Results 1 to 27 of 27
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    To mudflap or not is the question
    Noticed some rust on the wheel well of my 2013 S4 (34k miles). It's 3 small dots the size of this "o"
    Really pisses me off, I live in Ohio and drive the car year round. I have the touch up paint and will be fixing it soon. I can't find too much info on mudflap or splash guards sides they are about $160 for all 4 oem.
    Has anyone done this? Do u regret it?
    double thumbin' it!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Jul 29 2016
    AB, Canada
    my audi dealer says I can't get OEM flaps for the S4 or Sline A4's.....
    Feb 21 2015
    Ohio
    Quote Originally Posted by Wiredin View Post
    Swore I saw them on Google maybe it was A4, which should be the same.
    double thumbin' it!
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Someone on here has them. Cannot recall if its a 8 or 8.5 but someone on her put them on.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    No... :(
    2015 Sepang Blue S5- APR Dual Pulley Ultracharged, APR TCU tune, CR-15, AG M580s, Girodisc F/R rotors, EBC Red Stuff pads, APR Open Box CF Intake, AWE Track Exhaust with AWE Resonated DPs, etc...
    2017 Mythos Black S6- Stock
    2020 Nardo Grey RS3- Stock
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    When i first read this I was going to be like If you want mud flaps go buy a WRX. But if its doing damage to the car. Maybe some sort of mud flap or guard is in order. Maybe you can fix it and put a heavy duty piece of clear vinyl or something on it. i know some cars come factory with a little section of clear tape or whatever it is in certain places that the factory knows where rock chips will be bad to prevent them. That might be a better option looking wise to mud flaps
    Feb 21 2015
    Ohio
    Quote Originally Posted by chaos2984 View Post
    I know different car but my wife has mud flaps on her 2015 civic but they r hard plastic and they don't extend out that much, but just enough.
    I'll loom into it more when I get a sec. Trying to work some OT to finish up saving for a stage II tune
    double thumbin' it!
    Veteran Member Four Rings theedge111's Avatar
    Apr 15 2009
    Calgary
    Southgate Audi put front ones on my 2011 and 2014 S4, my 2010 came from royal oak in Calgary originally and it had them on all 4 corners when I bought it, the back ones look horrible and I think they have to drill a hole...fronts are honestly hardly noticeable and really help with the paint peeling issues...
    2014 fronts:
    2010 front and back
    2011 front:
    Feb 21 2015
    Ohio
    Quote Originally Posted by theedge111 View Post
    2014 fronts:
    2010 front and back
    2011 front:
    Can u find out what brand they are or are those oem?
    double thumbin' it!
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Check with ECS.....IIRC I saw them there but am not sure.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 21 2015
    Ohio
    Quote Originally Posted by pdqgp View Post
    Yhatzee
    https://www.ecstuning.com/Audi-B8_S4...ard/ES2540784/
    double thumbin' it!
    Apr 15 2009
    Calgary
    Quote Originally Posted by quietcropduster View Post
    double thumbin' it!
    Oem
    Oct 20 2008
    Denver
    double thumbin' it!
    https://www.google.com/url?q=http://...GaofTsq12wFkrw
    https://www.google.com/url?q=http://...nrE5e8hlPbrdYA
    https://www.google.com/url?q=http://...yFxU-XFVcGNcxQ
    https://www.google.com/url?q=http://...RcmJqzLmEGTtaA
    https://www.google.com/url?q=http://...D4Hs7NwoJrKGZw
    https://www.google.com/url?q=http://...XI3dZXo21cpVpg
    and this one LITERALLY is the same thread title as yours.
    https://www.google.com/url?q=http://...DBRJ-w2VMsKfCQ
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Lol! Good old search function.
    The one with the same title as yours mentions use of the 3M clear coat material. I guess it's like the clear bra. Def the more attractive approach.
