Results 1 to 6 of 6
    Senior Member Two Rings withENEMYin's Avatar
    Jul 24 2014
    2017 Q7 3.0t, 2008 Q7 4.2L
    Chicago, North Burbs
    PLM Heat Exchanger and reservoir install
    Hey All,
    I get this on Friday. Anyone have experience in putting one in? Easy? Solo job or a could a couple of Audi enthusiasts get it done in the garage? Should I bite the bullet and pay to have it done?
    Let me know.
    2014 RS7: Milltek Turbo back, RocEuro Intakes, Ported TB
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    here is the installation link
    https://www.dropbox.com/s/nh3h9t93nz...tions.pdf?dl=0
    U will need a power drill for the HE brackets. Other than that, once the bumper and the crash bar remove.
    It is quite easy to hook everything up and you need to bleed the air out...
    i didnt bleed after installing, the coolant level drop below "min" and pop up "CHECK COOLANT" indicator in the dash.
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Jul 24 2014
    Quote Originally Posted by lowjonathan View Post
    I thought this mounted in front of the existing heat exchanger and they were married? Directions say to remove...
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by withENEMYin View Post
    This replaces the existing HE as do all the other kits...
    There is a DIY for one that adds one on top of the stock HE.
    Geoff
    Jul 24 2014
    Quote Originally Posted by whiped View Post
    Oh well, time to get my hands dirty...
    Jun 30 2015
    yes it totally remove our stock HE and add another reservoir at the right side.
    probably will take around 3-4 hours of the whole process...
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
