Results 1 to 28 of 28
    Sep 10 2008
    ashburn, va
    Question Pro's and Cons of running 19inch wheels vs 20 inch wheels
    I would like to hear ppl's opinions on what size wheels ppl prefer between the two?
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Click
    IMO, 20's are a cosmetic thing only and don't offer much else except increased costs.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    if you get 20's, be sure to bookmark this link
    https://www.google.com/webhp?sourcei...pair+directory
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    20s: higher cost, slower car, rougher ride.
    Sep 10 2008
    ashburn, va
    Quote Originally Posted by onlyaudis View Post
    lol thanks!
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    To me 19's just look right, they're in proportion. 20's look too big. But hey that's me.
    Apr 04 2012
    MSP
    20s will be heavier typically. Even if same weight as a 19 they will require more energy to spin. They also will be more prone to bending with pot holes. You will also experience more vibrations with 20's - thin tires => so you'll feel vibrations more - no tire balances out 100% perfect. Tires will cost more and rims will cost more.
    That being said - I run 20's in the summer -
    Apr 05 2016
    Portland, OR
    Everyone is pretty much spot on.
    I run 20s in the summer, 19s in the winter.
    20s subjectively look better, have more NVH and cost slightly more.
    FWIW, my 20s are lighter than my 19s not that it really matters.
    Ultimately, go with what you like the best. Some love the look of 20s some hate them. It is up to you
    Geoff
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Quote Originally Posted by LittleDozer View Post
    This, and IMO look too big.
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Sep 10 2008
    ashburn, va
    thanks everyone, im leaning towards 19's now
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    lmfao so true
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    Apr 04 2012
    MSP
    Quote Originally Posted by whiped View Post
    Even if they are lighter they may require more energy to rotate given that weight is over a larger area. My 20's are lighter than OEM 19's as well but they don't feel lighter on the car... when I put my 18's on it feels like I shed 100lbs. Didn't feel that way before when I'd switch out from my OEM 19's (which again are heavier than my 20's) to 18's.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by MrFunk View Post
    I agree. My car is only slightly a racecar though, so I don't mind compromising some performance for looks.
    Geoff
    Apr 04 2012
    MSP
    I'm running 20's also... lol... the car has plenty enough power for it not to be a big deal... most new sports cars are now coming with 20's.
    Nov 10 2014
    Apex, NC
    20 > 19
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Established Member Two Rings douglasjboehme's Avatar
    Jul 22 2015
    1995 Land Rover D110 2.8TDi SW, 2016 Sepang Blue 6MT S4
    Blue Bell, PA
    2018 RS5 | Misano Red | All Options | AWE Touring Cat Back, BBS CH-R Nürburgring Edition Wheels
    Apr 11 2012
    Tires for 20's don't have the right load rating for our heavy ass cars, be prepared for more blow outs.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by will13k7 View Post
    dude.. lmao. I have been running on 20" for over 3 yrs straight now. And I have an A6- heavier than the S4. Only had one blowout till now, that too in the dead of the night on a crater like pothole.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Apr 11 2012
    I'm talking about 20's for a S4 that fit a dropped car, 245/30, 255/30, and two blew out for me, PSS's too. no punctures, sidewall failures. about 50% life left. load ratings are meaningful, some tire shops won't even install tires that don't meet the minimum. I didn't take this seriously either, did so after two blow outs on the freeway not even hitting any hard bumps or potholes around that time. just adding my experience and what I learned, do what you will with this info.
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    I have 20s now and will be getting 19s for winter. Unless you have air ride I wouldn't go with 20s though. They are big and heavy and the ride is a little bumpy due to low pro tires.
    Sent from my beeper
    @martino_motorsport
    Junior Member Two Rings
    May 06 2019
    texas
    i am also considering a change from OEM 20s to B8 19/9/ET33 rotors. for the reasons in this thread. BTW, in 8k miles, i have two catastrophic blowouts with the Conti ContactSport P05 that came on the car. And, both flats came about 80 miles from an Audi dealer, which was the only place i could find 275/30/20 on short notice. and, the tires will be Michelin.