    Established Member Two Rings skywalker15's Avatar
    Dec 16 2014
    PA
    To chime in here, my family owns a sign and vinyl wrap shop and we've done a couple clear bras / clear vinyl on cars that have the same effect as a mudflap. Definitely the more attractive option however with the thickness of the vinyl you will notice the transition line from paint to vinyl when you're up close. But it is relatively inexpensive and a lot cleaner looking
    2009 Brilliant Black A4 Premium
    LED Interior Swap | S-Tronic Gear Shift | S4 Steering Wheel | Bi-Xenon Conversion | RS4 Grille | LED Fogs | 25% Tint All Around
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Not great looking but, for a mudflap, not horrible either.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Feb 21 2015
    Ohio
    Quote Originally Posted by skywalker15 View Post
    This is the only spot out of all 4 wheel wells that's has rust or paint chips. I will be patching it today.
    Skywalker - ru willing to sell me some clear vynyl? Please PM me how much it would cost for some clear vynyl to protect all 4 wheels. I'd like 2 try that route b4 I go with mud flaps.
    double thumbin' it!
    Oct 31 2010
    Lafayette, Colorado
    I did it before last winter. Hated the back ones, and they scraped when leaving the driveway. I took the back ones off, left the front on because to me they're barely noticeable, and it stops the rock chipping that some describe.
    Mar 25 2015
    Calgary
    I have the front oem flaps on my car, it was like that the first day I saw it on the lot (same dealer as shown above). Id rather have the flaps than chipping the paint in the winter, as we get a lot of gravel on the roads from November to March.
    Jul 29 2016
    AB, Canada
    interesting.. thats the dealer I inquired with that said no go.
    Veteran Member Four Rings mattchat's Avatar
    Feb 12 2012
    2014 Honda Odyssey - Touring Elite
    Calgary
    I have seen a lot of the B8s rust on the front wheel wells, definitely get them. I had mine repainted because they were chipped and peeling so bad and rusting. I sold the car before I had the mudflaps put on but I highly recommend it, especially anywhere they salt the roads.
    2013 S4 - Monsoon Grey - 6spd - ADS - Carbon Atlas - Magma/Black Int.
    Mods: RS5 Red GT front and rear brakes, VMR v710 19x8.5 w/ Mich PSS (S), Audi Ti 19x8.5 w/ Pirelli Sottozero (W)
    AWE + RES DP exhaust, AWE Carbon S-FLO, P3, Eurocode Meisterwerk ASTS, eCode headlights w/ ZKW clear lense swap + Philips Xtreme
    KW HAS, Eurocode USS, Alu Kreuz, DEVAL C/F rear Valence, Black Op Front Grill w/ Chrome Combo, Folding Mirrors
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    Vinyl/3M peels off, doesn't help protect against salt, and mudflaps are fugly.
    Buy some truck bed spray liner from an auto parts and do a few thick coats on the inside of the fender. I did mine last year after getting my fenders REPLACED due to peeling paint. Looks like yours are showing early signs of that issue.
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    I have them front and rear ..LOVE them..I put them on myself 3 years ago..save the splash and lash on your wheels and body..
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Apr 15 2009
    Calgary
    Talk to Norm he will take care of you.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I m a big believer in the use of mudflaps to protect the area behind the wheels from stone chips. Always did MFs as my first mod. IMHO, the factory MFs looked tacked on and I wonder about the ability to protect the paint. That being said, my 2 B8 S4s that I put significant mileage on both have significant stone chipping behind the wheels. My recommendation would be to put Cclear Bra or similar material in these stone chipping prone areas. It will look better and protect better as well.
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Very easy install on OEM mudflaps. I like the way the look. Plus the added benefit of course.
    Active Member One Ring NJ2015sepangS4's Avatar
    Jan 03 2016
    Princeton, NJ
    I have a b8.5 s4 in sepang. Only the OEM s-line flaps will fit on the front of the s4. There are no flaps for the rear. Having said that, my fronts are barely noticeable and super easy to diy
    Sent from my SM-T350 using Tapatalk
