Results 1 to 20 of 20
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Upgraded Power Steering Cooler
    1999 A4 FWD AEB 1.8T ~ Atlas
    Sep 12 2008
    South Central PA
    yes. the stock one sucks wieners.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Not really. I run a tiny Hayden one for fmic. If you really want a cooler do a external oil cooler mines a mocal with thermo plate
    Apr 22 2014
    Aptos, CA
    Byah!?
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Is this a must for a car that will do a few autox's?
    Established Member Two Rings Agent Anger's Avatar
    Mar 20 2011
    Long Beach Ca
    I have a Mocal 19 row oil cooler that does the job, a bit overkill, but keeps my oil temps low in this hot California weather and at the track. If you're going to the track or autocross, then yes its worth it.
    Oct 10 2013
    State College PA
    I always thought about an oil cooler bc it gets quite hot by me and I do a lot of highway driving but my oil temp guard doesn't work anymore so I wouldn't be able to tell.
    Jul 07 2009
    Socal/IE
    Quote Originally Posted by Agent Anger View Post
    He was talking about the ps cooler I think.
    But I run the same oil cooler. Its a nice setup.
    Apr 22 2014
    Aptos, CA
    Good stuff. Seems to me to be a fairly inexpensive yet decent modification for what it's worth.
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    I run mine in the smic location
    I actually replaced that cooler with a new one and mounted it better since I bent a bunch of fins the first time. I like this location much better than the condenser location since the car can be put in service position without having to disconnect the cooler.
    Sent from my VS990 using Tapatalk
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Oct 10 2013
    State College PA
    That's not a bad idea at all. If I were to run an oil cooler how would I run lines to it? Like to and from locations?
    Aug 23 2014
    Tucson
    Quote Originally Posted by Davdraco1 View Post
    I'm curious to see one of those setups too.
    Oct 10 2013
    State College PA
    I kinda always thought about Putin the oil cooling in line for the turbo feed so the oil is nice and cold when it gets to the turbo.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    So much threadjack
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jul 07 2009
    Socal/IE
    Line goes from sandwich plate below stock cooler to cooler(smic location) back 2 sandwich plate.
    This is the kit I run but you can do it much cheaper if pieced together. I plan to put a small efk in front of it so when sitting it still gets air
    http://www.tdnparts.com/oil-cooler-kit/
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by B5nDisciple View Post
    This is a PS cooler? Looks sweet.
    Oct 10 2013
    State College PA
    Quote Originally Posted by Avant Nate View Post
    So much threadjack
    Just a little. I figure if we are on the topic of additional cooling why not?
    Apr 22 2014
    Aptos, CA
    Yeah I agree, bending the thread imo. Good information!
    Aug 23 2014
    Tucson
    Quote Originally Posted by b5a4erik View Post
    I guess technically it's labeled as a transmission cooler as it states in the description but it is a power steering cooler for me haha. I got the idea from another thread on here and decided on the smic location. I just had to cut the oem hoses a bit and make a bracket and voila, a smic located power steering cooler :)
    Here's the one I used:
    Hayden Automotive 402 Ultra-Cool Tube and Fin Transmission Cooler https://www.amazon.com/dp/B000C39C86..._p2qNxbVEDH5B9
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Here's an idea:
    You do not need to do the relocate, you can mount one in the oem location and the fans are just an added bonus. However a relocate really cleans things up.
    http://www.audizine.com/forum/showth...ry-charger-mod
