Originally Posted by
forcefed7
I hate to be the negative nancy here, but of all the things that didn't happen today, this story didn't happen the most.
Or he was as bone stock as they come with zero mods.
A tune & pulley CST-V is easily a 520-540wheel horsepower car. Even with the weight difference between the two cars, that kind of power will pretty much rape you anywhere.
Stock they are putting down 445WHP, which I would think even a stage 1 S4 would struggle with on a roll race like OP mentioned.
For reference, here is the dyno chart and this is the thread it came from:
[url]http://www.cadillacforums.com/forums/2009-2015-cadillac-cts-v-performance/219128-cts-v-dyno-stock-vs-wait4me.html[/url
I lol'd at the bold! Even bone stock gen2 V's trap 115-116 mph and are only a few hundred pounds heavier than a s4 sitting about 4300 before any weight eduction mods. For reference, my new setup should put me around 750whp on e85 after I get it retuned.
cnair
^ What he said... A stock Gen 2 CTS-V is a 118 mph trap speed car.
That would be a factory freak or a fast track like atco.
hotleadsingergu
Yup, I'm with the last few. A stock CTS-V runs faster than most Stage 1 S4s. A Stage 1 CTS-V (which that one is on the long end of it, by the looks) beats a Stage 2 S4 most of the time.
With an exhaust, intake, pulley, and tune, that CTS-V would slap a Stage 2 S4 around all day. That thing would probably run mid- to high-11s, and you're probably around a second slower than that. Either he lied about what's in his car or there was something wrong. From anything but a dig he'd walk away.
Logically thinking about it a V has two more cylinders, over twice the cubic inches and almost a liter bigger blower. Let guys do both an upper and a lower pulley, which depending on the combo and setup, makes +/-20psi. Just a 2.4 upper should make around 12psi. You have to keep in mind that most modded V's sit on Mickey Thompson drag radials so you still might get drug from a dig.
KnewJack
I roll raced a stock CTS-V 2014 model and he barely walked me after about 110 mph. I'm stage 2 APR trapping 112mph with a 1834DA. This race was the same night as my 112mph run. This same CTS-V was trapping 114-116 that night. A Stage one CTS-V? You would need Dual pulley cooling and race gas or 93 E85 mix. Stage one CTS-V's trap 120-122 at my local track.
That sounds about right.
Thanks for the comments fellas as I'm partially biased and couldn't come in here ranting without being a fanboy Hahahaha
