Results 1 to 16 of 16
    Oct 04 2013
    203 Connecticut
    Problems starting vehicle. Possibly Ignition lock cylinder? Need Help
    Hi guys, my vehicle intermittently will not start and is unreliable to drive. When it doesn't start it just cranks and cranks with excellent voltage but will not turn over. It feels like no fuel is going to the engine. Mechanics cannot figure out the issue as it doesn't happen when I bring it by. They cleaned the maf and intake, checked fuel pressure. Everything they could think of but all checks out. I eventually was able to get a code for the crank shaft sensor which I changed and have been able to start the car. Well once again I'm having same issue and it was suggested to me it may be my ignition. Now I do have an issue where my key has trouble turning, I have to take it out put it back in, and finagle the key to get it to turn but up it does start. Perhaps this has been worn out to the point where the car has trouble starting. I'm not sure if this is a possible cause so I'm asking for help here. If it is what exactly do I need to change, is it the cylinder lock? Can this be repaired by myself or a locksmith? I don't want to go through the trouble of ordering a whole new ignition set with new keys and having to change the front doors and trunk lock. Need help here please!
    Oct 04 2013
    203 Connecticut
    I really need help with this. I'm borrowing my gf's car and she actually needs it to get around. Mine is parked until I figure out where to go with it. So if you have any ideas pertaining to my issue please don't be shy.
    Feb 24 2010
    And have never been happier
    I just did some research to see if this "might" be a known issue on B7. It looks like members have posted issues with key getting stuck on the initial turn, but no one has mentioned that engine would crank and not turn on. If they did, then there was a bigger underlying issue - fuel pump on it's way out/bad plugs/coil packs/..etc.
    http://www.audiforums.com/forum/b7-m...d-turn-200076/
    Would you be able to make a quick youtube video of this? Ignition issue would probably require a change unless someone is willing to take it apart.
    Also, what car is this? Auto/manual?
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    If the car is cranking then it has nothing to do with your ignition cylinder. unless it;s an immobilizer problem but unlikely
    You mentioned you had crank position sensor replaced and after that you could start. I would look at this sensor again because if a crank position sensor keeps breaking this can be a symptom of a bigger underlying problem.
    Oct 04 2013
    203 Connecticut
    Hey thanks. I tried to duplicate the issue but it started right up about five times in a row. The issue is intermittent. Sometimes is starts right up, then sometimes it cranks for 3-4 secs and starts, then sometimes it will crank but not start at all. If this eliminates the ignition switch, immobilizer, or lock cylinder being the issue then I can look elsewhere. I just replaced the crank position sensor 2 weeks ago. I got lucky and caught a code when scanning. There was not cel or anything.
    Are these the symptoms of a failing fuel pump?. I imagined if the fuel pump is failing it would just stop working all together. I hear it prime every time I turn the key. My car is a manual btw with about 120k.
    Could this be a timing issue? I know other make/models will not start if timing has gone bad.
    Oct 04 2013
    203 Connecticut
    Audio snippet of how the vehicle sounds when failing to start: https://soundcloud.com/user-830890803/car-wont-start
    Jul 28 2008
    Everywhere
    Is the check engine light on when the car doesn't start?
    Oct 04 2013
    203 Connecticut
    Quote Originally Posted by Junaid View Post
    Not at all
    Oct 04 2013
    203 Connecticut
    I'm just brainstorming. Are there any components in the b7 that may cause this issue after the engine gets hot?
    Jul 28 2008
    Everywhere
    There is a rely under the ECU which would cause your symptoms. But I am not sure which one. Next time it's not starting try banging on the ECU box and see if it does start.
    Senior Member Two Rings JayTeeC's Avatar
    Aug 30 2013
    Hershey, PA
    Yes, this. My friend had the same prob, and it was a relay that was cooked. Easy fix. Phew! I'll ask him to jump on here and give some details. Your prob has nothing to do with ignition lock cyl.
    B8 S4 6MT Brilliant Black on Magma, EPL Stage 2 / AWE Touring / RocEuro / ST
    2011 Q7 3.0T Orca Black (family truckster) [] 2009 A4 Cabriolet 3.2Q S-line
    B7 S4 DTM 6MT Brilliant Black on black (past) [] B5 A4 1.8T K04, 5MT Brilliant Black on Terra Cotta (past)
    Aug 30 2013
    Hershey, PA
    His problem got worse and worse, until he did finally start getting codes. No CEL came on, but these codes were there:
    17072 - ECM Power Relay Load Circuit
    P0688 - 004 - Open Circuit
    18068 - Coolant Fan Control 1
    P1660 - 002 - Short to Ground
    18070 - Coolant Fan Control 2
    P1662 - 002 - Short to Ground
    Problem was fixed with new relay. The bad relay also controlled the coolant fan.
    Oct 04 2013
    203 Connecticut
    Quote Originally Posted by JayTeeC View Post
    Thanks, this is an elusive issue as I've been able to start the car the past few days.
    To bang against the ECU effectively, should I remove the plastic cover?
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Quote Originally Posted by ladiesgod View Post
    Absolutely. 99% sure it's the crank position sensor. It drove me crazy for weeks.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Senior Member Two Rings a4Jerseyboi's Avatar
    Aug 24 2009
    North NJ
    Awesome! My car has been having an issue similar to this recently. It will crank like the OP's but mine would start after about 4-5 seconds of cranking. Almost as if it struggles to start. About a month ago I got frustrated and was told it was the fuel pump. Replaced it ($600 later..FML) and it was still doing the same. I notice now that strangely it only does it intermittently and also if I leave my phone charger plugged in and let it sit for a while.
    Would this still count as a possible issue with the relay or a totally seperate issue?
    2008 Ibis White S4
    Oct 04 2013
    203 Connecticut
    Quote Originally Posted by earhythmic View Post
    Yea bro I changed that and everything was well. About 2 weeks later, I got the same issue. I got it going after some tries, and have been starting it successfully for about a week or two now. Much better than before I changed the sensor. Still...It cranks way longer than it should. I think there's something else involved. I'll post a sound clip.