    Mar 31 2008
    eS-4
    CAL*SO
    i went from oem 19s to lightweight 20s and its noticeable enough that i would never consider oem weighted wheels ever again.
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by Fresh.S4 View Post
    Yeah, but that's not a fair comparison. OEM's have to achieve a much higher testing standard vs 'most' after market wheels. That unfortunately requires a heavier wheel that is better able to bend and be reshaped vs simply cracking. I can count on one hand the number of times in my life I've seen a cracked OEM wheel vs the number of times I've seen a cracked after market wheel - high end wheels too.
    OEM wheels serve their purpose well though but in terms of weight which was your original point I can tell instantly there's a weight difference when running OEM wheels vs the countless number of after market wheels that I've run over the years.
    Shameless plug - https://www.audizine.com/forum/showt...Forgestar-CF5V - I have these for sale now LOL
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Jun 23 2015
    Michigan
    Quote Originally Posted by blackfunk View Post
    I think it has to do with the manufacturing too. OEM wheels are cast and cast wheels have to be beefier/heavier in order to have the same strength as an aftermarket forged wheel. If Audi forged their wheels, the wheels could be lighter with the same strength if not more, but forged wheels cost more to manufacture so it cuts into profit margins.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Biggest contributor to most wheel damage is a tire that’s not well suited to protecting the rim. Run a wide tire setup with a good sidewall size and stiffness for your level of driving vs road conditions and you won’t be breaking or bending wheels even if you hit the occasional pothole. Run stretched out tires and small profiles and you’ll increase this issue. It’s one of the main reasons why l can’t stand Michelin PSS tires I had one set and because of its shit ass sidewall design I scratched one wheel and the another pothole completely gouged the sidewall on another tire. It’s ironic how people rave about those tires and they’re on every high end performance car, but they suck in terms of their cross-section size on whatever width you get and they always look stretched out no matter what and their “lip protector” feature for wheels isn’t worth the 12 letters it spells. I got rid of those things years ago when the Indy500 tires first came out and tried them and the width is so much, the sidewall isn’t stupid soft anymore and I can’t hit a pothole and know I don’t have to pull over because I just punctured or even damaged the tire, let alone the wheel. Literally just see dust on the sidewall that brushes or washes away.
    So, sorry to go off on a slight tangent there, but get yourself some good meaty tires, which can still be low profile and as it compresses down, it’ll pillow out and protect the edge of the rim as well from the impact. That’s your cushion. In terms of weight, 19” wheel way lighter than factory wheels and you’ll feel it in both braking and acceleration changes. Rotational mass is a thing. One of the reasons why I went with light weight 19’s. The make a big dent in your weight savings per corner and you’ll notice added quickness from a roll as well.
    Senior Member Two Rings raceshop147's Avatar
    Oct 18 2021
    2012 Toyota Tundra, 2004 Aprilia Tuono R, 2021 Beta 300RR Race
    19” bbs
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    Quote Originally Posted by SwankPeRFection View Post
    What brand do you like/recommend for the "meaty" tires ?
    Aug 05 2013
    N/A
    Quote Originally Posted by carguy19 View Post
    I switched to Firehawk Indy500s years ago and find they are the best bang for the buck in terms of traction/durability and width on the rim. In my opinion, they are better than the PSS tires, which I hated and cost way less. I just didn’t think the Michelins were all that and I don’t understand why so many people use them. Hell, stock PSS tires on the newer BMWs cut and chunk their outer tread at even the slightest aggressive or track usage. Honestly, they’re overpriced shit. The Firehawk Indy500 tires have excellent dry traction and work great in the wet as well. I don’t baby my car and I drive very aggressively and they just work for me. Super neutral handling and you can easily feel and control any slip that might happen at the extreme limits. They don’t just get to the limit and give out completely. They just work man, no other way to say it. Even in stock size, there is no stretch on a wider than stock wheel and 265s fit even wider if you needed a bit more contact patch. Coupled with lightweight wheels, the combo works for great off the line response as well as from a roll.
