Originally Posted by
zillarob
The disks are very slightly different. Where you were measuring from on the hub is one of them.
The b5 also has some bumps around the rivets for reinforcement or something that the b7 does not have.
When using a disk built on a b5 oem center with a b7 pp, these bumps need to be ground down like the b7 or clutch wont fully disengage.
I hope it goes better this time and it was just the starter hung up or something. Not being able to turn the motor by hand is scary isht.
Thanks. I did some google image searching and noticed that the part number printed on the clutch disk is different on the B5 and B7 disks. I should have compared the two disks side by side before I installed it.
rollerton
If the engine and trans are out of the car then bolt the starter on and remove the spark plugs. See if you can turn the engine by hand.
If it's stuck then ..you might not like this but no damage will come from it: grab a pair of jumper cables, connect 12V+ from the battery to the battery connection on the starter. Ground the battery to starter with the other cable.
Use a screwdriver w/ insulated handle to bridge the small push-on connection on the starter to the 12V batt . The starter WILL crank. And there might be a spark or two, it draws some AMPs.
If it cranks then you're good?
If it doesn't I might try loosening the starter incrementally until it frees up, maybe that flywheel wasn't spec'd right?
Anyway, that's how I'd go at it I think.
Thanks for the advice. I was thinking about doing this as well. The starter is already installed and I can turn the engine by hand without any problem. I'm just not too confident about doing this because I might mess up something? Do I need to fill the motor up with oil?
Vxlgsi
Hi i'm from TTV I have been asked to lend a hand on this post by another member. I'm not sure what advice I can offer as you guys have way more knowledge about these cars than me.
Its interesting that you said you could turn the engine over just fine when it was out of the car with the gearbox fitted, but it doesn't turn over when installed?
The only time I have seen this was when I fitted a new engine to a car and forgot to install the engine ground cable.
Not being able to turn the engine by hand though is concerning. May I also ask what is involved with a stage 3 engine upgrade?
Thanks for lending a hand. Yes, I was able to turn the engine with the gearbox while it was outside the car the first time. It wasn't until I put everything back and tried to prime the turbos that I heard the weird grinding noise. The motor would turn with the starter but I couldn't turn it by hand.
Will forgetting a ground cable cause this issue? I would think that not having ground will cause the starter to not crank at all and won't engage the flywheel. For what it worth, when I separated the transmission this time around, I tried to spin the starter gear by hand and was able to turn it with one finger. I turned it counter clockwise.
The stage 3 build is all bolt on stuff. The motor was not taken apart for any internal work. I did change valve cover and cam tensioner gaskets.
