Results 1 to 31 of 31
    Account Terminated Four Rings
    Oct 15 2013
    using non VW approved 5W-30 or 5W-20 oils
    i got a good deal on pennzoil platinum oil (full synthetic) and i'm wondering if using it will really be detrimental to the engine. i doubt it but you never know.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    B7 takes 5w40
    Dec 23 2011
    5w20 is not the correct spec oil. 5w40 or 5w30 if in a pinch.
    Oct 15 2013
    Quote Originally Posted by Hugh@EuropaParts View Post
    B7 takes 5w40
    i know. i've only used that and 0W-40. i'm thinking about going on the wild side. the engine runs cool even in the summer so i wonder what this change may do.
    Dec 23 2011
    I don't think 20 weight oil will hold up very well in this car due to the turbo. Also with it being summer time it's not the best idea to run a 20 weight oil.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Rotella T6
    Veteran Member Three Rings grassrootz's Avatar
    Apr 01 2010
    Tampa, FL
    Switched up on the Rotella T6 and ran Mobil 5w-40 for a Florida run from North Jersey and back. No issues at all. Barely burned anything on the entire trip of over 2900 miles. To me the car is running and has been running amazing since the swap. And oil is consumption is gone unless I'm ripping the car and you'll get the plume of carbon deposit.
    I would say on my car which routinely burns a quart of Rotella by 1500-2000mi, Mobil is FTFW. Gonna try it again and see how it works.
    OP: Pennzoil isn't terrible. But never did a full change on it. Tended to burn up fast when I used it to top off in a pinch.
    -GrassRootz
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Rotella T6
    End thread/
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Oct 15 2013
    not the answers i'm looking for with regards to the question. i'll go ahead with the 5W-30.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by esandes View Post
    5w30 is a bit light... lets say you save $20.00 on the oil and you change your oil twice a year. You're saving a total of roughly .01 a day and potentially toasting your turbo.
    TURBOCHARGER (A4 B7 2.0T)
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    lol...you're asking about non VW approved oil in a lower viscosity than required and expect to hear what you want to hear. It's your car, good luck.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    how much are you really saving $24 for a 5qt jug of castrol
    http://www.walmart.com/ip/Castrol-Ed...Quart/35931146
    2018 A5 S-Line Manual
    Oct 15 2013
    i searched around about this question and it was also asked in a passat forum by someone else and someone replied that all he uses is 5W-30. how much savings? $30 saved for a 5 L jug.
    i'm not looking for editorial answers. i want to know from people who have done this.
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    On top of all this, 0w-40 Mobil 1 (Mobil 1!!!) is 22$ a gallon at my walmarts in NH. If I have free cash this week in gonna get 4-5 gallons lol!
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Jul 25 2016
    new hampshire
    And nobody has ran lower viscosity oil in these engines. Theres even a warning about it in the manual, emergencies only and don't use more than a quart of lower viscosity oil. The turbo we'll be eating it like potatoe chips and shit out carbon bricks very quickly. Look into the early 2000's Saab sludge issues. Your pretty much purposely causing the same issue for no reason than to save a couple bucks. Idiotic. Saabs had the issue of them suggesting running 5w-30 in a turbod engine. Nuff said.
    Theres nothing to gain by running the wrong viscosity like that other than maybe wanting to convince your spouse to let you buy a new engine?
    Eric
    Oct 31 2014
    NH
    I bet if you polled this forum most would use Rotella T6.
    - - - Updated - - -
    Quote Originally Posted by pezgoon View Post
    Plaistow?
    Jul 25 2016
    new hampshire
    Quote Originally Posted by adam044 View Post
    - - - Updated - - -
    Plaistow?
    Yep! I don't know if it still is, I sure hope so so I can pick up some before the deal is done! It's been on sale for awhile now too so its probably ending soon!
    I keep seeing an ad on here about Mobil 1 being 27.99 at Advance auto parts too till august something, which is cheaper than autozone's 35$ but I think thats the same as walmarts regular price.
    So glad they started carrying 0w-40 (especially in a gallon!) when I owned my saab, I could only find it in quarts at autozone! 8.99 a quart!
    Eric
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    I actually use vegetable oil in my car. I dont want to hurt the environment. I even gained 5mpg and 20hp on the dyno. Dont use olive oil it burns at a lower temperature.
    Dec 23 2011
    Quote Originally Posted by konarider94 View Post
    Damn dude, think of all the vegetables that had to die just so you can drive your car. I took the Bear Grills approach and just pissed in my engine. Runs great!
    Jul 25 2016
    new hampshire
    Quote Originally Posted by p0isin View Post
    ^ I lol'd
    Eric
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    ESandes at it again......trying to cheap out! CMON man--its an Audi.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    I use Castrol 0-30 european formula since new sometimes 0-40 european formula if the other is not available,
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    https://mobiloil.com/en/promotion/mo...nd-mobil-super
    $11 for 5qt after rebate, limit 2 per address...
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    I'll try that next oil change. Better start saving up now. Anyone have any extra bottles I can use? I prefer at least a Gatorade size cap.
    Oct 15 2013
    here's a quote from the pennzoil site:
    Pennzoil Platinum motor oil meets or exceeds:
    • North American warranty requirements for U.S., European and Japanese cars and light trucks with gasoline and gasoline
    turbo-charged engines where API SM and earlier API categories are specified
    also some history on my car; i ran nothing but mobil 1 0W-40 on the first engine. the oil consumption got worse with time then the oil pump failed at 100,000 miles.
    Dec 04 2011
    Kansas City, KS
    At least you just proved that your an idiot.
    OP: Hey guys, is 5-W30 good for my car?
    everyone on this forum: No!!! use 5W40
    OP: You guys are all wrong and dint answer my question
    Apr 12 2015
    '06 VW TOUAREG (V8), MTN Bike
    FALLON, NV
    Same here in NV!!!
    I'M THE ORIGINAL OWNER OF '07 B7 A4 2.0T 6MT Q (62K): JHM 91 OCT STG 2 | CARBONIO INTAKE | 034 REAR SB | JHM TP | JHM DP-Y | B6 S4 CB
    Jul 25 2016
    new hampshire
    Also I just checked yesterday and 0w-40 is regularly only 25$ at WalMart anyways! (much better than the 37$ at AutoZone)
    Did you have proof the oil caused it? I'm guessing you opened up the engine, did it have oil caked everywhere? If it did, did you regularly let the engine idle after driving to flow oil through the turbo so as not to cook it? Did you do engine flushes to get the caked carbon out? (assuming thats what did it), and theres no proof that going to the incorrect oil weight (especially something that is a lower high temperature limit!) will help to prevent what happened, if anything go to a higher limit! They do sell 5w-50, its diesel oil, expensive as (again WalMart) or even run rotella t6 which is probably what I've going to next oil change, again since its designed for diesels which have larger turbos and more heat. I guess you'll be the guinea pig to see what happens running the (proven) wrong weight in a turbo'd engine for its life and see how long it'll last (well other than all those 2000's Saabs anyways) let us know how it goes!
    Eric
    Oct 15 2013
    Quote Originally Posted by vvenom800tt View Post
    look at all of the answers-anecdotal. look at the answers i'm looking for. quite frankly, it's people who have little knowledge who tend to spout off BS the most on the internet. i often have to get audi answers on non audi forums. what does that say about this site?
    Oct 15 2013
    and all those years of running VW approved 0W-40 sure seemed to increase the tolerances in the engine-given the increased oil consumption. that's how much faith i have in running "proper" oil.
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Can we end thread already?
    OP, do what you want. Consequences, if any, will be on you and you alone.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
