw across the negative terminal connection to the battery. I connected the test leads and THEN disconnected the cable from the negative terminal of the battery to ensure power was not interrupted (I don't no if that is necessary but I didn't want any systems to "wake back up" once I reconnected the power through the multi-meter). The reading I was looking for was 50mA or less, based on several online sources. The reading I got was almost 1A (what?!).
My next step was to go through every single fuse in the fuse panel and check current draw across each circuit (by pulling the fuse and connecting the leads across the panel contacts). Most circuits were pulling single digit mA or fractions of mA.
Here is a list of the circuits that were pulling MUCH more than it seems they should when the car is off, locked, armed:
#1 (A/C) = 143mA
#13 (Steering Column) = 52mA
#15 (Instruments) = 240mA
#17 (Level, Tire Pressure Control) = Fluctuating from 32-75mA every 10sec or so.
#22 (Front Doors) = 32mA
#23 (Rear Doors) = 20mA
#24 & #38 (Central Comfort Electronics) = If both are unplugged I'm reading about 70-80mA across each, with only 1 unplugged I'm reading about 20-30mA.
#39 (Radio) = 71mA
Lastly, no codes on the OBDII system.
I hope this info is enough to cause a 'light bulb' for someone out there. I REALLY don't want to take my car in so someone can charge me hourly for their wild goose chase.
Pete
