    Jun 15 2010
    Chicago
    Rounded the flare nut bolt for the brake line, what to do next?
    Was installing stainless steel brake lines and rounded one of the four flare nuts. Had a set of flare nut wrenches but they skipped the 11mm size. So I used a regular wrench and 3 of them broke loose easily but the rear driver side was on tight. Thought I broke it loose but it just got rounded. Went to the store to get an 11mm flare nut wrench but it slips. Tried using PB blaster and that didn't work. Lastly, tried using vise grips but even that can't break the nut loose. What's the best thing to do next? Does Audi sell the hard lines?
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    leave that one alone :) is the best thing to do
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Jun 20 2015
    NC
    Vice grips. Preferably needle nose. It'll look like shit before and after but it will do the trick
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by Sceanzo View Post
    Yup, vice grips
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    Use vise grips to get it loose and then go to autozone and buy a new nut, and rent a brake line cutter and flare kit.
    Cut 3mm off slide the damaged nut off, then slide the new one on and crimp in a new flare. Bingo good as new for a couple bucks.
    https://www.amazon.com/OTC-6502-Mast.../dp/B0075XHDHI
    ...or go to the dealer and buy a new hard line. Bend over and prelube if you go this route
